Topic: Using Cygwin to save serial monitor data (Read 1 time) previous topic - next topic
smhall05
I am not sure if this information has already been posted, but I found that I can save the output of the serial monitor by doing the following in cygwin:
//my arduino is attached to COM4, the below command is zero based hence the ttyS3
stty -F /dev/ttyS3 9600 crtscts clocal
//Then I can simply issue
cat /dev/ttyS3
The sketch I am using is:
Code: [Select]
int count = 0;
void setup()                    // run once, when the sketch starts
  Serial.begin(9600);           // set up Serial library at 9600 bps
void loop()                       // run over and over again
  Serial.print("temp: ");
  Serial.println(count);
  count++;
  delay (1000);
The source of my information is http://blog.thomnichols.org/2009/08/serial-console-monitoring-without-hyperterminal
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
