Loading...
Pages: 1 [2] 3 4   Go Down
Author Topic: Weird glitchy stuff  (Read 1317 times)
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Ok, do you need to have a record of the values or are you just content to have them stored on the analogue output pin?
Logged
Offline Offline
Full Member
View Profile
I don't know, what would be the easiest?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Well it depends on if you want to use the values after you have set them. Or is this just a coding exercise?
Logged
Offline Offline
Full Member
View Profile
after i press the button, i want the current value of the led to remain.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Try this:-
Code:
int buttonInt = 2;
//Setup the LEDs
// LED outputs
 int blueLED = 4;
 int redLED = 0;
 int greenLED = 1;
 int nullLED = 16; // dummy does nothing on this processor attiny45
/* "volatile" is not necessary.  Remove it. */
int selectedLED = greenLED;
  pinMode (redLED, OUTPUT);
  pinMode (greenLED, OUTPUT);
  pinMode (blueLED, OUTPUT);
void fade()
  while ( true ) {
    for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
      analogWrite(selectedLED, fadeValue);
      delay(30);
      if ( digitalRead(buttonInt) ) return;
    for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
      delay(30);
  fade();
  delay(20); // debounce delay
  while(digitalRead(buttonInt)) { } // do nothing until button is released
  swap();
void swap()
  if (selectedLED == greenLED) { selectedLED = redLED; return;}
  if (selectedLED == redLED) { selectedLED = blueLED; return;}
  if (selectedLED == blueLED) { selectedLED = nullLED; return;}
  if (selectedLED == nullLED) { selectedLED = greenLED; return;}
Logged
Offline Offline
Full Member
View Profile
Now it does (almost) exactly the same as before:
-The green LED fades
-When i press the button, the green and red start fading alternately
-When i press the button again, red stays on but green and blue just blink (what appears to be) randomly.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Sounds like your button hardware is a bit faulty.
What happens when you hold the button down and keep it held, nothing should change until it is released.
Do a sketch just to read it and print out the value.
This sort of thing happens if the input is floating.
http://www.thebox.myzen.co.uk/Tutorial/Inputs.html
Also add this to the setup() function:-
Code:
  pinMode ( buttonInt, INPUT);
All pins are input by default but it might not be the case on your processor.
Logged
Offline Offline
Full Member
View Profile
Code:
Added
Code:
to the code and when i hold the button down, the green led stops fading. when i release the button, the green and red led start fading alternately again.
my setup: one side of the button connected to pin 2 and a 10K resistor that goes to ground and the other side connected to 5V.
What's wrong?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
And does that happen when you are touching none of the wires as well?
Replace:-
Code:
with
Code:
int selectedLED = redLED;
Now it should be that the behavior is the same, the red LED will be fine at first. If not then you have wired up the LEDs wrong.
But basically you have some sort of hardware fault. I think it is not wired up as you think it is.
Logged
Offline Offline
Full Member
View Profile
Quote
Quote
Nope. but on your site you are using 3K pulldown resistors, i'm using 10K. Does that matter?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Well I would not use pull down resistors at all. I would connect the button between input and ground and attach a pull up resistor of 10K.
Then you have to invert the logic inside the code by putting a ! in front of the digital read.
Did you do the experiment I asked you to do, putting the start to a different colour?
Logged
Offline Offline
Full Member
View Profile
Yep i did that.
I also changed the swap() to
Code:
void swap()
  if (selectedLED == redLED) { selectedLED = greenLED; return;}
  if (selectedLED == greenLED) { selectedLED = blueLED; return;}
  delay(100);
and now it kind of works but the green LED keeps blinking when it's supposed to be set..
Logged
Offline Offline
Full Member
View Profile
I'll try the pull-up resistor.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
The LED on the Uno (digital 2 on the ATtiny45; digital 13 on the Uno) is interfering.  Move the button to digital 3.
Do NOT try to access invalid pins.  The Tiny Core (like the Arduino Core) DOES NOT VALIDATE PIN NUMBERS...
Code:
static const int nullLED = 16;
pinMode (nullLED, OUTPUT);  // <--- Bad news.  Don't do this.
The following code works.  I used the internal pullup on the button pin; the button will have to be wired to ground the pin when pressed.  The debounce technique works but is crude.
Code:
//Setup the Button
// This is a constant and should be marked as such...
static const int buttonInt = 3; // 2;
//Setup the LEDs
// These are all constants and should be marked as such...
static const int blueLED = 4;
static const int redLED = 0;
static const int greenLED = 1;
/* These are not used and not necessary.  Remove them.
int blueValue = 0;
int greenValue = 0;
int redValue = 0;
int nullValue = 0;
//pinMode (nullLED, OUTPUT);
  pinMode (buttonInt, INPUT);
  digitalWrite (buttonInt, HIGH);
void swap()
  else if (selectedLED == redLED)
  else if (selectedLED == blueLED)
  delay(300);
void fade()
  if ( selectedLED == nullLED )
    while ( digitalRead(buttonInt) );
    while ( true ) {
        delay(30);
        if ( ! digitalRead(buttonInt) ) return;
        delay(30);
  fade();
  delay(30);
  while ( ! digitalRead(buttonInt) );
  swap();
Logged
Offline Offline
Full Member
View Profile
Quote
why?
Quote
Code:
Used the code and moved the button; now it just does exactly the same as 2 posts before:
-Green LED starts fading
-When i press the button the green and red LED start fading alternately
etc.
Logged
Pages: 1 [2] 3 4   Go Up
Print
Jump to:
