Topic: mArduino Library (Read 525 times) previous topic - next topic
coopermaa
I wrote a mArduino library for Arduino.
mArduino is a simple library for Arduino.
mArduino uses multiple Arduinos and I2C Protocol to expand Arduino's IO capacity.
By using mArduino, master arduino can read and write slave's I/O very straightforwardly.
Master can make slave's LED in a nearly identical manner to writing an arduino sketch,
for example, the following sketch will blink slave's LED:
#include "Wire.h"      // You need to include both Wire.h and mArduino.h
#include "mArduino.h"
const int SLAVE_ADDRESS = 1;
const int ledPin = 13;
  mArduino();            // join I2C bus as a Master
  pinMode(SLAVE_ADDRESS, ledPin, OUTPUT);
  digitalWrite(SLAVE_ADDRESS, ledPin, HIGH);
  delay(100);
  digitalWrite(SLAVE_ADDRESS, ledPin, LOW);
  delay(100);
And here is a general slave sketch:
// General_slave.ino
// Refer to master examples for use with this
#include <Wire.h>          // You need to include both Wire.h and mArduino.h
  mArduino(SLAVE_ADDRESS);    // join I2C bus as a slave with address 1
For more information, see:
http://coopermaa2nd.blogspot.com/2011/12/marduino-arduino-i2c.html
coopermaa
Sorry I forgot to say where to get the library.
The mArduino library can be downloaded here:
https://github.com/coopermaa/mArduino
