Loading...
Pages: [1] 2 3 4   Go Down
Author Topic: PCB board drawing  (Read 1948 times)
Ft. Worth, Texas
Offline Offline
God Member
View Profile
I've downloaded Eagle, but I'm thoroughly lost.
I have the board designs in DeltaCAD (2D CAD). screenshot below, click to expand. Would be willing to pay $20, paypal preferred (instant transfer).
This is for my weather station project.
Will be submitting through here -> http://dorkbotpdx.org/wiki/pcb_order
Quote
Design Rules
(Eagle DRU File: http://content.laen.org/pcb/LaenPCBOrder.dru) The minimums are:
    6 mil trace width
    6 mil spacing
    15 mil clearances from traces to the edge of the board
    13 mil minimum drill size.
    7 mil minimum annular ring
« Last Edit: December 10, 2011, 05:50:13 pm by magnethead794 » Logged
KF5RVR
Colorado
Offline Offline
Edison Member
Reviving dead brain cells with Arduinos.
View Profile
If you draw the schematic first, it makes creating the board much easier.  But if you just can't figure it out, I'm willing to help.
Logged
Colorado
Offline Offline
Edison Member
View Profile
Screw it, I'm waiting for a 7GiB download to finish.  Look over the attached PDF.  If it's correct, I'll export the gerber files.
Logged
Ft. Worth, Texas
Offline Offline
God Member
View Profile
You amaze me to do it that quickly. THANK YOU
Looks perfect smiley
Noticed you actually optimized the routing- something I wouldn't have thought of.
My email is steve -> magnethead794.com if you would like to email.
Logged
KF5RVR
Colorado
Offline Offline
Edison Member
View Profile
Do me a favor, and check the traces.  I actually have not done any of the rule checks or anything like that yet.  If it's all the same and I didn't forget or miss anything, I'll go through the rule checks and all of that.
Logged
Ft. Worth, Texas
Offline Offline
God Member
View Profile
Already did :thumbsup: Even double checked the 2 voltage regulator pinouts (that mess at the bottom right of the main board) to make sure they were right, and they are.
« Last Edit: December 10, 2011, 09:06:13 pm by magnethead794 » Logged
KF5RVR
Ft. Worth, Texas
Offline Offline
God Member
View Profile
I just figured if I already had it done up in separate layers on the correct .1" spacing, it shouldn't have been too hard to transfer to a PCB. I did the schematicing and grunge work myself.
Logged
KF5RVR
Colorado
Offline Offline
Edison Member
View Profile
Can you high light the traces that are carrying VCC?  I like to make those traces thicker.  Also, which ones are meant as ground?
« Last Edit: December 11, 2011, 01:51:52 am by KirAsh4 » Logged
Ft. Worth, Texas
Offline Offline
God Member
View Profile
In the original PNG, red is VCC, black is GND, green is DATA.
http://i1105.photobucket.com/albums/h355/magnethead494/wx_schems.png
Logged
KF5RVR
Colorado
Offline Offline
Edison Member
View Profile
Then those VCC lines need to be interconnected ... You have different, separate traces for VCC.  Unless they are different voltages, they need to be interconnected.
Logged
Ft. Worth, Texas
Offline Offline
God Member
View Profile
The mess at the bottom right of the big board is voltage regulators. The one going up and to the left is 3.3V, the one going up the right and that goes to the pin header at bottom left is 5.0V.
The input is 9 volts on the 2 bottommost pins that everything starts at.
added a legend
« Last Edit: December 11, 2011, 01:41:00 pm by magnethead794 » Logged
KF5RVR
Colorado
Offline Offline
Edison Member
View Profile
You're saying the two bottommost pins are 9V raw input?  Yet, it's the same color as your 5V line?  Do you understand where or why it's confusing? smiley
So if I understand you right, you have 9V (Vin) being supplied on the bottom.  The 'T' shape traces are +9V, correct?  From there, you have two regulators, one that regulates down to 3V3 (V3V3) and one that regulates to 5V (V5), correct?
Then, V3V3 is a single trace that goes up to the logic level as well as the HH10D and the BMP085.
The V5 trace goes to the DS1307, runs on the right hand side up to the logic level and on the way also connect to two additional pins around the Mini.
Question: what's the red bridge across the two pins on the left hand header?  If that's supplied voltage, where is that coming from?  It's not connected to anything.
Same thing on the small board, if it's being stacked ontop of the larger one, where is the V3v3 and GND being supplied from?  Which pins are they being connected to?
Understand that I'm not trying to be a pain here.  I want you to get a board that works, not one that once you connect stuff to it you realize something's amiss.  Not knowing what the electrical diagram looks like, I have to rely on you to explain these bits and pieces.
Logged
Ft. Worth, Texas
Offline Offline
God Member
View Profile
This is correct. I'd forgotten to change them.
Quote
Correct
Quote
Correct
Quote
reset and GND for external reset button. And the 2 standalone pins below the mini is the +5/GND pin header for the bluetooth module.
Quote
Yes it's to be a stacked shield. It's going to get power via wire jumpers from the logic board's 3V3 and ground. I have pass-through headers on the logic level for this reason.
Quote
I know. Right now I have it on soldered breadboard so I know it works, but it's a complete mess.
At 9Vin, the current is 70ma with my meter.
If I had to guess, the 3V3 line:
- probably carries 6mA to each sensor
- I don't know how much the logic level pulls (say 2 ma)
- but the LCD display pulls 15mA @ 3V3 including the controller IC (what the smaller board is for)
- So say 30mA on the 3V3 line.
5V line:
- bluetooth I know pulls 25ma because the overall jumps from 45mA to 70mA when I connect it
- the DS1307 runs on coin cell until polled over I2C so it's a non-factor (5ma at most?)
- so assume the arduino pulls ~15ma.
- So say 40-45mA on the 5V line.
« Last Edit: December 11, 2011, 06:28:28 pm by magnethead794 » Logged
KF5RVR
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
You could take advantage of ground planes also, will give you more room for your thicker traces.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Ft. Worth, Texas
Offline Offline
God Member
View Profile
I'm limited to 2 layer PCB. Unless I'm misunderstanding.
Logged
KF5RVR
Pages: [1] 2 3 4   Go Up
Print
Jump to:
