Topic: RFID Charlie Bear Project Software Snag from MAKEvol28 (Read 2586 times) previous topic - next topic
unkljd991
So I've tried to get help from the adafruit forums but none of the suggestions have helped. Anything you can come up with to help will be greatly appreciated by three very happy kids (hopefully) receiving this functioning project tomorrow.
If you're unfamiliar with the project listed in the subject, http://makeprojects.com/Project/Charlie-s-RFID-Teddy-Bear/1411/, meet my nemesis. Currently he has taken the form of an oversized black lab retriever with stuffing pouring out of his poorly unstitched sides and has a messy necklace of dangling wires, boards, and speakers. However, as far as I can tell, the problem I'm facing is not hardware (and yes, I bought everything on that parts list directly from MakerShed and Jameco- no dodgy 3rd party stuff)...
Last night I successfully got sound in the form of the "daphc.pde" sketch. My RFID reader prints the tags magnificently. However, trying to unite sound and RFID seem to be a bit beyond my grasp. Below is the code for "bear:"
Code: [Select]
// An interactive bear for Charlie -- RFID triggered sound responses
#include <FatReader.h>
#include <SdReader.h>
#include "WaveHC.h"
#include "WaveUtil.h"
SdReader memcard;
FatVolume vol;
FatReader root;
FatReader file;
WaveHC wave;
#define ENABLE 7      // Set the pin number for enabling the RFID reader. The Audio Shield uses pins 2-5.
#define NUMTAGS 22
int  val = 0;
char code[10];
int bytesread = 0;
char knowntags[NUMTAGS][11] = {"2100DFB002", "2100E0B6ED", "2100DFF660", "2100DFD586", "2100DFB1E5", "2100E0CBAA", "2100E07B21", "2100E0B9D6", "2100D82331", "2100DFA060", "2100DFBC77", "2100DFA69A", "2100D7EFF7", "2100DFE251", "2100E02F09", "2100DFBF83", "2100DFD9EA", "2100E0ABA6", "2100DFDFC4", "2100DFF0DF", "36005B7B50", "36005B7C05"};
char soundfiles[NUMTAGS][9] = {"1000.WAV", "1001.WAV", "1002.WAV", "1003.WAV", "1004.WAV", "1005.WAV", "1006.WAV", "1007.WAV", "1008.WAV", "1009.WAV", "1010.WAV", "1011.WAV", "1012.WAV", "1013.WAV", "1014.WAV", "1015.WAV", "1016.WAV", "1017.WAV", "1018.WAV", "1019.WAV", "1020.WAV", "1021.WAV"};
char filename[1][13];
  //////// Set up RFID reader to collect tag information /////////////////////
  Serial.begin(2400);         // RFID reader SOUT pin connected to Serial RX pin at 2400bps
  pinMode(ENABLE,OUTPUT);     // Set digital pin 7 as OUTPUT to connect it to the RFID /ENABLE pin
  digitalWrite(ENABLE, LOW);  // Activate the RFID reader
  //////// Set the pins to output for driving the Audio Shield
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  ////////// Set up the Audio Shield by initializing the memory card for reading ////////
  if (!memcard.init()) {
    // If something went wrong sdErrorCheck prints out the error check
    putstring_nl("Card init. failed!");
    cardErrorCheck();
    return;
  //This will optimize the reading of the memory card -- remove it if it times out
  memcard.partialBlockRead(true);
  // Find a FAT formatted partition by looking in teh first five slots. Remember your memory card should be FAT16 or FAT32 formatted
  uint8_t partition;
  for (partition = 0; partition < 5; partition++) {
    if (vol.init(memcard, partition))
  if (partition == 5)
    putstring_nl("No valid FAT partition");
    cardErrorCheck();
    while(1); // This is a point of no return. Format your memory card properly and try again.
  // Open the root directory for reading the files
  if (!root.openRoot(vol))
    putstring_nl("Can't open root directory");
    while(1); // Something went wrong here so investigate the file system on your memory card.
  // If you got this far then the card is ready to read
  putstring_nl("Ready to go");
// If we find an error, check what the error is and show it on the serial terminal
void cardErrorCheck(void)
  if(!memcard.errorCode()) return;
  putstring("\n\rSD I/O error:");
  Serial.print(memcard.errorCode());
  putstring(", ");
  Serial.print(memcard.errorData());
  while(1); // Stick here if there is an error
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10) {              // if 10 digit read is complete
        playsound(code);
        Serial.print("TAG code is: ");   // possibly a good TAG
        Serial.println(code);            // print the TAG code
        Serial.flush();                  // Flush the serial buffer before trying to read a new code
      bytesread = 0;
void playsound(char codetoplay[]) {
  for(int i = 0; i<8; i++) {    // Make a filename from the first 8 characters of the RFID tag number
    filename[0][i]=codetoplay[i];
  filename[0][8]='.';
  filename[0][9]='w';
  filename[0][10]='a';
  filename[0][11]='v';
  silence(); //shut down anything that is currently playing and close that file
  playfile(filename[0]);
void playfile(char *name) {
  if (!file.open(root, name)) {
      putstring_nl("Couldn't open file");
      return;
   if (!wave.create(file)) {
     putstring_nl("Not a valid WAV");
     return;
  wave.play();
void silence() {
  if(wave.isplaying) {
    wave.stop();
So what does Serial Monitor say when I put a RFID tag near the reader?
Code: [Select]
Ready to go
Couldn't open file
TAG code is: 3D001ED8B7
Near as I can tell, my primary issue here is confusion in the CharlieBear sketch where there's a software disconnect between reading the RFID tag, truncating the first 8 characters, and summoning the corresponding .wav file. I've run tests (dapHC, for those familiar) and have yielded my audio file on loop, playing as expected. I don't think it's a hardware issue.
Any ideas?
Grumpy_Mike
It looks like you are not getting the file name right. I would add some serial print debug lines to see the name of the file you are trying to open. Then double check that this file is actually on the SD card and is a valid file.
PaulS
You are passing the RFID tag to the playsound() function. That function is then overwriting the characters in positions 8 to 11, but not appending a NULL.
So, when you scan the tag 3D001ED8B7, the file to be played becomes 3D001ED8.wav. Does that file really exist?
Or, are you supposed to be looking that tag up in the knowntags array, and playing the corresponding file from the soundfiles array?
unkljd991
First of all, thank you for the speedy responses!
Bear with me here, this is my first major project. I've seen this as common advice but I don't know the first thing about where to start. What exactly should I put and here?
The physical file exists on the root of the SD card in the waveShield, yes. In terms of the code of the sketch, the project instructions mention no where that the builder should alter the code to get the project to function. That said, they provide very little in the way of troubleshooting as it is. Should I add the known tag "3D001ED8B7" and sound file "3D001ED8.wav" to  the sketch and remove the ones that came with it?
carlito
I've read the code and I'm certain that you don't need those arrays defined at the top
ie.
Code: [Select]
It looks like code that was never used in the final product.
I'm not 100% sure if this'll work, but can you try adding this line
Code: [Select]
Serial.print(name);
right before
Code: [Select]
end result should be
Code: [Select]
      Serial.print(name);
      return;
     return;
  wave.play();
Then post what the result is?
carlito
Also, this should fix it as well (taking into account what PaulS said)
change the playsound function to
Code: [Select]
  filename[0][8]='.';
  filename[0][9]='w';
  [b]filename[0][12]='0';[/b]
"should" fix it
unkljd991
Code: [Select]
  filename[0][8]='.';
  filename[0][9]='w';
"should" fix it
I made the changes you suggested but before I could upload it, I verified it and this came up. Do you know what I need to do to fix it?
carlito
unkljd991
Thanks- that was silly of me! The code compiled beautifully afterwards.
However, not all was swell in the serial monitor when I passed the corresponding tag infront of the reader:
It still won't open the file!
carlito
#9
Dec 13, 2011, 09:19 pm Last Edit: Dec 13, 2011, 09:21 pm by carlito Reason: 1
ok, let's change just this line to:
Code: [Select]
[b]filename[0][12]='\0';[/b]
and try running again.
Also, does this file exist on the root of your sd card?
3D001ED8.wav ??
exactly as it is written there (case sensitive)?
EDIT:
You could also try removing that line altogether as it seems to add the null anyway...
ie. remove this line from the code
Code: [Select]
or try both..i dunno :)
PaulS
Code: [Select]
is wrong. It should be:
Code: [Select]
Make sure that you changed the size of filename to allow it to hold 13 values.
There is a function to list the names of the files on the card. Add a call to that function, in setup(), and show us what names really exist.
unkljd991
Code: [Select]
3D001ED8.wav ??
EDIT:
Code: [Select]
I tried both versions of that line and neither worked. "3D001ED8.wav" exists on the root of the SD card. (The dapHC sketch prints the name on the Serial Monitor when executed.)
"Make sure that you changed the size of filename to allow it to hold 13 values.
There is a function to list the names of the files on the card. Add a call to that function, in setup(), and show us what names really exist."
^^ A bit of google researching has yielded no answers to what such function you've mentioned- plenty of sketches though. Did you have one in mind? (I'm sorry, I'm terribly new to all this.)
carlito
Can you post the output that you are receiving now please?
Again, have you made sure that the files on the sd card are EXACTLY what is displayed in the output? making sure to check for case-sensitivity?
unkljd991
Absolutely!
Output:
Unless I'm missing something (and I very could be), it's identical- even casing:
And, just for kicks, here's the most recent iteration of the code:
Code: [Select]
#include "WaveHC.h"
SdReader memcard;
FatVolume vol;
FatReader root;
FatReader file;
WaveHC wave;
#define NUMTAGS 22
int  val = 0;
char code[10];
int bytesread = 0;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
    cardErrorCheck();
    return;
  uint8_t partition;
  if (partition == 5)
    cardErrorCheck();
  putstring(", ");
      bytesread = 0;
        playsound(code);
      bytesread = 0;
  filename[0][8]='.';
  filename[0][9]='w';
      Serial.print(name);
      return;
     return;
  wave.play();
void silence() {
    wave.stop();
carlito
#14
Dec 14, 2011, 01:57 am Last Edit: Dec 14, 2011, 02:17 am by carlito Reason: 1
Your file shows an I where it should be a 1
ie. it should read 3D001ED887.wav instead of
3D00IED887.wav
Please change the I to a 1 and try again :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
