Topic: Real-time Data Acquisition from Matlab to Arduino (Read 3548 times) previous topic - next topic
lusian
Dec 17, 2011, 02:02 pm Last Edit: Dec 17, 2011, 02:07 pm by lusian Reason: 1
Okey, i need some help with the followings:
I need to transfer some variables from Matlab to arduino. I try to build a delta robot with an arduino controler, and I must calculate the degrees for the servo. Calculate their grades with Matlab, and after the matlab finish the calculation I want to send the results(3 degrees-variables) to arduino, and then arduino must send the data(degrees) at the servo.
I drew a sketch to be better understood.
PaulS
Quote
You need help with which part of it? Having MatLab calculate the values? Having MatLab send the values? Having the Arduino receive the values? Having the Arduino use the values? Sourcing parts for the robot? Assembling the robot?
cipriansebi
Hello everyone
I'm Lucian colleague and I can answer .
So, yes=MatLab calculate the values; yes =  MatLab send the values; yes = the Arduino receive the values; yes = the Arduino use the values to move some servo. The the whole idea is :how to Arduino read some value from Matlab .
Thank you, bye.
PaulS
Quote
Does this mean "Yes, we know how to make MatLab compute the values" or does it mean "Yes, we need help with making MatLab compute the values"?
The connection between MatLab and the Arduino is by way of the serial port. So, call Serial.begin() in setup, with a value to match MatLab. Then, use Serial.available() and Serial.read() to determine haow much data is available to read, and read the data one byte at a time.
Depending on how MatLab is sending the 3 values, you may have to read 3 bytes, 6 bytes, or an unknown number of bytes.
cipriansebi
Sorry for the confusion. The calculation is done in Matlab. We want to send three values ??to the Arduino. Would help us a simple example.
Thank you.
lusian
Quote
Quote
The results from the matlab we want to send to arduino.
PaulS
If I understand correctly, then, you need help with MatLab. When you get that working, will you go over to the MatLab forum and ask for help with the Arduino side?
