« Reply #30 on: May 04, 2012, 08:58:24 pm » |
I was having the same issue.
But end up I realized that I have place the reset switch A_RST_M at the wrong position. Correcting the switch position and my Arduino is now working well.
London
Arduino has it all
« Reply #31 on: June 04, 2012, 02:18:59 pm » |
I just joined in to say that I have this same problem. This ruined at least three weekends for me. Instead of working on new projects, I am banging my head into the wall, trying everything to resolve this.
I have Mega 2560, R2l, on Win XP SP3. It constantly either hangs with timeout, or sometimes it tells me that COM port is taken by another application. I always either get timeout or port locked by other applicaiton.
So many Mega 2560 owners are having problems with this, that developers should definitely check this one out.
Europe
« Reply #32 on: June 15, 2012, 11:09:16 am » |
I tottaly agree. But I can't expect support because my sparkfun mega isn't "official"...
« Last Edit: June 15, 2012, 01:58:20 pm by xvjeko »
Forum Administrator
Cambridge, MA
« Reply #33 on: June 16, 2012, 07:00:19 pm » |
For those of you having trouble, can you try changing "stk500v2" to "wiring" for the Mega 2560 in your boards.txt file (in the hardware/arduino sub-directory of your Arduino application directory)? That should tell avrdude to do an auto-reset of the board before the upload (in addition to the one done by the IDE itself), which might help. See: http://code.google.com/p/arduino/issues/detail?id=806 for more information and updates.
« Reply #34 on: June 17, 2012, 11:13:12 am » |
Just wanted to add my voice to the chorus on this issue. I'm using a Mega 2560 R2 with Arduino 1.0.1 running on Mac OSX 10.6.8. Changing "stk500v2" to "wiring" has made no discernible difference. As a few users on this thread and others have found, it has been a sudden behaviour change where I can't think of anything I've changed... EDIT: to add a couple more details: - The sketch that is currently loaded still functions perfectly.
- (non-)behaviour is seemingly identical in Arduino IDE 0022, 0023, and 1.01.
« Last Edit: June 17, 2012, 12:25:26 pm by Josephiah »
Europe
« Reply #35 on: June 17, 2012, 11:17:07 am » |
+1
Forum Administrator
Cambridge, MA
« Reply #36 on: June 17, 2012, 12:41:48 pm » |
It sounds like there may be different things going on here, since some of you are seeing different symptoms / behaviors.
Josephiah and DROBNJAK, can you post the verbose output of an upload attempt? Have you tried a different USB cable? Are you going through a USB hub (if so, try connecting the board straight to the computer)?
Europe
« Reply #37 on: June 17, 2012, 02:21:27 pm » |
if it helps, it doesn't work for me neither. Tried 2 pc-s and 2 cables. It all worked before (sometimes i didnt saw progress bar so i had to reconnect mega and it worked) but now i am stuck at 95% progress bar, and smtimes my L is on for the whole time, and sometimes not... cheers
« Reply #38 on: June 17, 2012, 04:16:01 pm » |
Hi Mellis, thanks for your help. Changing USB cable doesn't seem to make a difference, and it's plugged into the same USB port on my mac as it always has been. The results also appear to be the same whether I have the mega on its own with nothing else plugged in, or with a shield attached (I'm currently using it for a monome-like project). Sometimes I get this: Binary sketch size: 1,624 bytes (of a 258,048 byte maximum) /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cwiring -P/dev/tty.usbmodem-chr-001 -b115200 -D -Uflash:w:/var/folders/Vd/VdFeGvFZG4Gc-qfuGxx6pE+++TI/-Tmp-/build893675159181048838.tmp/Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf" User configuration file is "/Users/Jo/.avrduderc" User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodem-chr-001 Using Programmer : wiring Overriding Baud Rate : 115200 avrdude: wiring_open(): releasing DTR/RTS avrdude: wiring_open(): asserting DTR/RTS avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14] avrdude: Recv: . [1b] avrdude: Recv: . [0e] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14] avrdude: Recv: . [1b] avrdude: Recv: . [0e] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14] avrdude: Recv: . [1b] avrdude: Recv: . [01] avrdude: Recv: . [00] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17] avrdude: Recv: . [1b] avrdude: Recv: . [0e] avrdude: Recv: . [01] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
« Reply #39 on: June 17, 2012, 04:16:35 pm » |
And sometimes this: Binary sketch size: 1,624 bytes (of a 258,048 byte maximum) /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cwiring -P/dev/tty.usbmodem-chr-001 -b115200 -D -Uflash:w:/var/folders/Vd/VdFeGvFZG4Gc-qfuGxx6pE+++TI/-Tmp-/build893675159181048838.tmp/Blink.cpp.hex:i
Using Port : /dev/tty.usbmodem-chr-001 Using Programmer : wiring Overriding Baud Rate : 115200 avrdude: wiring_open(): releasing DTR/RTS avrdude: wiring_open(): asserting DTR/RTS avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14] avrdude: Recv: . [1b] avrdude: Recv: . [01] avrdude: Recv: . [00] avrdude: Recv: . [0b] avrdude: Recv: . [0e] avrdude: Recv: . [01] avrdude: Recv: . [00] avrdude: Recv: . [08] avrdude: Recv: A [41] avrdude: Recv: V [56] avrdude: Recv: R [52] avrdude: Recv: I [49] avrdude: Recv: S [53] avrdude: Recv: P [50] avrdude: Recv: _ [5f] avrdude: Recv: 2 [32] avrdude: Recv: t [74] avrdude: stk500v2_getsync(): found AVRISP programmer AVR Part : ATMEGA2560 Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PA0 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail :
Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring Description : Wiring Programmer Model: AVRISP avrdude: Send: . [1b] . [02] . [00] . [02] . [0e] . [03] . [90] . [86] avrdude: Recv: . [1b] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_getsync(): timeout communicating with programmer avrdude: Send: . [1b] . [02] . [00] . [02] . [0e] . [03] . [90] . [86] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17] avrdude: ser_recv(): programmer is not responding avrdude: stk500v2_ReceiveMessage(): timeout avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17] avrdude: ser_recv(): read error: Device not configured (that last line from me unplugging the board.) Cheers, Jo
« Reply #40 on: June 18, 2012, 06:34:51 am » |
Anyone have a verified and working fix? I've had my Arduino for about 4 hours and just got hit with this (and I'm not using any !!! in my code, which was allegedly the cause of the issue). This has been going on for months now and I gotta be honest - I'm pretty frustrated that the (presumably bootloader) issue still seems to be unfixed.
I did put a string containing "!!!!!!!!" in my code. Deleted it but no luck, same timeout error. Uploaded the Blink example (think this resetted the memory or something) and uploaded my original code again and it works again. weird? or not?
« Reply #41 on: June 18, 2012, 09:59:50 am » |
I am having the same problem when trying to upload my program. Every time I try to upload it says 'time out' or 'time out communicating with programmer'. I have been reading through all the advices you guys gave, but I'm not that experienced with adjusting the code of the Arduino software, so I have no idea what to do.
« Reply #42 on: June 18, 2012, 01:48:28 pm » |
I have to report my findings with Arduino Mega 2560. I struggled hours with these "avrdude: stk500v2_ReceiveMessage(): timeout", "avrdude: ser_recv(): read error: Device not configured" error messages that started haunt me just when I was adding some new data to my program.
First I though that I had too much data (although I had only 18Kb). Removing the new data solved the issue. Then I started to look deeper in to the issue. Finally I managed to track this down to very weird root cause:
When ever a sequence of "0x21, 0x21, 0x21" is added to PROGMEM and this variable is referenced like: const unsigned char bug[3] PROGMEM = {0x21,0x21,0x21}; pgm_read_byte(&bug[0]); Uploading fails!!
If I change one of those 0x21s to something else, everything works like a charm again. This has to be some sequence that causes Arduino somehow to get stuck... Just unbelievable but true.
My setup is: Arduino 1.0.1 Arduino Mega 2560 (ok it is from DE...) AVRISP mkII (same happens with AVR ISP) Mac OS 10.6.8
So if you have weird upload problems, just check your code for this sequence...
« Reply #43 on: June 18, 2012, 01:51:04 pm » |
I am using Mac OS 10.6.8 too, but where can I change the program of the arduino software? On my windows pc I can find the boards.txt file, but in my mac I can't find it and I don't know how to change it.
Austin, TX
carpe diem
« Reply #44 on: June 18, 2012, 04:08:23 pm » |
aleffe, This is a known issue and is being addressed in a future 2560 bootloader. See here for details: http://code.google.com/p/arduino/issues/detail?id=392
