Global Moderator
Dallas
Online
Shannon Member
« Reply #15 on: February 03, 2012, 01:48:06 am » |
In that case, I misunderstood the purpose of the cheat-sheet. I assumed it was meant to document pin mappings for Arduino compatible cores.
Logged
Tokyo, Japan
Offline
Newbie
« Reply #16 on: February 03, 2012, 02:57:08 am » |
You didn't misunderstand: The new version of the cheat sheet was meant to do exactly that: For example, physical pin 11 on the ATTiny2313/4313 is PD6 (when programming in low-level avr-gcc) and is assigned to Arduino pin number 8: This is written as PD6/D8 in the cheat sheet.
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #17 on: February 03, 2012, 03:08:42 am » |
In that case, PB3 needs to be excluded for the X5 family. As far as I know, no Arduino compatible cores make use of inverted PWM outputs.
Logged
Tokyo, Japan
Offline
Newbie
« Reply #18 on: February 03, 2012, 06:37:34 am » |
You won't be able to use the inverted PWM for Arduino, but the sheet covers both Arduino pin numbers and normal port numbers (that's why it says D3/PB3). That said, there should be a note saying that PB3 is a "special" PWM pin.
Logged
0
Offline
Newbie
Arduino rocks
« Reply #19 on: February 05, 2012, 04:43:47 pm » |
Hey Karl_B thanks for this cheat sheet, looks great. Wonder if you could also include attiny84 ?
Logged
Tokyo, Japan
Offline
Newbie
« Reply #20 on: February 05, 2012, 07:34:25 pm » |
Thanks kermit, attiny84 and attiny87/167 are on our TODO list.
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #22 on: February 06, 2012, 10:34:37 pm » |
Nice. Thank you.
I have a suggestion: use ", " (comma space) instead of "/" (slash) to separate the labels. It's a little difficult to locate a pin from its function (like MISO).
Logged
Tokyo, Japan
Offline
Newbie
« Reply #23 on: February 06, 2012, 10:53:14 pm » |
Thanks for the suggestion, we'll try it out and see how it looks
Logged
0
Offline
Full Member
Arduino rocks
« Reply #24 on: March 06, 2012, 03:53:05 pm » |
Great post. do you guys know what is the analog input pin numbers on the 2313 been reading the datasheet and can not find it.
thanks
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #25 on: March 06, 2012, 04:45:37 pm » |
For the analog comparator or the analog-to-digital converter?
Logged
0
Offline
Full Member
Arduino rocks
« Reply #26 on: March 06, 2012, 04:55:07 pm » |
more like Analog input/ Sensor input
Logged
0
Offline
Full Member
Arduino rocks
« Reply #27 on: March 06, 2012, 05:26:50 pm » |
I guess the analog is the PB0/AIN0/D9 I have been trying to get the analog input to work with a sensor how is set this pin to be a alaog input see sketch ///////////////////
int sensPin=PB0; // analog input for 2313 int sensVal=0; // value
int ledPin = 1; // The pin number of the LED int ledPin7 = 7;
//////SETUP////////
void setup() { pinMode( ledPin, OUTPUT ); // Sets the led pin to an output mode pinMode( ledPin7, OUTPUT ); // pinMode( sensPin, INPUT ); // Serial.begin(57600); //set Serial Data flow / debug/ read }
///LOOP///////////
void loop() { digitalWrite(ledPin7, HIGH); sensVal = analogRead(sensPin); // READS sensor,
if( sensVal > 350 ) // object is close to sensor?? {
digitalWrite( ledPin, HIGH ); //Turn LED pin on } if( sensVal < 450 ) {
digitalWrite( ledPin, LOW); // } }
Moderator edit: [code] [/code] tags added.
« Last Edit: March 06, 2012, 05:40:45 pm by Coding Badly »
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #28 on: March 06, 2012, 05:41:39 pm » |
more like Analog input/ Sensor input An analog-to-digital converter. The 2313 does not have one.
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #29 on: March 06, 2012, 05:44:01 pm » |
I guess the analog is the PB0/AIN0/D9 That is one of the two inputs to the analog comparator. sensVal = analogRead(sensPin); // READS sensor, If you are using this core... http://code.google.com/p/arduino-tiny/...zero is always returned.
Logged
