Topic: String over serial and writing byte-by-byte to 1602 (Read 2376 times) previous topic - next topic
willmp
Dec 12, 2011, 01:30 pm Last Edit: Dec 13, 2011, 09:42 pm by willmp Reason: 1
I'm pretty new to Arduino and not the strongest of programmers. As a starter project I wanted a get my Twitter mentions over USB serial and displayed on a 1602 LCD as if they were being typed, line by line.
I've set up the circuit and written some code. It's all working nicely. Well, apart from that at present it will only display 63 bytes of data correctly and one incorrect byte as the 64th. Lowering the baud speed of the serial comms increases this numbers, as does removing the delay in which data is written to screen in the while loop (where Serial.read() is used).
I've done some experiments with just having the board read serial to a string and then rewrite the string back out and even then I can't get the required 140 characters.
Here's the code:
Quote
//TYPING TWITTER SKETCH BY WILL LUTON
#include <LiquidCrystal.h>
LiquidCrystal LCD(12, 11, 5, 4, 3, 2);
int randMin = 50; // minimum wait for next character
int randMax = 250; // maximum wait for next character
int endDelay = 3000; // wait once characters are displayed
int startDelay = 50;
int messageLoop = 0;
int charNum = 0;
String message = "Waiting for serial input..."; // Initial message
char messageOutput[]= "";
void setup(){
 LCD.begin(16,2); // set up the LCD's number of columns and rows
 LCD.blink(); // sets blinking cursor
 // for loop writes message to screen
 for (int i = 0; i < message.length(); i++) {
   if (i==15){
     LCD.setCursor(0,2);
    delay(startDelay); // Wait for between min and max (simulates human type)
    LCD.write(message); // write i index of string message
 Serial.begin(9600); // initialize the serial communications
void loop(){
 // when characters arrive over the serial port...
 if (Serial.available()) {
   // wait a bit for the entire message to arrive
   delay(100);
   //Clear LCD for new message
   LCD.clear();
   Serial.println("New input");
   // Resets message character length
   messageLoop=0;
   charNum=0;
   // read all the available characters
   while (Serial.available() > 0) {
     // Debug - echo serial back
     charNum++;
     Serial.write(Serial.peek());
     Serial.print(" - ");
     Serial.print(charNum);
     Serial.println("");
     // display each character to the LCD
     LCD.write(Serial.read());
     // Check if character is over 16 then move to next line
     if (messageLoop==15){
       LCD.setCursor(0,2);
     // Check if character is over 32 then clear
      else if (messageLoop==31){
       LCD.clear();
       messageLoop=0;
     // Increments character
     messageLoop++;
     delay(random(randMin, randMax));
And here's a what serial monitor looks like when running the sketch using a 140 byte lorem ispum:
Quote
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Nullam dolor turpis, iaculis in posuere sit amet, feugiat a odio. Vestibulum metus.
Any ideas on what could be causing this? My first thoughts were how long the data is held in buffer, so they're wiped before it can be fully read. But like I say: I'm a total n00b ;)
Other than that, loving Arduino.
PaulS
Code: [Select]
This declares an array, called messageOutput, and makes the compiler determine the size. The compiler does this by counting the number of initializers present. How many are there? How big is the array?
Code: [Select]
    delay(100);
What is sending the data to the Arduino? Twiddling your thumbs hoping that all the data will have arrived while you were doing nothing is a recipe for disaster.
Quote
The buffer is 128 bytes. If you send 140, you may be overflowing the buffer with all the twiddling that you do.
wildbill
Data read from the serial port is buffered. I think the size of that buffer varies by Arduino type, for an Uno at least, it is 128 bytes. When you send ~140 bytes of Lorum ipsum in one go, you're going to overflow that buffer and characters will get lost. Feels like your buffer size is 64.
Happily, serial communications are very slow, so as long as you can read data out more quickly than it comes in, you won't drop anything. The delays in loop make this unlikely, get rid of them.
If you're using a version of the Arduino software earlier than 1.0, Serial.print is not buffered, it blocks, meaning that it will send character by character, waiting for the UART to become free. Your print statements therefore have the ability to slow down your sketch to the point where incoming text may overflow. If getting rid of the delays doesn't solve your problem, consider reading the serial data into your own  buffer and do the prints after you have received the data.
willmp
So I wrote this sketch:
Quote
char inData[140]; // Allocate some space for the string
char inChar; // Where to store the character read
byte index = 0; // Index into array; where to store the character
byte writeOut = 0; // when to write out
void setup(){
  LCD.write("Waiting...");
  if(Serial.available()) // Read to char if data is available
    delay(100); // Wait for data to arrive
    while (Serial.available()){
    inChar = Serial.read(); // Read a character
    inData[index] = inChar; // Store it
    index++; // Increment where to write next
    inData[index] = '\0'; // Null terminate the string
    writeOut=1;
  index=0;
  while(writeOut==1){
    LCD.clear(); // Clear the LCD for the message
    Serial.println("[BEGIN]");
    Serial.write(inData);
    Serial.println("[END]");
    writeOut=0;
And I now get this output:
Quote
[BEGIN]
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Nullam[END]
[BEGIN]
sit amet, feugiat a odio. Vestibulum metus. [END]
So it seems to read the buffer to string (first 62 bytes). Then print to serial. The next 34 bytes are lost. The rest of the buffer (44 bytes) is then read over the same string and printed.
Why is it not all read in that string?
AWOL
How many characters do you receive during your "delay (100);"?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
cmiyc
Note, you made your inChar[] array 140 characters.  However, you are always appending a null character.  So if you do receive 140 characters, you are writing past the end of your array.
Here's a suggestion on how I would approach this.  The amount of time it takes to receive a full tweet over serial is relatively short.  So why not receive the entire thing before you start trying to write it out to the LCD?  You'll notice I don't do a "if serial is available" because there is no need.  As long as there are characters available put them into a buffer, UNTIL an end of line delimiter is received.
In this case I am using a newline.  To test in the serial monitor make sure you turn on the "newline" in the lower right-hand corner drop down.
Code: [Select]
char inData[141]; // Allocate some space for the string PLUS a character for \0
int index = 0; // Index into array; where to store the character
void setup(){
  while(Serial.available()>0) // fill the butter
    char incomingCharacter = Serial.read();
    if ((incomingCharacter == '\n') || (index >= 140))   {   // you need SOME kind of marker you reached the end (turn this on in the monitor)
      writeOut=1;   // don't "write out" until a full tweet is received
      writeOut=0;
      inData[index++] = incomingCharacter;
    //  inData[index] = '\0';
  if (writeOut==1) {   // buffer is full, now write it out.
    Serial.println(inData);
    writeOut=0;
    index=0;
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
willmp
Thanks loads James!
Have now written this and appears to be working (not tested with less than 140 chars yet):
Code: [Select]
#include <LiquidCrystal.h> // include LCD lib
LiquidCrystal LCD(12, 11, 5, 4, 3, 2); // defines LCD
char tweet[141]; // Allocate some space for the string PLUS a character for \0
int typeDelay = 80; // how long to wait between each char being displayed on LCD
int endLineDelay = 1500;
String startMessage = "Waiting for serial input...";
void setup(){
  for (int i = 0; i < startMessage.length(); i++) {
    if (i==15){
      LCD.setCursor(0,2);
     LCD.write(startMessage[i]); // write i index of string message
  while(Serial.available()>0) // fill the buffer
      writeOut=0;
      tweet[index++] = incomingCharacter;
  writeOut = 0;
  index = 0;
  LCD.clear(); //clears any previous message and resets cursor to home
  messageLoop = 0; // resets message loop counter
  for (index = 0; index < 140; index++) {
         LCD.setCursor(0,2);
        }else if (messageLoop==31){
          delay (endLineDelay); // wait so message is readable
          LCD.clear(); // clear the screen and reset cursor to home
          messageLoop = 0;
    delay(typeDelay);
    LCD.write(tweet[index]); //write character to the LCD
    messageLoop++; //increase messageLoop by 1
GoForSmoke
Why do you bother playing "fill the buffer" at all?
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
cmiyc
Since we know the maximum length of a message is more than 128 bytes, it would make sense to empty the serial buffer as quickly as possible to ensure nothing is lost.
GoForSmoke
That's right. But why the *more than 1 character* buffer? What's the need?
around and around;
If character available
  get the character
  if character printable
    print the character
    evaluate the character and do what's appropriate
This whole "must buffer the line" mentality is usually just a habit from top-down type PC programming.
Occasionally it is needed but more often it is not.
PaulS
Quote
Did you read what OP is trying to do. OP wants to get the whole message, and echo it out slowly, to emulate someone typing. Why is not explained.
GoForSmoke
I must have had a mental filter on there.
PaulS
Quote
No problem. Been there, done that. Got the scars to prove it.
willmp
Okay. So spent this evening making this so it works with longer strings, not just tweets, putting the LCD bit in to its own function (writeToLCD()) and commenting.
I've also changed the name of the topic so it's easier to find for people. I hope it's of help to others who had the same problem.
Code: [Select]
// TYPING SERIAL SKETCH BY WILL LUTON
// MAKE SURE "NEWLINE" IS TURNED ON IN SERIAL MONITOR
#include <LiquidCrystal.h>                                   // include LCD library
char serialString [513];                                     // the string for the incoming serial message - maximum of 512 bytes, plus a terminating null
int i=0;                                                     // the index for serialString
int writeOut = 0;                                            // states if or not a full string is recieved and ready to be written to LCD
void setup(){
void loop(){
    if (incomingCharacter == '\n')  {                        // when a newline is recieved or the string hits 140 chars it's the end of the message (turn this on in the monitor)
      writeOut=1;                                            // now message is recieved write it to the LCD
      serialString[i] = '\0';                                // nullifier that signals the end of the string, so character beyond the current index are erased
      i = 0;                                                 // index for the string is reset
    else {
      writeOut=0;                                           // message is not fully recieved so don't write it
      serialString[i++] = incomingCharacter;                // add char to string and increment the index
  if (writeOut==1){                                         // if a message is stored in the string
  writeToLCD(LCD, serialString, 80, 1500);                  // send message to custom function writeToLCD so as it can be displayed on the LCD
  delay(1500);                                              // wait user has time to read what is on screen
  LCD.clear();                                              // clear screen
void writeToLCD(LiquidCrystal nameOfLCD, String message, int typeDelay, int fullScreenDelay){// this function writes characters to an LCD as if it had been typed. Waits when screen is full so is readable
  nameOfLCD.clear();                                        // clear the LCD ready for message
  int charsDisplayed = 0;                                   // defines new variable that counts char already written to the LCD
      if (charsDisplayed==16){
        nameOfLCD.setCursor(0,2);                           // if first line full, move cursor to second line
      else if (charsDisplayed==32){
        delay (fullScreenDelay);                            // wait so message is readable
        nameOfLCD.clear();                                  // if second line is full, clear the screen and reset cursor to home
        charsDisplayed = 0;                                 // reset numbers chars on screen
      nameOfLCD.write(message[i]);                          // write char in string with index of i to the LCD
      charsDisplayed++;                                     // increase charsDisplayed by 1 as a char is now on screen
      delay(typeDelay);                                     // delay between before next char is typed
  return;                                                   // return to where function was called from
