Topic: Unbelievable slow compilation of simple sketches (Read 64600 times) previous topic - next topic
terryking228
Hi Bob,
Quote
Good that you back up ESET with something else...There was a recent thread on just this topic LOL
I had some issues a year ago and I tried MBAM and liked it. Especially the anti-ransomware protection. I can't afford to have my little YourDuino.com get attacked...
Based on your sig, are you a CNC guy??  I have to find time to get back into that..
Thanks!
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
ballscrewbob
#61
Mar 26, 2018, 03:46 pm Last Edit: Mar 26, 2018, 03:49 pm by ballscrewbob
Sort of Terry...used to build CNC lathes and did a bit of general machine tool refurb.
Got a Ballscrew tag for taking the install time down from a few hours to about an hour and still maintain the build accuracy.  Never did much actual programming.
However thats taken a large leap over the last couple of months since I built a small CNC machine with Ardi.
Current machine is a bit of a Frankenstein as I have the main tooling on small sleds so I can change to a drawing machine or a laser engraver or a router.
I made the pen spring loaded to it keeps a constant pressure
The laser has a second laser I will be using to do distance measuring for uneven surfaces.
Mostly made from scrap materials around the house.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
terryking228
Hi Bob,  Wow that looks good; I like the interchangeable-effector idea.
25+ years ago I built a 4x4 inch table I used for jewelry; mostly carving wax and silver. It's waiting for a transplant board from a 3D printer..   Sigh....
ballscrewbob
The sled idea also brought with it a few weaknesses in the machine itself...
So now  "Strong like bull" each change shows up something else.
Blown out a few motors for the spindle but 24 volts up a 5 volt motor makes for a spectacular ending if not noisy...Now have selectable voltages 5,12,24V at 10A ea.  Oooh look at all the shiny bits.
310x240 mm work area.
BTW not meant as an offence but your avatar always reminds me of Rick Wakeman ;)
terryking228
Quote
I  needed to use Google Image..  Oh. OK.
The photo of me is in front of the Lime tree in the back yard of 4 Rue Jasmine in Carthage, Tunisia (North Africa) where I lived for 3 years.  Now I have more wrinkles and longer hair :-)
Bundy76
#65
Nov 08, 2018, 11:16 am Last Edit: Nov 08, 2018, 11:29 am by Bundy76
Exceptions in virus checker didn't do jack. And had no problem with other PC that had same anti-virus.
What worked for me...
CAUSE:-
Recent documents list with sketches on network shares or drives that timeout (Aren't currently available ). Silly bug/feature. :-P
Apparently the IDE checks/verifies links in "recent sketches" list before compiling/saving/loading etc. Eventually continues after they timeout.
FIX:-
Fix was to to just clear the "recent.sketches="  in preferences.txt file found in...
C:\Users\<your username or whatever>\AppData\Local\Arduino15
( If this doesn't work for you, then a suggestion... Be sure you have the right preferences.txt file, open a sketch and see if it shows up in that file. )
...Thanks goes to obscure post on some obscure forum somewhere else.
Dr_FM
Greetings, fellows.
After many atempts, "one" thing worked for me (Win 10, everything always updated):
  • Grant free firewall access to Arduino IDE
  • Run Arduino IDE always as admin
  • Delete the "preferences.txt" (which I think was the solution)
As I cannot point the "ultimate" step that fixed my problem, I've listed everything I tryed.
Note: The "preferences.txt" was not created again and everything is perfect in my IDE.
