Loading...
Pages: 1 2 [3]   Go Down
Author Topic: 16x2 LCD prints foreign letters?  (Read 1465 times)
Central MN, USA
Online Online
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
Here is my solder job: http://troll.ws/i/Kd8Gei.jpg
Not very good. Your soldering iron is too cold. Your pins 1,6, and 11 are the worst. You should re-head the pins so the solder can melt and be sucked into the holes. You have made some basic mistakes possibly melting the solder on the iron instead of on the part to be soldered together. The only trick you need to know is to NOT touch the solder with the iron.
Your picture is out of focus. To you, does the solder look like kisses?
Only cold solder looks like above. Solution is to re-heat.
Logged
Western New York, USA
Online Online
Faraday Member
View Profile
Quote
No, different symbols. Different positions depending on the words being printed.
The word being printed don't change, they are 'hello, world!' and 'it works!' so what do you mean by "depending on the words being printed"?
Here's another diagnostic sketch to run, you can leave the lcd.begin(20,4) it won't affect the results when run on a 16x2 .
Code:
    lcd.begin(20, 4);
    for (int i=47; i<127; i++)                 // send 80 consecutive displayable characters to the LCD
    lcd.print(i,BYTE);
    delay(100);                                // this delay allows you to observe the addressing sequence
Don
Logged
Online Online
Faraday Member
View Profile
Quote
You could hold the board upside down while you are reheating to try and get rid of the excess solder as well.
Don
Logged
Offline Offline
Newbie
View Profile
Ohhh. Well, I am new to all this. So I should re-solder? Should I get rid of the old header pins, and get new ones? Or just reheat?
Logged
Offline Offline
Newbie
View Profile
My NEW solder job.
http://troll.ws/i/mXeus0.jpg
None of the connections are touching, and they are fully secured with solder.
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
