Pages: [1] 2 3 ... 5   Go Down
Author Topic: Dagu Rover 5 chassis robot demo  (Read 15993 times)
Melbourne, Australia
Shannon Member
Lua rocks!
So I finally connected together a few things that arrived in the mail. smiley
This incredibly-sloppily wired-up robot is my first attempt to make something useful, eg. that will one day deliver a can of beer to my hands. smiley-wink
Right now it's a prototype. smiley-razz
It consists of a Dagu 5 chassis which I bought from here:
http://www.robotgear.com.au/Product.aspx/Details/554
(There are suppliers overseas too).
I also got their controller board which supports up to 4 motors and encoders.
At this stage the encoders are not used (although you may spot the wiring for them on the top). There is interrupt-driven code in the sketch to detect one of the encoders.
To help others get started, here is how I wired it up:
The battery is actually 6 x 1.5 NiMh batteries taped to the side.
This is the sketch:
// Dagu 5 Chassis example.
// Author: Nick Gammon
// Date:   11th December 2011
volatile int rotaryCount = 0;
#define PINA 8
#define PINB 9
#define INTERRUPT 0  // that is, pin 2
#define DIRECTIONA 4
#define MOTORA 5
#define DIRECTIONB 7
#define MOTORB 6
#define TIME_FORWARDS 10000
#define TIME_BACKWARDS 10000
#define TIME_TURN 1200
// Interrupt Service Routine for a change to encoder pin A
void isr ()
  boolean up;
  if (digitalRead (PINA))
    up = digitalRead (PINB);
    up = !digitalRead (PINB);
  if (up)
    rotaryCount++;
    rotaryCount--;
}  // end of isr
void setup ()
  attachInterrupt (INTERRUPT, isr, CHANGE);   // interrupt 0 is pin 2, interrupt 1 is pin 3
  pinMode (MOTORA, OUTPUT);
  pinMode (DIRECTIONA, OUTPUT);
  pinMode (MOTORB, OUTPUT);
  pinMode (DIRECTIONB, OUTPUT);
}  // end of setup
byte phase;
unsigned long start;
int time_to_go;
void loop ()
  analogWrite (MOTORA, 200);
  analogWrite (MOTORB, 200);
  start = millis ();
  // check current drain
  while (millis () - start < time_to_go)
    if (analogRead (0) > 325)  // > 1.46 amps
      break;
  switch (phase++ & 3)
    case 0:
      digitalWrite (DIRECTIONA, 1);
      digitalWrite (DIRECTIONB, 1);
      time_to_go = TIME_FORWARDS;
      break;
    case 1:
      // turn
      digitalWrite (DIRECTIONB, 0);
      time_to_go = TIME_TURN;
      break;
    case 2:
      digitalWrite (DIRECTIONA, 0);
      time_to_go = TIME_BACKWARDS;
      break;
    case 3:
      break;
    } // end of switch
  analogWrite (MOTORA, 0);
  analogWrite (MOTORB, 0);
  delay (500);
}  // end of loop
And this is the robot banging into walls (52 seconds):
The code is designed to drive the robot forwards or backwards for 10 seconds. Then it attempts to turn by driving the wheels in opposite directions for 1.2 seconds.
The current-sense circuit is used to detect too much load on the motors, if that happens the code immediately skips to the next phase.
There are quite a few improvements that could be made. For one thing, it needs a beer carrier. smiley-wink
It also could use a sensor to detect nearby obstacles. And a smarter algorithm would help it get out of being stuck in tight places. Oh, and it needs a sensor to stop it turning upside-down and spilling its guts.
This photo, taken after I neatened up the wiring with a my wire-wrapping tool, shows the connections between the motor board and the Arduino:
« Last Edit: December 11, 2011, 12:14:44 am by Nick Gammon » Logged
hello nick gammon....thanks for information provided but i need to know what the controller board, which you have used to support the rover 5 is called as...because the doing a project with arduino and planning to buy the rover 5 for my project...
Gosport, UK
Hi Nick,
I don't know if they are available in your part of the world, but this might fit - http://www.amazon.co.uk/Bigtrak-Can-Holder-Junior/dp/B005G3R4Z0
Been meaning to get one for my BigTrak. Also been meaning to make my BigTrak autonomous, but I only got it for Christmas, and I think it might be too soon to start tearing it apart.
Only problem with the can holder is that it'd need someone in the kitchen to put the can in.
Phoenix, Arizona USA
Where's the beer?
Hi Nick,
I wonder if that'll fit the original Big Trak (still have mine from when I was a kid; then again, I have the transport dumper, so maybe I don't need the can holder...)?
smiley
Gosport, UK
It should fit. I think the mouldings are the same.
Shannon Member
Lua rocks!
The link above would have led you to it, but here is the controller:
http://www.robotgear.com.au/Product.aspx/Details/555
No doubt there are non-Australian suppliers as well.
Belgium
Nice to see another Rover 5 smiley I bought one a couple of weeks ago. I've managed to write a sketch that lets me remote control it through a Nrf24L01 wireless module. I'm using the Mega1280 based Dagu red back spider controller and motor controller. Power comes from a 2 cell lipo battery.  Here's a video of mine:
I also have the version with 4 encoders/motors, but don't really have a clue what to do with the encoders  smiley-confuse
« Last Edit: February 24, 2012, 05:25:16 pm by Bajdi » Logged
Shannon Member
Lua rocks!
Very cute!
I'm not using the encoders right now, but what you could do with them is find how far it has gone. For example, you put out "full power" but you don't know whether, after 3 seconds, you have gone one foot or five. Reading the encoder data back would tell you how much the wheels have moved. Off course that doesn't take into account the wheels slipping.
Swannanoa, New Zealand
New To Arduino (and C)
Nick
I heard of one guy using the guts of an optical mouse, in a sumobot.
He simply detected if he was moving backwards while he was driving the wheels forward and acted on it.
This might help overcome the slippery surface issues.
Mark
hello everyone...i am doing a project which has three sensors, which when detects anything moves in other direction. For these work i am planning to going with rover 5 and also going with encoder compatible board(nick as suggested) but i guess i need some help with stuff....new for these kind of stuff...
hi nick...i am really sorry for the way of the message...i guess its hurt u alot...really sorry for that...i was trying get some information from you and i was in a little hurry...that's it....actually i am trying to develop a robot which should have three sensor's..as it detects something..the vehicle should move...its my final project....
Shannon Member
Lua rocks!
... i guess its hurt u alot...really sorry for that...
This is referring to a couple of personal messages I received in the last few days which shouted at me in all caps.
... i guess i need some help with stuff....
@krishna84 - I'm sorry but I don't see a question here. No wonder no-one else has answered.
What sensors? We can't read your mind you know. Motion detectors? Sound? Light? Colour? Distance?  "as it detects something" ... what? A cat? A wall? A hand? A line? A hole?
Read this:
http://mattgemmell.com/2008/12/08/what-have-you-tried/
I'm not going to sit here and design a cat-avoidance system so you can pass your final project in your exam. At least try something yourself. Choose some sensors. Post a link to them. Show how you wired them into your project (photo or schematic). If you don't know how to do that Google it and find out. If you can't make it work then, at least show how far you got, including links to the web sites you found with Google. If you write some code, post it. If it doesn't work, describe in what way.
Belgium
In your first post you said that the rover is sloppily wired. I got my share of that today, and needed to perform some surgery on my rover. I was trying out a sketch and suddenly one motor stopped running. I was fearing the worst thinking that one of the FETs on the motor controller had given up. Turned out to be a loose wire... one of the wires going from the coil to the connector had come loose. There was almost no solder to be seen on that connection so it's no surprise it came loose.
I've been working on an autonomous sketch using an ultrasonic sensor to detect obstacles. The code works but it keeps bumping into stuff. Think I need some more sensors and fancier code smiley
Netherlands
Something like this?
Rob Tillaart
Shannon Member
Lua rocks!
Exactly like that. smiley
Pages: [1] 2 3 ... 5   Go Up
