Topic: Error Message (Read 816 times) previous topic - next topic
Rakusan2
Hi, I am getting my arduino on Christmas and I want to have some kind of a project ready before then, but when i click verify it gives me a error message that I don't understand and would like help with.
The error message is:  error: expected ',' or '...' before numeric constant
I have started o learn arduino code on Thursday and because I have learned some of Turing and I am a good logical thinker I have created this.
This will control bunch of LED's to create a number and change it to the next one.
If the button is pressed then right now one LED blinks and when I will figure out the error then I will make itso another button changes it on command.
#define t 2   //Top LED's
#define tl 3  //Top Left LED's
#define tr 4  //Top Right LED's
#define m 5   //Middle LED's
#define bl 6  //Bottom Left LED's
#define br 7  //Bottom Right LED's
#define b 8   //Bottom LED's
#define d 9   //Dot
#define s 10  //Button
#define de 100  //delay
int n = 0;
int number0(){
  digitalWrite (t, HIGH);
  digitalWrite (tl, HIGH);
  digitalWrite (tr, HIGH);
  digitalWrite (bl, HIGH);
  digitalWrite (br, HIGH);
  digitalWrite (b, HIGH);
  n = 0;
int number1(){
  digitalWrite (t, LOW);
  digitalWrite (tl, LOW);
  digitalWrite (m, LOW);
  digitalWrite (bl, LOW);
  digitalWrite (b, LOW);
  n = 1;
int number2(){
  digitalWrite (m, HIGH);
  digitalWrite (br, LOW);
  n = 2;
int number3(){
  n = 3;
int number4(){
  n = 4;
int number5(){
  digitalWrite (tr, LOW);
  n = 5;
int number6(){
  n = 6;
int number7(){
  n = 7;
int number8(){
  n = 8;
int number9(){
  n = 9;
void setup ()
  for (int x = t; x <= d; x++) {
    pinMode (x, OUTPUT);
  pinMode (s, INPUT);
  digitalWrite (d, HIGH);
void loop ()
  while (digitalRead == LOW){
    switch (n){
      case 0:
      number0();
      case 1:
      number1();
      case 2:
      number2();
      case 3:
      number3();
      case 4:
      number4();
      case 5:
      number5();
      case 6:
      number6();
      case 7:
      number7();
      case 8:
      number8();
      case 9:
      number9();
    if (n == 9){
      n = 0;
    else {
    n++;
  digitalWrite (d, LOW);
  delay (100);
  delay (100);
pYro_65
#1
Dec 20, 2011, 04:52 am Last Edit: Dec 20, 2011, 05:05 am by pYro_65 Reason: 1
you need break statements in your switch it seems, each number function lights the other lights for you,
without the break, case 5 executes.
number5();
number6();
number7();
number8();
number9();
you should post the line number of the error
EDIT: n or your some of your defines are defined in the core ( WString.h apparantly ),
change the names to something meaningful and the errors will go.
your number functions need return values
Forum Mod anyone?
https://arduino.land/Moduino/
dxw00d
The problem is here...
#define d 9   //Dot
#define is a compiler directive. What it does is replace all occurrences of the first parameter with the second parameter within the code, prior to compilation. So, with your #defines, all occurrences of the letter 't' are replaced with the digit '2', all 'b's with '8's, and so on. The result of this is, for example, the function digitalWrite() becomes 9igi2alWri2e(), and the compiler doesn't have a clue what you mean.
Moral: If you are going to use #define, make sure you consider the results.
You do need breaks in the switch/case bit.
PaulS
No, that does not happen. All occurrences of t as a word, not as a letter, are replaced.
The problem IS with the #define statements, but it is because of a bug in the way that the IDE added code to the sketch. Move the int n=0; statement ABOVE the #defines, and the problem goes away.
dxw00d
Ah, ok. Right area, wrong reason. Thanks for the explanation. Still learning myself.
