Topic: 'work in progress' - arduino driven plotter (Read 3932 times) previous topic - next topic
ole_kristensen
Sep 07, 2010, 07:45 pm Last Edit: Sep 07, 2010, 07:56 pm by ole_kristensen Reason: 1
[size=42][font=Arial]
work in progress[/font][/size]
[size=11][font=Arial]
http://3xw.ole.kristensen.name/works/work-in-progress/
[/font][/size]
[size=13]
[font=Arial]
this is a project that started two years ago
when i fell in love with an abandoned roland
dxy-1100 plotter. initially i hooked it up to
processing and explored some simple generative
drawing styles, until i decided to see if i could
make it doodle the same way i do.
when i finally got it to make the same lines and
curves i do myself, i made it ask for a very modest
salary for the drawings and got it exhibited
a few times here in copenhagen.
it had been hibernating for a year when peet from
black box gallery asked me if i would like to have
it exhibited in brunnhofer galerie in linz alongside
this years' ars electronica.
to make things more fun i decided to move
the software to an arduino, and made a
protoshield with a max323 driver, a button,
a blinkm led and an sd card for buffering data.
it's now doodling away in linz, so come by
and have a look if you're in town at this
there's a video too (will open on vimeo.com):
[/font]
[/size]
ole_kristensen
#1
Sep 08, 2010, 01:04 am Last Edit: Sep 08, 2010, 01:11 am by ole_kristensen Reason: 1
here is the skeleton of my plotting sketch, it takes care of not overrunning the plotter's 1024 byte buffer and detects disconnections and plotter errors.
user.h
Code: [Select]
enum pState {
 reset,
 waiting,
 plotting,
 buffering,
 noconnection,
 error
enum pWorld {
 plotter,
 text,
 drawing
void setState(pState state);
First Part of code (too long to fit one post)
Code: [Select]
#include "user.h"
#include <math.h>
#include <avr/pgmspace.h>  // for progmem stuff
#define DEBUG_enabled 0
#define buttonPin 8
#define ESC "\x1B"
#define cmdBufferSize 255
pState plotterState;
pState noConnectionReturnState;
pWorld plotterWorld;
byte errorCode = 0;
byte statusCode = 0;
int bufferCapacity = 0;
char serInStr[64];
char cmd[cmdBufferSize] ="";
char progStrLine[48] = "";
boolean textMessageBuffered;
boolean textMessagePlotted;
unsigned long nextDrawMillis = 0ul;
unsigned long nextPingMillis = 0ul;
union coordinate {
 byte b[4];
 double d;
currentCoordinate;
const double minDistToDraw = 60.0;
double x, y, xOld, yOld;
boolean firstDraw = true;
boolean penDown = false;
boolean wantsToEnd = false;
boolean endingInited = false;
int currentPen = 0;
// A3 plotter space size: 16158 x 11040
int plotterWidth = 16158;
int plotterHeight = 11040;
// system coordinates MAX_INT x MAX_INT
int systemWidth=32767;
int systemHeight=32767;
int textLines = 0;
int margin = 40*10;
/********************** PROGMEM SECTION BELOW **********************/
// long text string can be stored in program memory, and sent to the plotter
// from there as commands or log messages
const char startMessage[] PROGMEM =
"\n___________________________________________\n"
"\nARDUINO PLOTTER\n"
"version 2.0\n"
"\n"
"ole kristensen 2010\n"
"\n"
"mailto:ole@kristensen.name\n"
"http://ole.kristensen.name\n"
"___________________________________________\n\n"
const char textMessage[] PROGMEM =
"mailto:ole" "\x40" "kristensen.name\n"
const char resetPlotterCodes[] PROGMEM =
"\x1B" ".Y\n"
"\x1B" ".R\n"
"\x1B" ".M0;;;13:\n"
"IN;\n"
"SP0;\n"
boolean getProgStrLine(const prog_char str[], int lineNo){
 memset(progStrLine, 0, sizeof(progStrLine));
 char c;
 int currentLine = 0;
 byte currentChar = 0;
 if(!str) return false;
 while((c = pgm_read_byte(str++))){
   progStrLine[currentChar] = c;
   currentChar++;
   if(c == '\n'){
     if(currentLine == lineNo) {
       if(currentChar == 1){
         progStrLine[0] = ' ';
       return true;
     else {
       currentLine++;
       currentChar = 0;
 if(currentLine == lineNo && currentChar > 0){
   return true;
 if(currentLine < lineNo) {
   return false;
void printProgStr(const prog_char str[])
 char c;
 if(!str) return;
   Serial.print(c,BYTE);
void logProgStr(const prog_char str[])
 Serial.println(ESC ".)");
 printProgStr( str );
 Serial.println(ESC ".(");
/********************** MAIN SECTION BELOW **********************/
 // start/stop button
 pinMode(buttonPin, INPUT);
 setState(reset);
 if(plotterState == plotting){
   if(digitalRead(buttonPin) == HIGH){
     wantsToEnd = true;
   if(wantsToEnd && !endingInited){
     endingInited = true;
   if(wantsToEnd){
     plotSend();
     Serial.flush();
     Serial.println(";OA;");
     if (readSerialString()) {
       while(readSerialString()){
         Serial.flush();
       setState(reset);
   else {
     if(statusCode < 16) {
       if(millis() > nextDrawMillis){
         /********************** TEXT PLOTTING BELOW **********************/
         if(!textMessageBuffered){
           int textMessageLineNo = 0;
           textLines = 0;
           while(getProgStrLine(textMessage, textMessageLineNo++)){
             writeTextLine(progStrLine);
           textMessageBuffered = true;
         if(!textMessagePlotted){
           plotSend();
           Serial.flush();
           delay(10);
           nextDrawMillis = millis() + 2000ul; // prevent buffer overflow while waiting
               Serial.flush();
             textMessagePlotted = true;
         else {
           /********************** MAIN DRAWING BELOW **********************/
           setupDrawingWorld();
           double xReal = 0.0;
           double yReal = 0.0;
           double xDist = 0.0;
           double yDist = 0.0;
           if(firstDraw){
             selectPen(1);
             plotPenUp();
             plotPenAt(x,y);
             firstDraw = false;
           penDown = true;
           x=random(-systemWidth/2.0,systemWidth/2.0);
           y=random(-systemHeight/2.0,systemHeight/2.0);
           xDist = x-xOld;
           yDist = y-yOld;
           xDist = abs(xDist);
           yDist = abs(yDist);
           if(xDist > minDistToDraw || yDist > minDistToDraw) {
             xOld = x;
             yOld = y;
             plotPenAt(x,y);
             if(penDown){
               plotPenDown();
             else{
               plotPenUp();
     else {
       if(errorCode == 0){
         if(!plotterPing())
           setState(noconnection);
 else {
   if(errorCode == 0 && plotterState != reset){
     if(millis() > nextPingMillis){
       nextPingMillis = millis() + 2000ul;
       if(!plotterPing())
 if(errorCode > 15)
   setState(error);
 if(plotterState == reset){
   resetPlotter();
 if(plotterState == waiting){
       // give feedback, eg by turning on a specific led
     startPlotter();
 if(plotterState == noconnection){
   if(plotterPing()){
     plot(";");
     setState(noConnectionReturnState);
     setState(reset);
   delay(100);
 if(plotterState == error){
     errorCode = 0;
     setState(reset);
void waitForPlotterBuffer(){
 boolean isBuffering = true;
 while(isBuffering){
   Serial.flush();
   Serial.println(ESC ".B");
     bufferCapacity = atoi(serInStr);
     debugStr(serInStr);
     if(bufferCapacity >= cmdBufferSize+1){
       isBuffering = false;
       setState(plotting);
     else {
       setState(buffering);
   else {
boolean plotterPing(){
 Serial.println(ESC ".Y");
 Serial.flush();
     Serial.flush();
 Serial.println(ESC ".O");
   statusCode = atoi(serInStr);
   char msg[128] = "";
   memset( msg, 0, sizeof(msg) );
   strcat(msg, serInStr);
   Serial.flush();
       Serial.flush();
     strcat(msg, "\t");
   if(errorCode == 0){
     Serial.flush();
         Serial.flush();
     Serial.println(ESC ".E");
       errorCode = atoi(serInStr);
       strcat(msg, "\t");
       if (errorCode == 0){
         debugStr(msg);
         return true;
       else{
         logStr(msg);
         return false;
   else {
     logStr(msg);
     return true;
 else {
   return false;
ole_kristensen
Second part of code
Code: [Select]
void resetPlotter() {
 Serial.flush();
 // Welcome message
 logProgStr(startMessage);
 // Reset plotter
 printProgStr(resetPlotterCodes);
 wantsToEnd = false;
 plotterWorld = plotter;
 textMessageBuffered = (DEBUG_enabled == 1); //  skip text
 textMessagePlotted = (DEBUG_enabled == 1);  //  when debugging
 penDown = false;
 firstDraw = true;
 x = 0.0;
 y = 0.0;
 textLines = 0;
 currentPen = 0;
 setState(waiting);
void startPlotter() {
 setState(plotting);
void plot(char *str){
 plotSend(strlen(str));
 strcat(cmd, str);
void plotln(char *str){
 plotSend(strlen(str)+1);
 strcat(cmd, str);
 strcat(cmd, "\n");
void plot(int i){
 char iStr[6] = "";
 itoa(i, iStr, 10);
 plotSend(strlen(iStr));
 strcat(cmd, iStr);
void plotln(int i){
 plot(i);
 plotSend(1);
 strcat(cmd, "\n");
void plot(long l){
 char lStr[24] = "";
 ltoa(l, lStr, 10);
 plotSend(strlen(lStr));
 strcat(cmd, lStr);
void plotln(long l){
 plot(l);
 plotSend(1);
 strcat(cmd, "\n");
void plot(double d){
 char dStr[48] = "";
 fmtDouble (d, 5, dStr, 48);
 plotSend(strlen(dStr));
 strcat(cmd, dStr);
void plotln(double d){
 plot(d);
 plotSend(1);
 strcat(cmd, "\n");
void plot(float f){
 plot((double)f);
void plotln(float f){
 plotln((double)f);
void plotSend(int len){
 if(strlen(cmd) + len > cmdBufferSize-1){
   plotSend();
void plotSend(){
 waitForPlotterBuffer();
 if(plotterState != noconnection){
   Serial.println(cmd);
   memset( cmd, 0, sizeof(cmdBufferSize) );
void setState(pState state){
 pState formerState = plotterState;
 plotterState = state;
 unsigned long bufferMillis = 0ul;
 switch (plotterState) {
 case reset:
   // change state indication, eg by turning on a specific led
 case waiting:
   if(formerState != plotterState){
 case plotting:
 case buffering:
   bufferMillis = millis()+3000ul;
   while(bufferMillis > millis()){
       wantsToEnd = true;
 case noconnection:
     noConnectionReturnState = formerState;
 case error:
 default:
//read a string from the serial and store it in an array
//you must supply the array variable
uint8_t readSerialString()
 delay(10);
 if(!Serial.available()) {
   return 0;
 delay(10);  // wait a little for serial data
 memset( serInStr, 0, sizeof(serInStr) ); // set it all to zero
 byte i = 0;
 while (Serial.available()) {
   serInStr[i] = Serial.read();   // FIXME: doesn't check buffer overrun
   i++;
 //serInStr[i] = 0;  // indicate end of read string
 return i;  // return number of chars read
void logStr(char* str){
 Serial.print(ESC ".)");
 Serial.print(str);
void debugStr(char* str){
 if(DEBUG_enabled == 1){
   logStr(str);
void writeTextLine(char* text){
 setupTextWorld();
 textLines++;
 Serial.print("SP2;PU0,");
 Serial.print((plotterHeight-(margin*2))-(3*40*textLines));
 Serial.print(";DT\n;SI0.1,0.16;LB");
 Serial.print(text);
 Serial.println("\n;");
void setupTextWorld(){
 if(plotterWorld != text){
   int x1 = margin+plotterHeight+margin+margin;
   int y1 = margin;
   int x2 = plotterWidth-margin;
   int y2 = plotterHeight-margin;
   Serial.print(";IP");
   Serial.print(x1);
   Serial.print(",");
   Serial.print(y1);
   Serial.print(",");
   Serial.print(x2);
   Serial.print(",");
   Serial.print(y2);
   Serial.print(";");
   Serial.print("SC0,");
   Serial.print(x2-x1);
   Serial.print(",0,");
   Serial.print(y2-y1);
   Serial.print(";");
   plotterWorld = text;
void setupDrawingWorld(){
 if(plotterWorld != drawing){
   int x1 = margin;
   int y1 = margin;
   int x2 = plotterHeight-(margin*2);
   int y2 = plotterHeight-(margin*2);
   int radius = systemWidth/2;
   Serial.print("IP");
   Serial.print(x1);
   Serial.print(",");
   Serial.print(y1);
   Serial.print(",");
   Serial.print(x2);
   Serial.print(",");
   Serial.print(y2);
   Serial.print(";");
   Serial.print("SC-");
   Serial.print(radius);
   Serial.print(",");
   Serial.print(",-");
   Serial.print(",");
   Serial.println(";");
   plotterWorld = drawing;
void fmtDouble(double val, byte precision, char *buf, unsigned bufLen = 0xffff);
unsigned fmtUnsigned(unsigned long val, char *buf, unsigned bufLen = 0xffff, byte width = 0);
// Produce a formatted string in a buffer corresponding to the value provided.
// If the 'width' parameter is non-zero, the value will be padded with leading
// zeroes to achieve the specified width.  The number of characters added to
// the buffer (not including the null termination) is returned.
unsigned
fmtUnsigned(unsigned long val, char *buf, unsigned bufLen, byte width)
 if (!buf || !bufLen)
   return(0);
 // produce the digit string (backwards in the digit buffer)
 char dbuf[10];
 unsigned idx = 0;
 while (idx < sizeof(dbuf))
   dbuf[idx++] = (val % 10) + '0';
   if ((val /= 10) == 0)
 // copy the optional leading zeroes and digits to the target buffer
 unsigned len = 0;
 byte padding = (width > idx) ? width - idx : 0;
 char c = '0';
 while ((--bufLen > 0) && (idx || padding))
   if (padding)
     padding--;
     c = dbuf[--idx];
   *buf++ = c;
   len++;
 // add the null termination
 *buf = '\0';
 return(len);
// Format a floating point value with number of decimal places.
// The 'precision' parameter is a number from 0 to 6 indicating the desired decimal places.
// The 'buf' parameter points to a buffer to receive the formatted string.  This must be
// sufficiently large to contain the resulting string.  The buffer's length may be
// optionally specified.  If it is given, the maximum length of the generated string
// will be one less than the specified value.
// example: fmtDouble(3.1415, 2, buf); // produces 3.14 (two decimal places)
void
fmtDouble(double val, byte precision, char *buf, unsigned bufLen)
   return;
 // limit the precision to the maximum allowed value
 const byte maxPrecision = 6;
 if (precision > maxPrecision)
   precision = maxPrecision;
 if (--bufLen > 0)
   // check for a negative value
   if (val < 0.0)
     val = -val;
     *buf = '-';
     *buf++;
     bufLen--;
   // compute the rounding factor and fractional multiplier
   double roundingFactor = 0.5;
   unsigned long mult = 1;
   for (byte i = 0; i < precision; i++)
     roundingFactor /= 10.0;
     mult *= 10;
   if (bufLen > 0)
     // apply the rounding factor
     val += roundingFactor;
     // add the integral portion to the buffer
     unsigned len = fmtUnsigned((unsigned long)val, buf, bufLen);
     buf += len;
     bufLen -= len;
   // handle the fractional portion
   if ((precision > 0) && (bufLen > 0))
     *buf++ = '.';
     if (--bufLen > 0)
       buf += fmtUnsigned((unsigned long)((val - (unsigned long)val) * mult), buf, bufLen, precision);
 // null-terminate the string
 *buf = '\0';
void selectPen(int pen){
 currentPen = pen;
 plot(";SP");
 plotln(pen);
void plotPenAt(double theX, double theY){
 plot(";PA");
 plot(theX);
 plot(",");
 plot(theY);
 plotln(";");
void plotPenUp(){
 plotln(";PU;");
void plotPenDown(){
 plotln(";PD;");
copiertalk
Good job on saving it for others to see. This technology may have passed us but was rock solid built.
ole_kristensen
yep, and funny to watch - there's a performative aspect to a humming pen plotter that is way more entertaining than an inkjet.
copiertalk
I love things like this.
Today when people open an application and wonder why certain things are measured in and about the type of "pen" used. Many people do not remember when plotters and printers actually used pens and had several colors and sizes to use.
Been working in the industry for almost 25 years so this brings back some memories and some interesting comments from end users.
Thanks again for bringing it back and displaying it for others to see and enjoy.  :)
ole_kristensen
yes, i also remember my primary school internship at a sign factory cutting away in adhesive foil from corelDRAW was soo awesomely high tech and cool.
but, sigh, that is a long time ago, which reminds me
[font=Georgia][size=24]old plotter pens wanted[/size]
[/font]
[smiley=undecided.gif] plotter pens are hard to get these days - and can be ridiculously overpriced.
- so if you've still got some lying around waiting for the trash heap, and would be willing to give them away, please do not hesitate to contact me ...
copiertalk
I am not sure where you could pick up inexpensive pens at. Everything went thermal and then laser many years ago.
ole_kristensen
i'm not sure either, so that's why i made a wanted sign :)
actually, most of the ones i use now, i found in the holds of the illutron ship... most of them worked, but i still had to buy quite a few from a supplier, who's run out now.
florinc
Quote
Can't you just use a sharpie? (innocent question)
ole_kristensen
yes, i'm sure i could mod an empty plotter pen in some ways, but if people are trashing pens anyway, i'd rather use them.
the plotter's own pen exchange mechanism needs to work reliably, and the precision is important, especially when plotting the small fonts in the texts. but, yeah, cutting and gluing pens is a probable last resort.
