North Yorkshire, UK
« Reply #15 on: June 11, 2009, 01:08:20 pm » |
It looks like the smallest you can get is 1.8" diagonal made for small phones etc and then you can get varying other sizes going up to about 15" but most places seem to want to sell a couple of thousand so they may be difficult to get hold of. The DS touch screen is easy to get hold of and relatively cheap and you don't have to buy thousands  Just do a search for a 4 wire resistive touch screen. Mowcius
« Reply #16 on: July 27, 2009, 12:22:04 pm » |
How did you go about connecting the DS touchscreen to wires you could use in the breadboard? i have one (well two actually as i assume i will mess up the connection on at least one!) and would love any tips for how you went about it. My current plan is a to cut between the wires using a modelling knife.
Does anyone know of a way to get rid of the plastic overlay thats on the wires then it would be easy to connect wires at the base of the wires.
North Yorkshire, UK
« Reply #17 on: July 27, 2009, 03:45:25 pm » |
I just did it carefully with a sharp pair of scissors and then laid 4 wires on the connectons and soldered them up with some heatshrink round it to stop the joint flexing so much... I didn't remove any plastic or anything...
Anternatively, if you like surface mount soldering you can buy the touch screen connector from sparkfun... I presume that it works with both the DS and DS lite touch screens (it looks like it should)
Hope this helps,
Mowcius
B0100111001000011, USA
I'm confused. Wait, maybe not..
« Reply #18 on: November 21, 2009, 05:21:36 pm » |
Still no video of this in action?  I've added one to my Wish list (2.99 free shipping on eBay, can't beat that!), but I'd love to see how yours looks while functioning  .
North Yorkshire, UK
« Reply #19 on: November 21, 2009, 05:29:37 pm » |
Oh, sorry. I dismantled it to use some of the parts as I still only have one arduino! If I remember then I will still try to a get a video done eventually. The LEDs on the picture were not evenly matched so it didn't mix very well and I have not got round to playing with the i2c commands for my blinkm maxm yet...
Mowcius
« Last Edit: November 21, 2009, 05:30:14 pm by mowcius »
« Reply #20 on: November 21, 2009, 05:30:19 pm » |
Alright, well thanks for the update anyways  !
« Reply #21 on: November 21, 2009, 05:55:23 pm » |
I know it says in the code where to connect the pins from the screen, but could you please write it out? For some reason I'm having trouble understanding it. A picture would be useful if you have one  . NEVERMIND. I believe I get it now..
« Last Edit: November 21, 2009, 06:13:19 pm by Tchnclfl »
North Yorkshire, UK
« Reply #22 on: November 22, 2009, 05:42:22 am » |
Ok, cool. Just say if you need any help with anything else.
Mowcius
North Yorkshire, UK
« Reply #23 on: November 22, 2009, 10:30:52 am » |
Just a quick comment to anyone still looking at this. In my first posted code there are some weird numbers to get the values right for PWMing the LEDs, if you are going to do something similar then you want to 'map' the values from the touch screen to get them within the right range for the PWM.
Mowcius
« Reply #24 on: November 22, 2009, 11:51:02 am » |
if you are going to do something similar then you want to 'map' the values from the touch screen to get them within the right range for the PWM. No idea what that means (I'm still a noob  ) but alrighty! haha
North Yorkshire, UK
« Reply #25 on: November 22, 2009, 12:16:07 pm » |
No idea what that means (I'm still a noob) but alrighty! haha Well I did some rubbish like this: analogWrite(LEDB, touchX/4 -18) to get the values correct for the PWM (altering the brightness of the LEDs) I should have used the map function: http://arduino.cc/en/Reference/Mapto change the values from the touch screen into values from 0-255 for the PWM. It is just a much better and more accurate way to do it... Mowcius
« Reply #26 on: November 22, 2009, 12:17:31 pm » |
Oh so instead of using the 0-1024 produced by analogRead(), you use Map to change them to 0-255 used for PWM?
North Yorkshire, UK
« Reply #27 on: November 22, 2009, 12:32:19 pm » |
Yeah. Well you don't get quite the full range from analog reading on the touch screen, you normally get close to it but not quite... So the map function sets it right  You don't get 0-1024 on analog read, you get 0-1023... So basically if you wanted 1-1024 then you would need to map it still (or add 1!) Mowcius
« Last Edit: November 22, 2009, 12:33:45 pm by mowcius »
« Reply #28 on: November 22, 2009, 12:33:33 pm » |
Cool. Thanks for the advice  . Seems like that'd be simpler and faster than what you did, so why didn't you just do it that way in the first place?  !
North Yorkshire, UK
« Reply #29 on: November 22, 2009, 12:40:30 pm » |
I was a noob! We all were originally... If I could go back and change that post then I would. I have learnt a lot in half a year!
Mowcius
