Topic: 16x2 LCD prints foreign letters? (Read 4967 times) previous topic - next topic
Ciehanski
dc42
The LCD Pins:
1 - To ground.
2 - To 5v
3 - To pot.
4 - To Arduino pin 7.
5 - To ground.
6 - To Arduino pin 8.
11 - To Arduino pin 9.
12 - To Arduino pin 10.
13 - To Arduino pin 11.
14 - To Arduino pin 12.
15 - To 5v.
16 - To ground.
The ones I skipped are not connected to anything. From that, is my wiring and LCD variable in the code all correct?
That wiring does correspond to the LCD constructor call in the code you posted.
Try a sketch that does the begin call, then sets the cursor position and prints a single character, or 4 characters all the same. Experiment with different cursor positions and characters. From the results you get, we may be able to establish where the problem lies.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
Ciehanski
The LCD Pins:
1 - To ground.
2 - To 5v
3 - To pot.
5 - To ground.
15 - To 5v.
16 - To ground.
When I do the lcd.cursor(); it doesn't show it at all, but when uploading to the board it shows up, not at the beginning of the line, but about 4 spaces away from the end, and then when uploading is done, it disappears.
Also, when I do lcd.print("Test"); it doesn't even show the weird symbols anymore. My lcd variable code must not be in order.
Ciehanski
Forget that. But the cursor doesn't show. But the symbols do.
floresta
@Ciehanski
You really should not use the Quote button with orange text at the upper right of a previous reply unless you really intend to quote the full text of that particular reply.  If that is not the case then you should use the Reply button with black text that is under the last reply.
Don
floresta
Quote
The cursor is not shown by default. I think the 'lcd.cursor()' command is used to turn it on.
Don
Ciehanski
Quote
Don
I rewired, and recoded my sketch to the LCD Library tutorial on the Arduino site. It still prints the weird symbols, and sometimes doesn't print or show the cursor at all.
Code:
Code: [Select]
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int sencePin = 0;
int switchPin = 8;
int ledPin = 6;
int yellowPin = 7;
boolean lastButton = LOW;
boolean currentButton = LOW;
int ledLevel;
int val;
boolean on = false;
  pinMode(switchPin, INPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(yellowPin, OUTPUT);
  lcd.begin(16, 2);
  lcd.clear();
  lcd.cursor();
boolean debounce(boolean last)
  boolean current = digitalRead(switchPin);
  if (last != current)
    delay(5);
  return current;
void readLight()
   Serial.println(analogRead(sencePin));
  int yPin = digitalRead(yellowPin);
  int sPin = digitalRead(switchPin);
  val = analogRead(sencePin);
  val = constrain(val, 250, 800);
  ledLevel = map(val, 250, 800, 255, 0);
  currentButton = debounce(lastButton);
  if (currentButton == HIGH && lastButton == LOW)
      on = !on;
  if (yPin == HIGH)
   lcd.print("Works!");
  if (on == true)
    lcd.display();
    lcd.clear();
    digitalWrite(ledPin, HIGH);
    analogWrite(yellowPin, ledLevel);
  } else if (on == false) {
    lcd.noDisplay();
    digitalWrite(ledPin, LOW);
    digitalWrite(yellowPin, LOW);
  lastButton = currentButton;
I added some buttons, LEDs, and a light sensor.
liudr
How good is your soldering on the female connector? Can you take a picture of the under side of the lcd to show the soldering job?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
JoeO
What happens when you run Floresta's code in reply #5?
Ciehanski
I'll upload one soon.
It just shows the symbols.
dc42
My mistake, I meant lcd.setCursor(...) - I wanted to see whether cursor positioning worked.
Ciehanski
Even in the hello world tutorial, the cursor, nor the text shows. I even re-soldered the header pins. I have no idea what's wrong.
Ciehanski
Here is my solder job: http://troll.ws/i/Kd8Gei.jpg
floresta
Quote
Quote
Quote from: JoeO on December 10, 2011, 11:01:32 PM
Come on, give us some help here....
Does it always show the same three symbols?
Are they always in the same position?
Are there symbols on both lines?
Don
Ciehanski
Quote
Quote
Don
No, different symbols. Different positions depending on the words being printed. They only appear on the first line.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
