Topic: LED Matrix Spectrogram (Read 5978 times) previous topic - next topic
zitron
Oops, it looks like I overwrote the arduino code with the pc software code,  because they had the same name :-?
I re-uploaded the arduino code again:
http://sites.google.com/site/iluvtocnc/LED_Spectrum_Arduino.zip
Sorry...
yen
:) Thanks a lot (all I have to do now, is to figure out why my 0832-Board doesn't light up... But thats only a question of time  8-) )
zitron
Lex it should be very easy to control more than 1 panel, you need to set the dip switches according to the manual, and use additional arduino pins to choose which panel is the active one.
zitron
#18
Mar 01, 2010, 01:42 pm Last Edit: Mar 01, 2010, 01:51 pm by zitron Reason: 1
Yen my code has a self test that lights up all the LEDs when it starts, so if it doesn't work at all it's probably a wiring or other hardware problem...
Edit: oh wait the arduino code doesn't have a self test, my pc program just sends values to fill up all the leds when it connects.
yen
Yep, was a harware problem.
Is there any way to change the spectrum so that it actually shows the data of the music which is currently being played - and not the microphone?  :)
zitron
#20
Mar 01, 2010, 01:53 pm Last Edit: Mar 01, 2010, 01:54 pm by zitron Reason: 1
Yes, if you are using a windows pc, you need to choose stereo mix as input in the sound recording screen.
yen
Well, exactly this is my problem - it's not possible with Win7 afaik...
Carnyworld
Hi, I am trying to get your spectogram up and running on my 0832 Green LED Matrix. It compiles and uploads fine to my Arduino. The PC Application launches fine but no leds are lighting up. Why is this? Im using Windows 7.
C program run. C program crash. C programmer quit.
zitron
Hi all,
I found out that the MicroSoft DRM police has disabled stereo out on Win 7 and Vista, so people can't record stuff to MP3 on their computers. So my program won't work on Windows 7 or Vista. To get it working you may need additional software, perhaps "virtual audio cable"?
Sorry about that,
-Z-
Carnyworld
(Tested on windows 7)
1. Click the Start Button, type "MMSYS.CPL" (without quotation marks) in the Start Search box and press Enter.
2. On Recording tab, right-click on the blank area
3. Check "Show Disabled Devices" and "Show Disconnected Devices" and the Stereo Mix should show up.
If it is disabled, right click on it and choose Enable.
zitron
OK Thanks. I'm still using XP so I have no idea about win7, but I think it you should be able to test it using the mic input.
Also I just remembered that I've got a new version of the PC software, now it uses both stereo channels, displaying them symmetrically, and the nob thing actually does something (the higher you turn it the more gain is reduced)!
Get the new one here: https://sites.google.com/site/iluvtocnc/LEDSpectrumV2.zip
Cheers,
-Z-
Carnyworld
The new one works great!
DeFex
That song made me laugh. who did it?
zitron
Quote
http://www.youtube.com/watch?v=WGoi1MSGu64
