Author Topic: Arduino1.0 and SoftwareSerial Library Example  (Read 1062 times)
Switzerland
with the Arduino 22 and NewSoftSerial Test from Mikal Hart.
I received from GPS Receiver the following information:
Goodnight moon!
$GPZDA,152444.00,14,12,2011,,*60
$GPGLL,4730.3739,N,00924.9473,E,152444.00,A,A*63
$GPZDA,152446.00,14,12,2011,,*62
$GPGLL,4730.3739,N,00924.9473,E,152446.00,A,A*61
with the new Arduino1.0 and SoftwareSerial Library Example
I lose characters by the $GPGLL sentence ???
Goodnight moon!
$GPZDA,152656.00,14,12,2011,,*61
$GPGLL,4730.3737,N,00924.9468,E,152656.00A$GPZDA,152658.00,14,12,2011,,*6F
$GPGLL,4730.3737,N,00924.9467,E,152658.00*$GPZDA,152700.00,14,12,2011,,*63
        ¦ missing comma , A,A 63 and "CR" "LF"
 Can someone help my ? I receive all 2 second first the $GPZDA after the $GPGLL sentence.
 Willy
Shannon Member
Can you try SoftwareSerial on 22 - that way you can tell if the difference is library-related or Arduino software version related...
[ I won't respond to messages, use the forum please ]
Switzerland
I 've  found on 22 -  the library "SoftwareSerial"  but not a Example program
My testprogram I could not compile
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,0);
  Serial.begin(57600);
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
void loop()    // run over and over again
    if (mySerial.available())
     Serial.print((char)mySerial.read());
Compiler Error 'class SoftwareSerial' has not nember named 'available'
Best regards Willy
Forum Administrator
Cambridge, MA
Weird, the SoftwareSerial library in Arduino 1.0 is the NewSoftSerial.  Can you post the whole program?
What if you install the NewSoftSerial library into Arduino 1.0, and try that?
Switzerland
The in the NewSoftSerial ibrary contained NewSoftSerialTest program  isn't compatible with Arduino 1.0.  I cannot compile it.
With this SoftwareSerial Library Example program in Arduino 1.0
  mySerial.println("Hello, world?");
    Serial.write(mySerial.read());
Best  regards Willy
Brooklyn, NY
looks like a baud rate problem. is it consistent?
the buffer is 64 bytes, you are receiving 150+.
What do you get when you buffer the overflow flag?
