Loading...
Pages: [1]   Go Down
Author Topic: need guidance about servo and arduino mega  (Read 306 times)
Offline Offline
Newbie
View Profile
   im noob in arduino and servo.
i want to control 2 servos using the accelerometer from an android phone(since i read that arduino is compatible with most android phones).
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Forget the phone for now, and just get used to driving the servos from serial commands.
Zoomkat will be along shortly to post some example code.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
Thanks
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Simple test code for use with the serial monitor to test your servo.
Code:
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
    int n = readString.toInt();  //convert readString into a number
    // auto select appropriate value, copied from someone elses code.
    if(n >= 500)
      Serial.print("writing Microseconds: ");
      Serial.println(n);
      myservo.writeMicroseconds(n);
      Serial.print("writing Angle: ");
      Serial.println(n);
      myservo.write(n);
    readString=""; //empty for next input
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Newbie
View Profile
btw is arduino mega and mega 2560 the same?
can someone give me a code about two servos being controlled by pushbutton..tnx smiley
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
 The original Arduino Mega board was based on the AVR mega1280 chip and that board was replaced by the current Arduino Mega2560 board based on the AVR mega2560 chip. The main difference is the newer mega board has twice the program flash memory size (256KB Vs 128KB) and uses the 8u2 USB serial converter chip Vs the FTDI USB serial converter chip on the older mega. Other then that they are identical in performance.
Lefty
Logged
Pages: [1]   Go Up
Print
Jump to:
