Offline
Edison Member
Arduino rocks
« Reply #15 on: January 30, 2012, 02:05:16 am » |
I find that the pins on the ICSP header (on the right) are useful for grabbing an extra +5/Gnd combination if I need to power other devices (or for hooking up a multimeter or logic analyzer).
I generally use the giant USB socket for a gnd to connect my multimeter to.
Logged
Offline
Newbie
« Reply #16 on: February 05, 2012, 04:11:22 pm » |
Hey thanks alot for sharing, this is really useful.
(cool, and I am the 1970th person to view this)
« Last Edit: February 06, 2012, 04:26:52 am by opal_1970 »
Logged
0
Offline
Edison Member
Have you mooed today?
« Reply #17 on: February 16, 2012, 09:38:48 am » |
Have you already share this in the playground? It's very useful!
Logged
Colorado, USA
Offline
Newbie
« Reply #18 on: March 06, 2012, 02:22:50 pm » |
Please pardon the somewhat off topic post....
I just bought an R3 Uno and it has the DIP processor.
Are the surface mount versions out yet, and are there any advantages to the surface mount types?
Logged
Global Moderator
Boston area, metrowest
Offline
Brattain Member
Available for Design & Build services
« Reply #19 on: March 06, 2012, 03:14:24 pm » |
Surface mount was used on Unos when DIPs where in short supply for a while. Same die within each package. Surface mount does allow access to two analog-input only pins, but they are not connected to any header pins on the Uno. So really just a disadvantage when you smoke the chip by accident and need to replace it.
Logged
Global Moderator
Melbourne, Australia
Offline
Shannon Member
Lua rocks!
« Reply #20 on: March 06, 2012, 03:30:13 pm » |
I like the removable ones. After all, if you test new sketches every day (as I do) then you will wear it out eventually. Rather than buying a new board for $30 I can replace the processor for $5. Similarly if I do something silly and burn out an output pin.
When you are ready to go you can buy one of the surface-mounted "tiny" versions that will be physically smaller and do the same things.
Logged
Offline
Edison Member
You do some programming to solve a problem, and some to solve it in a particular language. (CC2)
« Reply #21 on: March 06, 2012, 03:36:44 pm » |
Thanks Nick, that photo is useful. A very good page on your site, too.
Logged
ਪੰਜਾਬ
Offline
Edison Member
WANTED! A Girl with LOVE for me and Arduino!
« Reply #22 on: March 13, 2012, 11:06:21 pm » |
JP 2 is for?
Logged
"Real Men can Accomplish Anything" - Website - skype : nishants5 ਫ਼ਤੇਹ ਕਰੂਂ !
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #23 on: March 13, 2012, 11:21:55 pm » |
I wondered that when I was doing the picture. See this: http://arduino.cc/forum/index.php?topic=83829.0
Logged
Canada
Offline
Sr. Member
« Reply #24 on: March 26, 2012, 07:42:13 pm » |
Thanks for the pictorial doc.
BTW, what is the scoop on why they the second access to A4 and A5 (SCL & SDA). Why would they be needed twice?
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #25 on: March 26, 2012, 08:00:37 pm » |
On the Mega SDA and SCL are in different spots. I am guessing they wanted to make it so shields could be compatible with both the Mega and the Uno if they use I2C.
Logged
Global Moderator
Offline
Brattain Member
« Reply #26 on: March 26, 2012, 08:18:58 pm » |
paraphrasing Blazing Saddles: "You said I2C twice." "I like I2C."
« Last Edit: March 26, 2012, 08:20:55 pm by CrossRoads »
Logged
Dallas, TX USA
Offline
Edison Member
« Reply #27 on: March 27, 2012, 02:23:10 pm » |
I actually prefer what Seeeduino and iTeeduino did for i2c on their boards by providing a separate 4 pin header. That way everything you need is there with a simple 4 pin connector/cable and you can still use it even when a shield is being used.
--- bill
Logged
Offline
Newbie
« Reply #28 on: April 12, 2012, 10:11:24 am » |
Below is a modified photo of the Uno Rev3 board, with annotations about the extra meanings of some pins (not printed on the board): Earlier boards are similar except that they don't have the ICSP header for programming the USB interface chip, and the extra SDA/SCL sockets for use with I2C.
Are the I2C pins on the D8-D13 header the same as the ones on A4 and A5? If so, are these in the same place as on a Mega because the A4 and A5 pins moved to D20 and D21 on the Mega and that's a pain for building a shield. Thanks
Logged
Global Moderator
Offline
Brattain Member
« Reply #29 on: April 12, 2012, 08:03:53 pm » |
"Are the I2C pins on the D8-D13 header the same as the ones on A4 and A5?" On Uno, Yes.
"are these in the same place as on a Mega because the A4 and A5 pins moved to D20 and D21" No. Mega has seperate functions pins for I2C, are not on A4/A5.
Logged
