Loading...
Pages: [1]   Go Down
Author Topic: How to stop tilt servo centering while booting up?  (Read 754 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
i ripped the thread topic from a post on a related forum.
my servo centers on boot. its a problem as every time i reset/boot the arduino the servos jump  to mid-tilt position.
i tried
Code:
#include <Servo.h>
Servo panS;
Servo tiltS;
int tiltMin=60;
int panMin=0;
  panS.attach(9);  // attaches the servo on pin 9 to the servo object
  tiltS.attach(10);
  //on wake up smoothly bring pan and tilt to start
  for(int pos = 93; pos>=panMin; pos--) {
    panS.write(pos);
    delay(33);
  for(int pos = tiltS.read(); pos>=tiltMin; pos--) {
    tiltS.write(pos);
    delay(33);
but if i try to servo.read() i always get 93. no matter the location.
i found this bit on an old documentation page
Quote
Safety Quirk
Even though you attach a servo, it won't receive any control signals until you send its first position with the write() method to keep it from jumping to some odd arbitrary value.
but what help is that?
im surprised it hadn't been mentioned.
if i haven't searched enough please enlighten.
keywords: servo, jerk, startup, boot
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
You can set the initial position of a servo before you attach it.  If you don't set the initial position I believe it defaults to centered.
It's not clear from your code where you want the servos to start.
Code:
#include <Servo.h>
Servo panS;
Servo tiltS;
  panS.write(panInitialPosition);
  tiltS.write(tiltInitialPosition);
  tiltS.attach(10);
If you don't want them making any sudden moves you will need to remember where they were when you turned off the power. For that you will have to use some form of non-volatile memory like the built-in EEPROM.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
the code logic is:
on startup, read last resting place of servo position and from there write slowly to fixed start position
i will try the EEPROM way, thanks
Logged
Pages: [1]   Go Up
Print
Jump to:
