Loading...
Pages: [1]   Go Down
Author Topic: continuous servo, low speed more power?  (Read 560 times)
Offline Offline
Jr. Member
View Profile
Hi there:
I am measuring the power requirements of a continuous servo. When it is running at full speed the power requirement is small... however, when I set the speed to a low value, it eats 0.2 A!
Can anybody explain me why this happens? it seems that running at high speed would need more power.
Thanks in advance.
Logged
Offline Offline
Jr. Member
View Profile
Perhaps the reason is that low speed for this servos means running a bit, micro stop, running, micro stop...etc..
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
Amperage is based on how much torque the servo is providing and that is the most likely reason, especially given the high gearing in the servo which is a major use of the available power. Beyond that, the FETs in the servo will run less efficiently when at slower speeds; does it seem to get warmer when run slowly?
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Are you sure of this?
Do you know what the mechanism of this is?
I can't think why this should be.
As to the original question, it depends on the internal circuitry of the servo. However a DC motor takes more current when it it stalled than when it is running, and more when it is running slowly than quickly. This is because at stop or slow speed the coil resistance is the main factor controlling the current. When a motor is running the alternating current in the coil is limited by the inductive reactance slowing down the rise time in the coil. It changes direction before the full DC current can flow.
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
Quote
Why wouldn't you expect the FETs to run hotter (less efficiently) under the PWM or linear mode that would be required for the slower speed?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
Check the below on the back emf a motor produces when spinng fast that will act to reduce the foward current flow thru the motor.
http://en.wikipedia.org/wiki/Counter-electromotive_force
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Brattain Member
View Profile
WWW
Quote
Why wouldn't you expect the FETs to run hotter ..... under the PWM
Because:-
1) when the FET / motor is off it should be generating no heat because there is no current through it.
2) when the FET / motor is on it will be generating heat because of the current flowing through the on resistance of the FET.
3) When the FET is being turned on / off at say a 50% duty cycle then the heat situation alternates between 1) and 2) and so it runs cooler than 2).
Quote
Why wouldn't you expect the FETs to run hotter (less efficiently) under ...... linear mode
Now here you are making a definition of less efficiently that is not valid. In the linear mode it is designed to burn off the excess power and that is what it is doing very efficiently. There is no change in efficiency of the FET, the lack of efficiency is due to the design decision to have the FET burn off excess power.
Logged
Pages: [1]   Go Up
Print
Jump to:
