Hello,
I usually have my code and stuff on my own website, but its been down so I will just put code here. Because this is my first post here, I am not allowed to post w/ links, but you can see the demos under lordvon64's channel.
Demos:
Arduino Xbee Wireless Full-Range Joystick FPS Servo Turret:
//CONTROLLER CODE
//Feel free to use this code however you like, but please credit lordvon and this site!
//'ud' and 'lr' are the pot signals for the up/down and left/right pots, respectively.
//(Joysticks and their pot values are not perfect, so some things have to be empirically
//determined. The serial read function is a great tool for collecting the values.)
//range of ud: 29-1014 (middle: around 479-540; avg:~510, center:+/-35)
//range of lr: 0-960 (middle: around 419-471; avg:445, center:+/-30)
//minimum range extreme (from avg) magnitude: 445
//maximum tolerance value: 35
//Print values as 'topic:value', where 'topic' denotes either 'ud' or 'lr',
//and 'value' is the associated pot value.
//Reciever is prompted to record by ':', and ended by ','.
//"" gives characters, '' gives characters in integer form.
//Empirically determined and/or arbitrary constants.
#define ud1 0
#define lr1 1
#define highpulse 2400
#define lowpulse 600
#define lr1avg 445
#define ud1avg 510
#define tolerance1 40
#define range1 445
#define maxadd 35
int ud1val;
int lr1val;
int lr1pulse;
int ud1pulse;
int lr1previous;
int ud1previous;
boolean update;
//initialize servo to its center position.
lr1previous = lr1avg;
ud1previous = ud1avg;
Serial.print(':');
Serial.print((highpulse-lowpulse)/2+lowpulse);
Serial.print(',');
ud1val = analogRead(ud1);
lr1val = analogRead(lr1);
update = (abs(lr1avg-lr1val) > tolerance1) || (abs(ud1avg-ud1val) > tolerance1);
if (update)
lr1val = newval(lr1val,(lr1avg-range1),(lr1avg+range1),lr1avg,lr1previous);
ud1val = newval(ud1val,(ud1avg-range1),(ud1avg+range1),ud1avg,ud1previous);
lr1previous = lr1val;
ud1previous = ud1val;
lr1pulse = map(lr1val,(lr1avg-range1),(lr1avg+range1),lowpulse,highpulse);
ud1pulse = map(ud1val,(ud1avg-range1),(ud1avg+range1),lowpulse,highpulse);
//':' is packet delimiter, ',' is UD/LR delimiter.
//Each cycle of delimiters denote a packet.
//Packet: UD value first, then LR value. (:UD,LR:)
Serial.print(':');
Serial.print(ud1pulse);
Serial.print(',');
Serial.print(lr1pulse);
delay(25);
update = false;
int newval(int val, int minval, int maxval, int avgval, int previousval)
int increment;
increment = val-avgval;
if (increment > 0)
increment = increment - tolerance1;
else if (increment < 0)
increment = increment + tolerance1;
increment = map(increment,0,range1-tolerance1,0,maxadd);
val = increment + previousval;
if (!(val <= maxval) || !(val >= minval))
if (val > maxval)
val = maxval;
val = minval;
return val;
//RECIEVER CODE
#include <Servo.h>
Servo elevation;
Servo azimuth;
char received;
char pulsechar[4];
int counter=0;
int pulse;
boolean delimiter;
while (!Serial.available()){}
received = Serial.read();
elevation.attach(12);
azimuth.attach(13);
// if (Serial.available())
// Serial.println(char(Serial.read()));
delimiter = (received == ',') || (received == ':');
if (!delimiter)
counter = 0;
while (!delimiter)
pulsechar[counter] = received;
counter += 1;
pulsechar[counter] = '\0';
pulse = atoi(pulsechar);
switch (received)
case ',':
azimuth.writeMicroseconds(pulse);
break;
case ':':
elevation.writeMicroseconds(pulse);
break;
Wireless PWM with ADC: Xbee with No Microcontroller (Direct I/O)
(just configuration code for the a hyperterminal (i used xctu))
//pot (potentiometer) reader configuration
//initialization: type "+++", WAIT few seconds for ok,
//then type "AT" and press enter, get ok, then issue commands.
//(numbers are in hexadecimal format)
ATID 4064
ATMY 40
ATDL 64
ATD1 2
ATIR A //(A=10 in hexadecimal format)
ATIT 1
ATWR
//pwm outputter
ATID 4064
ATMY 64
ATDL 40
ATP1 2
ATIU 1
ATIA 40
ATWR
Arduino Servo Turret Controlled by a Nintendo DS Touch Screen
//Code was adapted from that found on (http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1243499684/0).
#include <Servo.h>
Servo azimuth;
Servo elevation;
// Empirically determined; Voltage between an output high and output low pin.
#define Vref 4.46
#define quarter (highpulse-lowpulse)/4
#define s1high lowpulse+quarter/2
#define s2high s1high+quarter
#define s3high s2high+quarter
#define s4high s3high+quarter
#define sdivide .7071
#define maxmag 420
//When looking at DS screen with connector bottom left,
// the connections are from left to right:
//TOP, X1
//LEFT, Y2
//BOTTOM, X2
//RIGHT, Y1
// Digital pin connections (used to drive power)
#define X1 2 // TOP to Digital output 5
#define Y2 3 // LEFT to digital output 2
#define X2 4 // BOTTOM to digital output 3
#define Y1 5 // RIGHT to digital output 4
// Analog inputs
#define Xin 3 // From X1
#define Yin 4 // From Y1
// set initial touched position
int touchX;
int touchY;
int xpos;
int ypos;
float cosine;
float sine;
float mag;
int apulse;
int epulse;
azimuth.attach(11);
if (touched())
xpos = touchX - 511;
ypos = touchY - 511;
if(!(xpos == 0 and ypos == 0))
mag = sqrt(pow(ypos,2) + pow(xpos,2));
sine = ypos / mag;
if(abs(sine)>=sdivide)
cosine = xpos / mag;
if(ypos>0)
apulse = map(cosine*10000,-7071,7071,s2high,s3high);
if(xpos >= 0)
apulse = map(cosine*10000,7071,0,s4high,highpulse);
apulse = map(cosine*10000,0,-7071,lowpulse,s1high);
if(xpos>0)
apulse = map(sine*10000,7071,-7071,s3high,s4high);
apulse = map(sine*10000,-7071,7071,s1high,s2high);
azimuth.writeMicroseconds(apulse);
if(mag>maxmag or mag<0)
mag=maxmag/2;
epulse = map(mag,0,maxmag,highpulse,lowpulse);
elevation.writeMicroseconds(epulse);
boolean touched()
boolean touch = false;
// Horizontal routine Y1:Y2::Vcc:Gnd
pinMode(Y2, OUTPUT);
digitalWrite(Y2, LOW);
pinMode(Y1, OUTPUT);
digitalWrite(Y1, HIGH);
// X1,X2 high impedance (input mode)
pinMode(X1, INPUT);
pinMode(X2, INPUT);
// wait a bit, then read from X1
delay(10);
touchX = analogRead(Xin);
// Vertical routine X1:X2::Vcc:Gnd
pinMode(X2, OUTPUT);
digitalWrite(X2, LOW);
pinMode(X1, OUTPUT);
digitalWrite(X1, HIGH);
// Y1,Y2 high impedance (input mode)
pinMode(Y1, INPUT);
pinMode(Y2, INPUT);
// wait a bit, then read from Y1
delay(10);
touchY = analogRead(Yin);
// Only read touch if coords are below 1000 and above 0
// (stops errors with certain screens)
if(touchX < 1023 and touchX > 0 and touchY < 1023 and touchY > 0)
touch = true;
return touch;
