Loading...
Pages: [1] 2 3 ... 5   Go Down
Author Topic: Arduino Uno Rev3 pinouts photo  (Read 36160 times)
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I'm not sure where to post this, but here goes ...
Below is a modified photo of the Uno Rev3 board, with annotations about the extra meanings of some pins (not printed on the board):
I personally find that when trying to hook up I2C or SPI, I can never remember which pin is SDA and which is SCL. Hopefully this photo will help others to quickly connect up their systems.
Earlier boards are similar except that they don't have the ICSP header for programming the USB interface chip, and the extra SDA/SCL sockets for use with I2C.
I find that the pins on the ICSP header (on the right) are useful for grabbing an extra +5/Gnd combination if I need to power other devices (or for hooking up a multimeter or logic analyzer).
« Last Edit: December 21, 2011, 08:02:01 pm by Nick Gammon » Logged
Offline Offline
Jr. Member
View Profile
Thanks for sharing!
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
You are welcome.
I've put the same photo on my website, with various annotations about what the abreviations (eg. I2C, SPI) mean, and some useful stuff about maximum ratings:
http://www.gammon.com.au/uno
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Quote
SCL = Simply Connect Last (at least on an Arduino 328)
SDA = Shouldbe Dhe Ather (The other)   smiley-wink
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
That mounting hole on the top left side was already hard to use and this time with the two additional pins it should be impossible to use now.
Logged
Colorado
Offline Offline
Edison Member
Reviving dead brain cells with Arduinos.
View Profile
Really?  I'm using that mounting hole just fine with an R2.  I suspect the R3 will be tight and might even require some shaving of the screw/bolt head, but it should still work just fine.
Logged
Grand Blanc, MI, USA
Offline Offline
Faraday Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
Nice job Nick. Working on breadboards a lot, I have a cheat sheet (attached) which shows the DIP pin numbers, the Arduino pin numbers, and the AVR pin names.
True that. I wonder why they felt compelled to add redundant I2C pins. I've found the existing ones to be quite adequate...
Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Centurion RSA
Offline Offline
Full Member
Arduino rocks
View Profile
Thanks for the cheat sheet Jack. I do a lot of stand alone development (not using the Arduino board) and I always have to look up the pins. This will help a lot.
Logged
Rather people think you to be a fool than you open your mouth and confirm it.
SF Bay Area (USA)
Online Online
Faraday Member
Strongly opinionated, but not official!
View Profile
Quote
multiple cpu compatibility.   It won't always be the case that the I2C shares pins with the ADC, and it would be nice to have shields that continue to work.
It's the same issue as SPI on the existing Uno vs MEGA.  The original ethernet shield assumed that the SPI pins were D13..11, and it didn't work with the MEGA at all, without stringing jumpers all over...
Logged
Offline Offline
Faraday Member
View Profile
WWW
Makes sense. Thanks.
Logged
Smithfield, Rhode Island
Offline Offline
God Member
View Profile
Dumb question... Did they change the USB interface chip and, why does its firmware need to be upgraded?
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
The older Uno had an Atmega8U2-MU USB interface. The Rev 3 Uno has an Atmega16U2-MU chip.
I presume the ability to upgrade the firmware is to allow for if it turns out to have some sort of bug, or maybe just for future expansion.
Logged
Greenville, IL
Offline Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
View Profile
 Here is a small part of the info from this link: http://www.ladyada.net/library/arduino/unofaq.html
  The USB controller chip has moved from an atmega8u2 (8K flash) to an atmega16u2 (16K flash). This does not mean that you have more flash or RAM for your sketches this upgrade is for the USB interface chip only. In theory this will mean that it will be easier to have low level USB interfaces such as MIDI/Joystick/Keyboard available. However these are only theoretical at this time, there is no example code or firmware which will actually do this.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Nick,  you didn't mention the extra pins on the power header. I think one has no connection the other is +5v also, tho not labelled that on the card.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
True, not on the photo. I mention the IOREF pin on the page I linked to.
Logged
Pages: [1] 2 3 ... 5   Go Up
Print
Jump to:
