Topic: charging while using (Read 903 times) previous topic - next topic
ocean750
Hello all.
I need some help with a battery.
I would like to run my board from a battery. at the same time, I would like to charge it.
So that when the power is out my board will keep on working.
I don't mind what type pf batery I am using for now, I do very much need a diagram that will show how this is possible.
Thanks
Angela
Rokkit
#1
Dec 15, 2011, 07:34 pm Last Edit: Dec 15, 2011, 07:36 pm by Rokkit Reason: 1
Here's something to get you started, you may need to adjust it accordingly to work with the voltages you're using
"Every day is a good day, some are just gooder than others."   D. Fowler
MarkT
I guess the unstated issue is the rise in battery voltage during charging.  If the battery is 9V say and going into the Vin, its easy, just connect charger to battery.
If using 4x NiMH cells (about 5.3V) then over-charging might push the battery voltage too high for Vcc (5.5V is the maximum).  A constant-voltage charger set to 5.5V would be one solution.  That would work with either battery, charger or both connected which is nice.
ocean750
Thanks for the diagram!
I do have some questions.
The left part is understood, I am curios about the right side, from where Q1 is placed.
The purpose of the circuit is to activate the arduino board.
So how do I connect both powers so that when the power is down the battery will take over ?
Thanks
Angela
ocean750
Thanks for the input.
Let's say that I am using a 9V battery.
I can not connect the power supply to both board and battery directly.
Can you put your idea into a diagram ?
Thanks
Angela
Rokkit
Quote
Thanks
Angela
This circuit will do that automatically.
