Topic: Reading Camera Data (Read 2666 times) previous topic - next topic
joppuh123
I would like to use the arduino with a sd reader to read out a sd card that is still in a digital camera
Any body who tried that?
johnwasser
Does the camera act as a USB mass storage device when connected to a USB host?  If so a USB Host shield might allow the Arduino to read the camera contents without taking the SD card out of the camera.
What are you trying to accomplish?
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
joppuh123
I have a arduino with a ethernet shield and the thing im trying to do is taking a photo with the camera (by powering the shutter button with the arduino) and then stream the photo that got stored on the sd card trough a web server like the example on the internet
PaulS
Quote
If you said something about the camera in question, perhaps more meaningful answers could be provided.
At first glance, though, I'd say that it was very unlikely that the camera provides an easy to use way to read the SD card while it is still in the camera.
joppuh123
Its not about the camera I want to read the sdcard simultaneously by 2 devices
So the camera has an sd card and then I will wire the sd card to the arduino so 1 sd card 2 devices is is possible? (Like splitting the sd)
PaulS
Quote
How do you propose to physically do this? Are you planning to solder wires to the SD card? After doing this, will it still fit in the camera?
joppuh123
I know you have a Sd to Microsd converter and you get a ribonwire so you can solder
http://www.dealextreme.com/p/sd-to-microsd-transflash-card-converter-module-27001
So it will fit but I dont know if it will work
Grumpy_Mike
Allowing any device, in this case an SD card, to be read by two machines requires that both machines know about it and make hardware provisions for it. That is allow the interface lines to enter a tri-state. In your case this is not possible because you have no way of modifying the cameras's circuitry.
If you want to hack into that module you can isolate the SD card with tri-state buffers from the camera and attach the arduino to it with tri-state buffers. But this is a tricky soldering job and would require a custom PCB.
joppuh123
And no way off syncing 2 sd cards or something like that?
Grumpy_Mike
I haven't a clue as to what that means.
joppuh123
Is there a way to sync 2 sd cards
PaulS
Quote
Start writing some software to read both cards. Decide which file on each card is more up to date, and write that file to the other card.
Grumpy_Mike
Synchronising is not some low level function, it involves reading files and the meta data and deleting some files and copying files over. You still need independent access to both SD cards. So I don't understand why you think it is an option.
