Loading...
Pages: 1 ... 3 4 [5] 6 7 8   Go Down
Author Topic: Multidisplay, a Open Source inCar Display, Logger  (Read 6493 times)
0
Offline Offline
Full Member
Arduino paper
View Profile
WWW
Looks cool Designer2k2!
I've been fighting with this LM2917N... its sticking out a reference voltage of 1.2V and then seems to work best actually triggering on a GND than a VCC  :-/ So I've got something screwy in my circuit im trying to sort out ...
Logged
Checkout my projects development blog @ SLiDA
Austria
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
do you have a special reason for the LM2917 in the 14pin case?
one difference is that on the 14pin you need to shortcut pin 3 and 4 directly, look at the 8pin where its internaly connectet.
in your circuit you have pin 3 with a C and pin 4 with an R to ground.
same for pin 11 and 12, they are internaly shortcuttet and then routet to ground, you have a R6/D2 there.
and pin 8, 9 i have also shortcuttet, you used R7. but that looks ok becouse of the zener.
something like this should be a copy from the 8pin to the 14pin:
i thing its right like this, but its sunday after a short night  smiley-grin
Logged
0
Offline Offline
Full Member
Arduino paper
View Profile
WWW
No special reason other than thats my local availability and so thats all I could get 'off-the-shelf'.. I would have been better off getting an 8-pin in from futurelec in hindsight....
Thanks for the circuit - i did pickup my lack of bridge on 3/4.. i'll have a fiddle based on the schematic you kindly provided shortly..
« Last Edit: August 16, 2009, 01:52:23 am by adr1an » Logged
Austria
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
got the interface nearly assembled:
im very happy how well the 2 layers align, but making the vias is a sh*** job  smiley-razz
and put my prototype in the car:
i messed up the video  :-[ , but its working  smiley-grin
drove about 2 hours arround, the LCD sometimes shows crap (need to make it more stable) but even as i had 43°C in the car it worked perfect smiley
Logged
0
Offline Offline
Full Member
Arduino paper
View Profile
WWW
Looking good!
Is the SuperCap on the PCB to survive cranking/start-up ?
Logged
Austria
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
to survive starting i have a big cap in the power supply, the one on the interface should get me a stable 5V for the ADW´s.
this print will be connected with a 2-3m network cable to the arduino, and located in the engine bay. im hoping that the big cap is enough to remove noise   :-/
Logged
0
Offline Offline
Full Member
Arduino paper
View Profile
WWW
Ok.. Im about to start abusing things. I've breadboarded this, and I've made the changes as per your suggested schematic and I'm going insane. Can't get it to work properly at all.
I am going to leave it for the moment.. I think the fact I'm using a tantalum instead of a ceramic for the 2 x 1µF Caps isn't helping.. I'll pickup some Monolithics tomorrow..
Im not convinced I've got the 2917N pinned right either... its just not behaving properly at all. Guess my caps aren't helping... but if I have the lower board connected to ground I get nothing much.. if I leave the bottom ground floating I get voltage - now thats just all whacked to start with smiley-sad Then if I bridge the ground I can only manage about 0.6V's out the other side. I've even gone back to using a 130K resistor in place of the trimpot, so it should be identical to your setup..
Heres a pic in case you can spot anything obvious... Yellow jumpers are the input frequency, white jumpers are the RC circuit, Blue is the signal out, red and black are pwr and ground... the LED is hooked up to the signal out wire just to give me a visual reference...
a full res version is at http://slida.canberrariders.org.au/wp-content/uploads/2009/08/P1040265.JPG
This is really annoying me now smiley-sad If only I had a damn 8-pin 2907.... Argh!!!! Im pretty sure I need to do some more work on the 2917.. you'll see on this tach schematic that 11 is pulling off of the supply as well.. I think 11 is important to the Internal Zener? I dunno.. Im too tired right now to work it out .. all the example apps seem to hook it between VCC with a pullup and GND with a sig-diode......
EDIT: Ok, picked up some 1µF Monolithic Ceramics today, so am replacing the tantalums. Don't ask  :-? . After that, I'll modify my circuit to have the signal diode and 10K pull up off of pin 11 - it seems to be constant across the few 2917 examples I could find. Wish me luck.  ;D
« Last Edit: August 20, 2009, 04:30:47 am by adr1an » Logged
Austria
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
on a first view the breadboard does seem right, but its tricky to see everything  :-/
order a 2907 in 8pin, i think thats the easier way instead off debugging this...
Logged
0
Offline Offline
Full Member
Arduino paper
View Profile
WWW
Yeah... Im chasing down an 8-pin.. but damn it .. I refuse to admit defeat!! smiley
I think I need to ditch the BC557 and look at my pinout again.. w/ the 2917N I dont need an AC input.. it can be just a DC differential...
I'm *really* sucking at this effort... and I dont know why... it should be a fairly simple circuit  :o
Logged
Austria
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
i would understand it different...
my input to the circuit ist a switched 12V, no AC. The BC557 just helps to get a nicer signal into the LM, you need some sort of other circuit then becouse having a 5V supply but giving a 12V input doesnt work  smiley-wink
from your Applications Information i take that the LM2917 is needed when the supply voltage is not stable, but we have nice 5V?
Basically yes, just giving it up is not good, but you could get a lm2907 to work, and have something what works, and then chase the 2917 problem. But you removed the show-stopper  smiley-wink
Logged
Austria
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
got them prints ready and ordered 1 to see how they look when they are professional made smiley
the arduino main print:
the interface print for all the sensors:
More information including the schematics: http://code.google.com/p/multidisplay/wiki/SplitBox
Logged
Austria
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
the main print is here  smiley-grin
my first ever ordered professional print. glad it worked so well, hope it will work as nice as it looks  8-)
Logged
Austria
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
Started to build the first kit:
today i made the main print, where the Arduino, LCD and powersupply is:
the breadboard version:
and the real thing:
and it works:
 smiley-grin
tomorrow i build the sensorprint (shown above in my selfmade version) and then its very close to get into my car  8-)
« Last Edit: October 15, 2009, 02:24:02 pm by designer2k2 » Logged
Austria
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
the first Kit is build and running:
Check the Website for more informations: http://code.google.com/p/multidisplay/
Logged
Austria
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
updated the SVN, Partlists, Layouts and the Wiki, everything you need to make one off this is now online  smiley
wiki: http://code.google.com/p/multidisplay/
Instructions: http://code.google.com/p/multidisplay/wiki/Build_a_Kit
when running like planned i will install the first kit this weekend  8-)
Logged
Pages: 1 ... 3 4 [5] 6 7 8   Go Up
Print
Jump to:
