Topic: progmem P macro question (Read 1 time) previous topic - next topic
zoomkat
Is there any advantage to storing data in program memory like below as opposed to just leaving it in the sketch code without trying to specifically storing it?
Code: [Select]
   /* store the HTML in program memory using the P macro */
P(message) = "<html><head><title>Webduino Image Example</title>"
"<body>"
"<h2>LED Image</h2>"
"<img src='led.png' width=256 height=256>"
"</body></html>";
server.printP(message);
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
westfw
Yeah.  There's about 16 times more program memory than there is ram.  if you start putting large strings, like html webpages, in ordinary RAM memory, you run out pretty quick.
zoomkat
This looks to be a handy way of keeping large blocks of reusable html as a variable. The main question is can this P macro be used to store data once the code is running on the arduino. Recently somebody made the statement that program memory is read only apparently when the arduino program is running.
westfw
Quote
program memory is read only apparently when the sketch is running.
Yes, that's correct.  You have to handle the constant data in program memory and the variable data in RAM separately.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
