Topic: Arduino Uno Rev3 pinouts photo (Read 255092 times) previous topic - next topic
testato
#60
Apr 16, 2013, 01:08 pm Last Edit: Apr 16, 2013, 01:11 pm by Testato Reason: 1
I've put the same photo on my website, with various annotations about what the abreviations
http://www.gammon.com.au/uno
Hi Nick, on your website correct this
Quote
giving a reading between 0 (for 0V) and 1024 (for 5V) using the analogRead function
to:
Quote
between 0 and 1023  ;)
bie
- [Guida] IDE - http://goo.gl/ln6glr
- [Lib] ST7032i LCD I2C - http://goo.gl/GNojT6
- [Lib] PCF8574+HD44780 LCD I2C - http://goo.gl/r7CstH
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
arduinomagbit
there really is so many thing to learn....
I'm not sure where to post this, but here goes ...
Below is a modified photo of the Uno Rev3 board, with annotations about the extra meanings of some pins (not printed on the board):
I personally find that when trying to hook up I2C or SPI, I can never remember which pin is SDA and which is SCL. Hopefully this photo will help others to quickly connect up their systems.
Earlier boards are similar except that they don't have the ICSP header for programming the USB interface chip, and the extra SDA/SCL sockets for use with I2C.
I find that the pins on the ICSP header (on the right) are useful for grabbing an extra +5/Gnd combination if I need to power other devices (or for hooking up a multimeter or logic analyzer).
Cactusface
Hi Nick,
              To someone like me who only just took up the Arduino  and had my Uno for about 3 days, that printout is going to be very useful!!  All I have to do now is learn C? Well I'm getting there a few simple things, but lots to learn..
Regards
Mel.
Open your mind! But not too far, your brains might fall out.
Also like Photography, model building and my 300+ Cacti and Succs.
tlharv
Some great information here... I've been using Nick's guide at http://www.gammon.com.au/forum/?id=11637 to successfully bootload the ATMega328P-PU and get a sketch uploaded using an FTDI friend.  Thanks for making such clear instructions, Nick!
Jack, great excel-version pinout of the '328.  Is this pinout the same whether it's bootloaded at 8MHz (Lilypad) or 16MHz (using an external resonator)?
Thanks!
Tom
nickgammon
The speed won't affect anything except ... speed. Nor will the bootloader. That is just for getting new code on the board.
terryking228
Hi Nick,
Nice work on this helpful graphic. To say nothing of all the other great info I use on your site.
May I use this image on the ArduinoInfo.Info WIKI? I'd also link back to your page...
Other, if you have time, please take a look at this beginning discussion of Timer Conflicts:
http://forum.arduino.cc/index.php?topic=199930.0
Thanks!
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
nickgammon
cjdelphi
Quote
SCL = Simply Connect Last (at least on an Arduino 328)
SDA = Shouldbe Dhe Ather (The other)   ;)
Lol I came up with my own rule, but yours makes morse sense...
C before D.
SkobyMobil
Hi there,
http://pighixxx.com/unov3pdf.pdf
http://pighixxx.com/atmega328v3_0.pdf
http://pighixxx.com/atmega382mlfv3_0.pdf
Greeting and fun
Andreas
die zweite Maus bekommt den Speck...
irishcream24
#70
Mar 11, 2015, 01:44 pm Last Edit: Mar 11, 2015, 01:45 pm by irishcream24
This might have been answered elsewhere, but what can you do with the "ICSP for USB interface" pins?
testato
flash a new firmware on the usb controller chip.
It is an Atmel mcu and you can do whit it many more that a simple usb to serial converter  ;)
CrossRoads
They connect in parallel to D11-12-13, Reset, +5, Gnd.
1 or 2 shields connect to those pins to grab those signals.
I would agree with Testato, generally just used for burning bootloader onto blank parts, and direct programming with no bootloader via File:Upload Using Programmer command.
testato
No CrossRoads,
he speak about the ICSP for the 8/16u2  ;)
irishcream24
so am I understanding this right then, that the 6 set of pins on the right of the board does exactly the same as the 6 on the top left?
