Loading...
Pages: 1 2 [3]   Go Down
Author Topic: millis() blink != 50/50  (Read 1144 times)
Des Moines, WA - USA
Offline Offline
God Member
View Profile
Brevity is not clarity.
And stop acting like a child.  This wasn't aimed at you it's a common complaint I have with most programming forums.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Right. Let's move on. All of the solutions posted have their merits. Let's not descend into a flame war.
Logged
Offline Offline
God Member
View Profile
And to this I agree with!!
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
Here is a user interactive version, it blinks the on-board led on my UNO.
Enter numbers from 0 to 999 through serial and that will be the millisecs/second the led stays on.
Code:
unsigned long waitUntil = 0UL; // because millis() returns UL
enum whatFlag { led13state, endOfLine, dataBegun };
byte  Flags = 0;
  pinMode( 13, OUTPUT );
  digitalWrite( 13, bitRead( Flags, led13state ));
  Serial.begin( 9600 );
  Serial.println( "Blink w/user input. Enter up to 1000 for led-on interval" );
  static byte  c; // c for character buffer
//  static byte  endOfLineState = 0;
  static unsigned long timeSinceLastSerialRead = 0UL;
  static int enter = 0; // to get serial-entered number value.
  static int ledMillisOn = 100;  // must be 0-999
  // flash led and state changer
  if ( waitUntil - millis() >= 10000UL )  // when millis() passes waitUntil the _unsigned_ subtract
  {                                       // leaves very large positive result
    Flags ^= ( 1 << led13state ); // led13state T/F bit toggle
    if (bitRead( Flags, led13state ))  waitUntil = millis() + (unsigned long)(ledMillisOn);
    else                              waitUntil = millis() + (unsigned long)(999 - ledMillisOn);
    digitalWrite(13, bitRead( Flags, led13state ));
  // serial input
  if (Serial.available())
    c = Serial.read();
//    Serial.print(".");
//    Serial.print( c );
    timeSinceLastSerialRead = millis();
    if ( c >= '0' && c <= '9' )
      enter *= 10;  // decimal shifting whatever is in enter 1 place up
      enter += ( c - '0' ); // ascii 48 is '0'
      bitSet(Flags, dataBegun );  // entry is treated as finished
      if ( enter >= 100 ) // next digit being able to take the total > 999
        bitSet(Flags, endOfLine );  // entry is treated as finished
    else if (( c == 13 || c == 10 ) && bitRead( Flags, dataBegun ))
      bitSet( Flags, endOfLine );  // entry is treated as finished
    else if (( millis() - timeSinceLastSerialRead >= 500 ) && ! bitRead( Flags, endOfLine ))
  // serial output
  if ( bitRead( Flags, endOfLine ) && bitRead( Flags, dataBegun )) // should be done and have data
    Serial.print( ">> " );
    Serial.print( enter );
    Serial.println( " <<" );
    ledMillisOn = enter;
    enter = 0;
    bitClear( Flags, endOfLine );
    bitClear( Flags, dataBegun ); // clears bits, endOfLine and dataBegun
Logged
Examples can be found at Learning in the Main Site and at the Playground
Pages: 1 2 [3]   Go Up
Print
Jump to:
