I recently started prototyping a new system with a Mega 2560. This is my 4th arduino system, and my 1st one using a Mega.
I have a simple program that I have successfully loaded on the Mega (it toggles some digital pins and sends some serial messages). Something's changed, and now I can't upload new images to the board. When I try to upload, I get the following error messages:
Binary sketch size: 4560 bytes (of a 258048 byte maximum)
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x10
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500v2_command(): failed miserably to execute command 0x11
avrdude: stk500v2_disable(): failed to leave programming mode
I'm trying to track down the source of the problem. Here's what I know:
1) The Green "on" light is on when the board is powered up.
2) The "L" light flashes when I power up the board (indicating that the bootloader is present).
3) The code that I loaded on the board still runs (I can see the digital pins toggling).
4) I have the arduino IDE pointing to the correct COM port and setup for the Mega board
5) I have tried two different PCs
6) I have disconnected all of the external circuits that were attached to the Mega
Does anyone have any debug ideas? I have a scope, so I can capture an image of the serial lines during upload if that would help.
