Topic: Powering Arduino Uno (Read 1 time) previous topic - next topic
rockerrullz
Dec 09, 2011, 04:41 pm Last Edit: Dec 09, 2011, 04:42 pm by rockerrullz Reason: 1
Hi guys,
The main ideea of this post is to ask you if its a good ideea to power up the arduino with this kind of battery:
http://www.batteryjunction.com/duracell-2012.html
or with 4 of these in series connected:
http://www.batteryjunction.com/encocebaeccr2.html
Thx:)
johnwasser
That 12V battery is for very low power device or devices that only run a few seconds at a time.  It will run your Arduino but not for long.
Those lithium coin cells will also run your Arduino, but not for long.
For portable operation a reasonably cost effective power source is 3 AA cells in series connected directly to the +5V pin (not Vin).  This bypasses the voltage regulator which throws away some power.
You will also want to put the processor to sleep as often and as deeply as possible.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
rockerrullz
Well i`m trying to find the best solution, i need a portable power supply for a gps based vehicule, so the ideea with
Quote
i dont think is so good in my case.
johnwasser
What powers the vehicle?
rockerrullz
Currently all the power is taken from arduino, and dont think this is the best solution, i guess i could power up the ardumoto shield separately :-?
johnwasser
How big is your vehicle?  If it is much larger than a pack of cards you will probably need a lot more power than a tiny replaceable battery can supply.  Perhaps a rechargeable battery pack such as used for RC cars or a cordless drill would be appropriate.
rockerrullz
My vehicle looks exactly like this:
( 60x160 dimensions), and on it near the Gearbox its the arduino uno with 3 shields(ardumoto, xbee, and gps ). and there should be the power supply too. so i guess that i`m looking for a small portable power to fit in it and supply the needed voltage to run all 3 shields and motors.
Btw, thx for the replays :)
johnwasser
I'd use a 4 x or 5 x AA battery holder and put in rechargeable NiMH AA cells. The resulting voltage (4.8 or 6.0) can be hooked directly to the Vin pin of the Arduino.  I'd go with 4 cells because some add-on devices might not be able to take 6V safely.  The 4.8v should be just right for the electric motors and should be enough for any 5V device.  For any 3.3V devices you can get that from the 3.3V pin of the Arduino.
retrolefty
Quote
Too low a voltage for Vin. Arduino spec for Vin:
Quote
Input Voltage (recommended) 7-12V
Input Voltage (limits) 6-20V
johnwasser
Quote
Quote
OOPS!  You're right.  I meant to say "directly to the +5v pin".  Sorry.
magnethead794
I'm using a 8.4V RC battery to Vin.
