Topic: Hack from SPI display to Arduino (Read 5442 times) previous topic - next topic
RickRantilla
I have a time and attendance fingerprint system with no technical documentation or support line.  It reads fingerprints, matches them up to a user ID then logs the read (or other activity) to its memory.  You can access the memory only in batch, such as downloading a day's worth of transactions to a USB card.  I need to know the user ID in "real time".
The system does display each successfully read user ID on a 128 x 64 LCD display.  The display is similar to DOGM display but not identical.  The motherboard writes to the LCD using SPI at 2.4 mega Hz.  When writing the user ID it uses a graphics mode to draw a picture of the numbers.  Each digit is 11 bits high and 7 bits wide, so it uses two 8x8 bit blocks for each digit.  They are sent as a 3 byte location/command, followed by 16 bytes of data.
Here is my plan: I want to use an Arduino as an SPI slave to monitor the signals being sent to the LCD. I've decoded the motherboard to LCD enough that I know that after the sequence of two bytes with digital 88, 16 I have to capture about the next couple hundred bytes which I can eventually decode to my user ID.  I'll then have a couple of seconds to decode this mess and issue instructions to the rest of my system before going back to monitoring the LCD.
Before I get too invested in this plan, I'd like to know if the Arduino can read SPI at 2.4 megaHz while looking for the "88,16" trigger signal and storing a few hundred bytes of the SPI sequence in memory.  Or am I going to have to build some kind of small hardware buffer.
I'd appreciate any advice on either approach.
nickgammon
Take a look at my screenshots here:
http://www.gammon.com.au/spi
According to that page, the normal SPI processing is at 4 MHz clock, so 2.4 should be fine.
I suppose you are wearing a white hat, and not a black one?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
RickRantilla
Thanks, this looks good and gives me a better understanding of SPI.
I'm doing a white hat.  The time and attendance fingerprint reader I'm hacking will be used in an Alzheimer's clinic art class.  Placing the patient's finger in the reader will pop open that specific patient's cabinet door.  The other patients can't accidentally access other patient's work.  The teacher's fingerprint will open any door and/or allow registration of new patients.  The cabinet doors are clear acrylic and family visitors can see the art work in progress.  We might optionally allow the family to register their fingerprint and to open their relative's cabinet.
Thanks again.  I'd be glad to post my "decoding" algorithm if you think anyone might be interested.
nickgammon
graynomad
You should be able to read the bytes just fine but I wouldn't spent much time playing with them until you have the lot.
If there's no gap between the bytes you only have about 400nS to read data from the SPDR register so interrupts are out as well.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
RickRantilla
Well, a little progress, but I'm stuck again.  To bone up on SPI I used Nick's article, thank you.  I set up an Arduino 2009 as a slave and a Mega1280 as the Master.  I put the logic analyzer pins on the slave and got them communicating the best using the second pair of Nick's programs.  I got the Master to simulate the signals and pictures that are coming from the Time and Attendance LCD and hacked enough of a program on the Slave so I could identify the graph/picture for at least the digits 0-9.  I got the interrupt routine short enough to work at 4 megaHz and since the T&A system is at 2.4 megaHz I thought it was time to move on.
Then I hooked the Slave and logic analyzer to the T&A LCD and ran into what turned out to be a big problem.  Both the clock and the Slave Select voltages on the T&A system are inverted (voltage high vs. low) from the way SPI is set up in the SPI library.  There is a clock polarity setting in SPI.setDataMode() which I think solves the former, but I can't find any way to change the Slave Select polarity.
Any ideas in software or settings?
I'm not much with electronic hardware but I'm sure there is some easy way to invert either of these signals with a transistor or two.  Any reference to how to do that?
PS.  My son is visiting his in-laws in Florida.  They are originally from somewhere just north of Melbourne, I think Seymour?
nickgammon
Well, slave select is pretty-much manual, so you just do a digitalWrite HIGH rather than LOW, and you solved that one.
Quote
About two hours drive north, but yes, I know Seymour.
RickRantilla
Thanks, Nick.  I got the clock mode fixed and found another line from the motherboard with a byte frame signal that I'm using as a SlaveSelect signal with the correct polarity.  This causes a minor problem in that I have to also look at and discard all the command bytes, but no big deal.
Thanks, Graynomad.  Actually there are about 10 bits per byte so I have about 4 microsec to do something with the SPDR byte before it gets overwritten.  The time and attendance to LCD clock is running at about 2.4 megaHz (400 nanosec).  4 microsec is about 64 Arduino assembly instructions.
I simulated the LCD with another Arduino at 4 megaHz SPI and got everything hobbling along.  However, when I wire up to the Time and Attendance LCD I'm losing about 5% of the bytes in the Interrupt Service Routine.  I'm getting clear bytes on the logic analyzer.  I put debug timers in the ISR and with Arduino microsec() resolution I get mostly 4 microsec but occasionally 8 microsec for the loop, which is marginal.  I don't know what causes the longer ISR or whether that's when I lose a byte.  Since each valid userID has 8 digits in it I'd have to have the patients rescan about 40% of the time, which I think is unacceptable.  Even worse might be the occasional false positive.
I've written the ISR with a switch case conditional to capture any of the 10 numerals it might be looking at.
Here is the code.  Any idea how to speed it up?  Or do I need to try a faster processor like the Maple?
Quote
// SPI interrupt routine
ISR (SPI_STC_vect)
  //unsigned int time = 0; time = micros(); // debug
  cp = c; //  store previous digit needed to distinguish a 1 or 8
  c = SPDR; // SPDR is the byte as SPI finds it
  switch (c)  // The T&A LCD displays the userID as an 8 digit graphic including 4 leading zeroes
               // each graphic bitmap has 16 bytes per digit displayed
              // Among the displayed digits, I found each digit has a unique byte (or byte pair) somewhere in it
              // So whenever I find this unique byte in a field of digits, I've identified a digit
              // I might also get these "unique bytes" in a field of commands or letters, but never with 4 leading zeroes
              // Whenever I find a likely digit I store it in the buffer array digit[] to extract the userID later
  case 71:
    digit [j++] = 0;  // Rick e
  case 96:
    if (cp == 192) {digit [j++] = 1; }// Rick n
  case 67:
    digit [j++] = 2;  // Rick d
  case 30:
    digit [j++] = 3;  // Rick d
  case 19:
    digit [j++] = 4;  // Rick d
  case 33:
    digit [j++] = 5;  // Rick e
  case 48:
    digit [j++] = 6;  // Rick d
  case 1:
    digit [j++] = 7;  // Rick d
  case 62:
    if (cp == 127) {digit [j++] = 8; }// Rick n
  case 35:
    digit [j++] = 9;  // Rick d
  default:
  //time = micros() - time; Serial.println (time, DEC); delay(100); // debug
  } // end of switch
}  // end of interrupt service routine (ISR) SPI_STC_vect
Thanks in advance, Rick.
nickgammon
How have you defined all those variables?
Possibly the 5% is because of the timer interrupt kicking in. You could probably turn that off, however then micros() and millis() wouldn't work.
What would probably be faster than a switch would be a table lookup. That is, directly index into a table to find the correlation between the code you receive and the translated code. You would still have a problem with 1 and 8 though.
The other thing would be to stuff it into a buffer (eg. buf [pos++] = SPDR; ). Then worry about interpreting the buffer when you have time on your side.
graynomad
#9
Dec 28, 2011, 05:51 am Last Edit: Dec 28, 2011, 05:53 am by Graynomad Reason: 1
Quote
If you can afford 72 bytes for a sparse array lookup table and use a pointer instead of indexing into an array it should be faster
Code: [Select]
volatile BYTE vals [72] = {x,x,x,x,x,}; // put values in here, 0 if not used
volatile BYTE * j = digit;
ISR (SPI_STC_vect)
if (c == 96 && cp == 192) {
*j = 1;
} else if (c == 62 && cp == 127)
*j = 8;
*j = vals[c];
j++;
Not tested (or even compiled) and I'm sure the first two ifs could be removed with some thought and more knowledge of the data, but that has to be faster.
Also you are losing a hell of a lot of time just servicing the ISR, polling will be faster.
______
Rob
nickgammon
#10
Dec 28, 2011, 06:46 am Last Edit: Dec 28, 2011, 06:55 am by Nick Gammon Reason: 1
Well he says it works 95% of the time, so a bit of speed up in array lookups might help. And if he is using int rather than byte you could save a bit there.
However I agree with Rob, I reckon it takes around 3.5 uS to enter an ISR (we looked into it before, there are about 22 54 clock cycles involved) so if time is critical, polling would probably be faster. Of course you have to stop polling and do something with the results at some stage. If you do poll, you could turn off all interrupts (thus stopping the timer interrupts) which should make it more reliable.
nickgammon
#11
Dec 28, 2011, 06:52 am Last Edit: Dec 28, 2011, 06:55 am by Nick Gammon Reason: 1
I worked it out here:
http://arduino.cc/forum/index.php?topic=70625.21
54 cycles to enter the interrupt routine (3.38 uS). And roughly the same amount to leave it.
bill2009
naked_Isr can cut the entry time quite a bit.
Good point about the polling though.
graynomad
I've use a naked ISR before but in an app that had to save every reg in a known order so I used ASM pre/postambles.
How would naked work if you just had C code in the ISR? You couldn't use any variables or do anything except IO I would think.
______
Rob
nickgammon
You could be right there.
Anyway I await a response to reply #8. :)
