Loading...
Pages: [1]   Go Down
Author Topic: [ANN] ArduinoTap : an Unit Testing library  (Read 809 times)
Offline Offline
Newbie
View Profile
ArduinoTap is a port of the Perl5 module Test::More.
It uses the Test Anything Protocol as output, that allows a compatibility with the Perl QA ecosystem.
It allows a simple end efficient way to write tests (without OO).
An additional script 'runino' allows to build a sketch, to upload it, and to capture its output.
So, it's possible to run a fully automatized test suite on device.
The library is hosted on Github : http://github.com/fperrad/ArduinoTap.
Patch, feedback are welcome.
Thanks,
François.
Logged
New Zealand
Offline Offline
God Member
Arduino pebbles
View Profile
WWW
I had a quick look in the repository on GitHub.
My one suggestion would be to change the example code in https://github.com/fperrad/ArduinoTap/blob/master/MANUAL.md to put the test code in setup() rather than loop() then you don't need to worry about the prospect of looping.
--Philip;
Logged
Pages: [1]   Go Up
Print
Jump to:
