Topic: Me and my Quadrabot (Read 6379 times) previous topic - next topic
CrazyEyesNZ
Sorry I have taken my sweet time returning to this forum, life has been busy.
All I've done at this stage is make a to the change to the movements. Now instead of making the foot move from point A to point B, it moves in a path between point A to point B, stopping at a predetermined (set at three in this example) number of points along the path. I have done this in an attempt to create a more accurate path. The path is made from the original coordinates and mathematically added within the program.
There are still a few glitches in it and it looks quite dumb imo, but its a start.
http://www.youtube.com/watch?v=i7LSH_QzORE
Code: [Select]
void doTest()
  for (h=0; h<testcount; h++) //step
    for (e=0; e<12; e++) //servo
    for (d=1; d<testcount; d++)
        if (h==0)  //if first step
        move=test[e][h];
        myservo[e].write(move);
        if (h!=0 && h<=testcount) //if subsequent steps
          if (test[e][h]==test[e][h-1]) //if move-to is equal to
            move=test[e][h];
          else if (test[e][h]>test[e][h-1]) //if move-to is greater than
            c=test[e][h]-test[e][h-1];
            c=c/3;
            move=test[e][h]-(c*d);
            delay(pause);
          else if (test[e][h]<test[e][h-1]) //if move-to is less than
            c=test[e][h-1]-test[e][h];
            c=c/3;
            move=test[e][h]+(c*d);
            delay(pause);
  delay(pause);
For all those that want to follow a little closer I have set up a Facebook page:
http://www.facebook.com/home.php#!/pages/Quadrabot/246637268735818
CrazyEyesNZ
Opps, I put the wrong code on there, sorry:
Code: [Select]
void doTest()
    for (d=divisor; d>0; d--) //divisions per movement
        savepos[e]=test[e][h];
          if (test[e][h]==savepos[e]) //if move-to is equal to
            move=test[e][h];
          else if (test[e][h]>savepos[e]) //if move-to is greater than
            c=test[e][h]-savepos[e];
            c=c/3;
          else if (test[e][h]<savepos[e]) //if move-to is less than
            c=savepos[e]-test[e][h];
            c=c/3;
              move=test[e][h];
              c=c/3;
              c=c/3;
        delay(pause/(divisor*2));
Cello62
#17
Feb 14, 2012, 09:04 am Last Edit: Feb 14, 2012, 03:12 pm by Cello62 Reason: 1
Hi
Nice project!
Would you mind to do a litte "instructables" with any photo, to explain how to assembly the legs,wires and sensor?
Thanks for all
