Loading...
Pages: [1]   Go Down
Author Topic: 'Generic' multiplexing out of arduino  (Read 779 times)
SP - Brasil
Offline Offline
Newbie
View Profile
Hello all,
I want to build a generic multiplexer for arduino, that would be capable of PWM controlling 8~16 outputs, for example.
I've read that the 4051/4067 are not recommendable, however I cannot find the reasons why. The 5940 seems ideal, but is too expensive and has a current output that I do not need (plan to use mosfets).
I have considered the 74hc374 and 74hc595, but they both seem to receive negative comments, not always specifying in what exactly they are not good.
I'm not expecting you to explain all of them to me, just maybe point some good reading resources, since most I could find were rather superficial.
[my knowledge in 'programming logic' and syntax is not very developed, please pardon my ignorance.]
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Your application doesn't really match the chips are you suggesting.
Except for the TLC5940 none of the chips you researched are viable for PWM outputs.  Part of the reason the TLC5940 costs what it does is that it provides 16-channels of PWM.
Logged
www.cmiyc.com - A guide to being an Enginerd
SP - Brasil
Offline Offline
Newbie
View Profile
hmmm, I see..
Are there any other chips besides the TLC5940 that would fit my application? Maybe a low power TLC5940?
Where can I look for alternatives? Maybe I'm googling the wrong words...
Thanks for the answer btw smiley
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Your application is entirely clear.
Do you have 8-16 channels of individually controllable PWM (at the same time)?
Or do you want a single PWM signal that you can send to 1 of 8-16 channels?
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Depends on what else you need to do with your CPU cycles but this is lower powered and cheap.
http://www.elcojacobs.com/shiftpwm/
Logged
SP - Brasil
Offline Offline
Newbie
View Profile
James,
what I want/need is 16 different channels of PWM ('simultaneous' and individually controlled), something like controlling a 4x4 LED matrix for example (not this case). I do not want to build a matrix every time I have to use this setup. It seems to be something of a "perfect" solution, at least to me, so I would understand if its something that does not exist. Maybe just too perfect... smiley-sad
Mike,
Thanks for your suggestion, I was looking for a "hardware" solution if possible, in some cases I might need extra CPU headroom. In any case I will try this solution, since it seems to be the one with best cost/benefit in simpler cases.
Logged
0
Offline Offline
Faraday Member
20 LEDs are enough
View Profile
WWW
You may want to look at my examples here: http://www.blinkenlight.net. Depending on the frequency requirements different solutions are possible. If binary PWM is acceptable this will give you a lot of CPU headroom. I am working on binary PWM examples but Google will find some for you right now.
Logged
Check out my experiments http://blog.blinkenlight.net
Pages: [1]   Go Up
Print
Jump to:
