Loading...
Pages: [1]   Go Down
Author Topic: Multiple pushbuttons and pulldown resistor  (Read 957 times)
Offline Offline
Newbie
View Profile
So I have three pushbuttons each with a +5v input, output to pin via resistor and a pulldown resistor to ground. They work great but I'm wondering if I wouldn't be able to just use 1 pulldown resistor to stop them from floating or if this would cause them to not function properly if they were pressed concurrently. If they were not meant to be pressed concurrently, is this a safe thing to do?
If this is a stupid question and this is not logical thinking is there some proper way to do this? 3 pushdowns with a shared pulldown?
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
In cases like this, it is helpful to look at a schematic of what you are trying to do.
Notice that pin2, pin3, and pin4 are all effectively on the same piece of wire?  So when one of the buttons is pushed, they will ALL see 5V.  No, you can't use a "shared" pull-down resistor.
However, why not use the internal pull-up resistors instead?  Then you don't need any external components.  The only trade off is that the logic is inverted (unpushed buttons are HIGH and pushed buttons are LOW.)
Logged
www.cmiyc.com - A guide to being an Enginerd
Offline Offline
Newbie
View Profile
Ah, I see what you're getting at. By using the internal pullup resistor I can sidestep the external resistors. Would this have any implications for battery life, though, since I would now have to supply a constant 5v except for when the button connection is broken (open) and electrons diverted?
It seems like almost every Atmel chip has support for internal pull-ups so it's also future proof should I decide to switch chips. Great solution, thanks!
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
In order for power to be burned you must have both Voltage AND current.  Holding a pin up with 5V (nearly) eliminates current from flowing just the same as when tied to ground.  So while you are applying a constant 5V, so little current is flowing that the Power is practically Zero.  (In the P = I * E you don't use 5V.  You use 5V-induced voltage which is practically zero.)
Incidentally, when using a pull-down the same reasoning applies.  Keep in mind that if current starts to flow there is a voltage, even a small one.  So you burn the same amount of power using a pull-up as a pull-down.
Virtually no current flows until the button is pressed.  Once it is pressed, the current is the same whether it is a pull-up or pull-down.
If you are worried about power consumption it is a very good practice to enable the Pull-Up resistors on ALL unused I/O pins.  Otherwise, floating pins can draw over 1mA of current.  Which, on a device that only consumes 20mA is pretty significant.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
With the internal pullup, the swithes aren't connected also. All they share is ground, so you can press 1 and 2,3 see nothing.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
Quote
Interesting, I had no idea! Very good to know.
One last question for you then; right now I'm using those buttons to trigger an interrupt on the arduino on any difference in the interrupt pin they are all connected to (H->L or L->H). Other than changing the pin to be an input (to avoid a short) would I even need to change anything else to maintain the interrupt functionality?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
No, just create the interrupt on a Low level instead of High.
Logged
Offline Offline
Newbie
View Profile
Quote
I know this is an old thread but can somebody please elaborate on this. Does this mean all unused pins should be grounded to lower power consumption? If so, would this also mean one has to be extremely careful not to set a pin as output inadvertently, otherwise you run the risk of an overcurrent on that pin?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Better option is to set unused pins to input with internal pullup resistor enabled.
This stops any floating or oscillating, and pins can be pulled high/low by outside forces and not hurt anything.
Logged
DELHI
Offline Offline
Full Member
View Profile
Is there  any other technique of doing this.If we are doing this way the resistor might degrade on variation in temperature. If we using analog read pin to read data .The value may not same at  start and in actual field.
let me know other technique
Logged
AMPS
Cumming, Ga
Offline Offline
Edison Member
Ultimate DIY: Arduino
View Profile
WWW
No this is about Digital I/O.  We are not measuring a voltage so the ACTUAL value of the resistor is not critical.  The pin is looking for a logic change from 0 to 1 on a keypress.
The drawing is flawed.  Any keypress will be the same as ALL keys being pressed since the inputs... by means of sharing a resistor... are also all shorted together.
It's time we all started loving resistors for the very useful job they do for us.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
And time to also love not needing to use any external resistors at all to read switch contacts as the AVR chip gives us optional internal pull-ups to use so there is no reason to not just utilize negative logic and use the internal resistors.
Lefty
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Quote
No, it's not, since the point that you make pwillard:
Quote
is exactly the point that James was making when he posted that sketch.
Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
DELHI
Offline Offline
Full Member
View Profile
i understood above concept like this.
if any of 3 switch has been triggered particular digital pin goes high
Assume i have connected to analog pin. Due to variation of resistor it start reading analog values.depend on analog read signal i can able to judge which mode i need to go..
Logged
AMPS
Pages: [1]   Go Up
Print
Jump to:
