Topic: Arduino DNS lookup (Read 3681 times) previous topic - next topic
mrjonny2
I am looking to use the EthernetDNS library to look up a specific server every time and get its IP without any user interaction.  the current code that requires me to type in the hostname into the serial monitor is as follows.  I tried just defining the hostname as my address but that didn't work.
//  Copyright (C) 2010 Georg Kaindl
//  http://gkaindl.com
//  This file is part of Arduino EthernetDNS.
//  EthernetDNS is free software: you can redistribute it and/or modify
//  it under the terms of the GNU Lesser General Public License as
//  published by the Free Software Foundation, either version 3 of
//  the License, or (at your option) any later version.
//  EthernetDNS is distributed in the hope that it will be useful,
//  but WITHOUT ANY WARRANTY; without even the implied warranty of
//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
//  GNU Lesser General Public License for more details.
//  You should have received a copy of the GNU Lesser General Public
//  License along with EthernetDNS. If not, see
//  <http://www.gnu.org/licenses/>.
//  Illustrates how to do non-blocking DNS queries via polling.
#if defined(ARDUINO) && ARDUINO > 18
#include <SPI.h>
#endif
#include <Ethernet.h>
#include <EthernetDNS.h>
// substitute an address on your own network here
byte ip[] = { 192, 168, 0, 250 };
// substitute your DNS server ip address
byte dnsServerIp[] = { 192, 168, 0, 1};
// NOTE: Alternatively, you can use the EthernetDHCP library to configure your
//       Ethernet shield and find out the DNS server IP address.
const char* ip_to_str(const uint8_t*);
  Ethernet.begin(mac, ip);
  Serial.println("Enter a host name via the Arduino Serial Monitor to have it "
                 "resolved.");
  // You will often want to set your own DNS server IP address (that is
  // reachable from your Arduino board) before doing any DNS queries. Per
  // default, the DNS server IP is set to one of Google's public DNS servers.
  EthernetDNS.setDNSServer(dnsServerIp);
  char hostName[512];
  int length = 0;
  while (Serial.available()) {
    hostName[length] = Serial.read();
    length = (length+1) % 512;
    delay(50);
  hostName[length] = '\0';
  if (length > 0) {
    byte ipAddr[4];
    Serial.print("Resolving ");
    Serial.print(hostName);
    Serial.print("...");
    // Let's send our DNS query. If anything other than DNSSuccess is returned,
    // an error has occurred. A full list of possible return values is
    // available in EthernetDNS.h
    DNSError err = EthernetDNS.sendDNSQuery(hostName);
    if (DNSSuccess == err) {
      do {
        // This will not wait for a reply, but return immediately if no reply
        // is available yet. In this case, the return value is DNSTryLater.
        // We can use this behavior to go on with our sketch while the DNS
        // server and network are busy finishing our request, rather than
        // being blocked and waiting.
        err = EthernetDNS.pollDNSReply(ipAddr);
        if (DNSTryLater == err) {
          // You could do real stuff here, or go on with a your loop(). I'm
          // just printing some dots to signal that the query is being
          // processed.
          delay(20);
          Serial.print(".");
      } while (DNSTryLater == err);
    Serial.println();
    // Finally, we have a result. We're just handling the most common errors
    // here (success, timed out, not found) and just print others as an
    // integer. A full listing of possible errors codes is available in
    // EthernetDNS.h
      Serial.print("The IP address is ");
      Serial.print(ip_to_str(ipAddr));
      Serial.println(".");
    } else if (DNSTimedOut == err) {
      Serial.println("Timed out.");
    } else if (DNSNotFound == err) {
      Serial.println("Does not exist.");
      Serial.print("Failed with error code ");
      Serial.print((int)err, DEC);
// Just a utility function to nicely format an IP address.
const char* ip_to_str(const uint8_t* ipAddr)
  static char buf[16];
  sprintf(buf, "%d.%d.%d.%d\0", ipAddr[0], ipAddr[1], ipAddr[2], ipAddr[3]);
  return buf;
PaulS
Is your machine a DNS server? I didn't think so. Setting your machine as the dnsServerIp was the wrong thing to change.
The value in hostName is what is read from the Serial port. It is that value that you want to hardcode.
zoomkat
I think the arduino IDE 1.0 now includes DNS in its ethernet library, which you may want to check out.
mrjonny2
I am going to use the DHCP library to get the DNS server address, but the data that comes in on the serial read is what I want to hard code. So yes.
mrjonny2
I had a look at the new IDE but decided I can't use it as I am planning on integrating this into a system I have already written, this would require rewriting the whole thing as I used a lot in terms of the ethernet libraries.
