Topic: switch/case (Read 2875 times) previous topic - next topic
jmnijsse
Hello,
I had the following code (not complete):
switch (wind_direction)
  case'30':
  Serial.print("ZW");
  break;
Is it possible to define the '30' as a value of 25 - 35?
The value 30 is in some circumstances a little bit lower or higher, but in all this range he must Serial.print("ZW").
Ideas?
Gr.
Johan
magnethead794
Hello,
  case'30':
  Serial.print("ZW");
  break;
Ideas?
Gr.
Johan
You would be better off using if statements if you have to check range. 99.2% sure switch case is steady-state.
jmnijsse
Yes, we do in the first time.
But we have twelve situations (its a winddirectionflag, contacted with reedcontacts and different resistors).
So, i thought, the if-solution became a long code.
J.
MarkT
You can't mean "case '30':", perhaps you mean "case 30:" ??
Sounds like you need "if (wind_direction >= 25 && wind_direction <= 35)"
wildbill
Is the output of the reed switches and resistors a voltage that you get with analogread and that is the need for a range to test for?
jmnijsse
Yes, I read a voltage of the resistor.
With the if-solution:
Have i write it like this:
if (wind_direction >= 25 && wind_direction <= 35) {
  Serial.print("ZW");
if (wind_direction >=40 && wind_direction <=50) {
  Serial.print("W")
...and this twelve times?
magnethead794
J.
This will look redundant with If and switch, but will be much cleaner- particularly if you're doing the same thing, but with different numbers.
Use 12 if statements to set an int, then switch on that int. IE,
if ((-15 <= wind_direction) && ((wind_direction <= 15)){
evalDir = "N"
} else if ((16 <= wind_direction) && ((wind_direction <= 30)){
evalDir = "NNE"
} else if ((31 <= wind_direction) && ((wind_direction <= 60)){
evalDir = "NE"
} else if ((61 <= wind_direction) && ((wind_direction <= 75)){
evalDir = "ENE"
} else if ((76 <= wind_direction) && ((wind_direction <= 105)){
evalDir = "E"
} else if ((106 <= wind_direction) && ((wind_direction <= 120)){
evalDir = "ESE"
} else if ((121 <= wind_direction) && ((wind_direction <= 150)){
evalDir = "SE"
} else if ((151 <= wind_direction) && ((wind_direction <= 165)){
evalDir = "SSE"
} else if ((166 <= wind_direction) && ((wind_direction <= 195)){
evalDir = "S"
} else if ((196 <= wind_direction) && ((wind_direction <= 210)){
evalDir = "SSW"
} else if ((211 <= wind_direction) && ((wind_direction <= 240)){
evalDir = "SW"
} else if ((241 <= wind_direction) && ((wind_direction <= 255)){
evalDir = "WSW"
} else if ((256 <= wind_direction) && ((wind_direction <= 285)){
evalDir = "W"
} else if ((286 <= wind_direction) && ((wind_direction <= 300)){
evalDir = "WNW"
} else if ((301 <= wind_direction) && ((wind_direction <= 330)){
evalDir = "NW"
} else if ((331 <= wind_direction) && ((wind_direction <= 345)){
evalDir = "NNW"
} else if ((346 <= wind_direction) && ((wind_direction <= 360)){
evalDir = "N"
switch (evalDir){
case n:
serial.print(evalDir);
break;
AWOL
You could put the ranges and direction string into an array of structs, then simply loop through the array.
wildbill
What are the actual ranges? It might be possible to reduce them with a simple formula to give you an int in the 0 to 11 range to use as an index into a string array.
pYro_65
#9
Dec 16, 2011, 02:32 pm Last Edit: Dec 16, 2011, 03:23 pm by pYro_65 Reason: 1
Oops, went to modify my post and removed it by accident.
Wildbill is right, no if's or switch needed.
This is assuming the values you read are relative to degrees.
const char *c_Text[] = { "N", "NNE",  "NE", "ENE", "E", "ESE", "SE", "SSE", "S", "SSW", "SW", "WSW", "W", "WNW", "NW", "NNW", "N" };
int deg; //Provided from sensor.
#define WHICH_DIRECTION( sensor_degrees )        ( c_Text[ ( int ) ( ( 17.0f / 360.0f )  * ( float ) sensor_degrees ) ] )
#define WHICH_DIRECTION__SAFE( sensor_degrees )  ( c_Text[ ( int ) ( ( ( 17.0f / 360.0f )  * ( float ) sensor_degrees ) - 0.0001f ) ] )
void loop(){
 //Get value into deg
 deg = 34;
 //If sensor data is in range 0 to 359
 Serial.print( WHICH_DIRECTION( deg ) );
 //If you receive a value of 360 instead of 0, use this instead. ( prevents overflow ).
 //Shouldn't need this. A sensor should only give one result for a discrete position.
 Serial.print( WHICH_DIRECTION__SAFE( deg ) );
Forum Mod anyone?
https://arduino.land/Moduino/
ryschwith
Would this be an instance to use map()? Something like:
map( wind_direction, 0, 359, 0, 11 );
PaulS
You want to use a convoluted function to divide by 30? Whatever floats your boat, I guess.
pYro_65
Division is slower than multiplication.
( 17.0f / 360.0f ) is a compile time constant, only operation being emitted is 0.0472 * deg
Forum Mod anyone?
PaulS
So? Have you looked at the map function?
pYro_65
Nope, didn't realise you were referring to it.
Have now tho. map contains an operation not needed for this topic. Division would be faster due to the overhead and the fact that gcc will optimise most / operations to * operations.
Forum Mod anyone?
