Topic: Arduino Uno Rev3 pinouts photo (Read 268383 times) previous topic - next topic
nickgammon
Dec 21, 2011, 11:32 pm Last Edit: Sep 29, 2016, 06:59 am by Nick Gammon
I'm not sure where to post this, but here goes ...
Below is a modified photo of the Uno Rev3 board, with annotations about the extra meanings of some pins (not printed on the board):
I personally find that when trying to hook up I2C or SPI, I can never remember which pin is SDA and which is SCL. Hopefully this photo will help others to quickly connect up their systems.
Earlier boards are similar except that they don't have the ICSP header for programming the USB interface chip, and the extra SDA/SCL sockets for use with I2C.
I find that the pins on the ICSP header (on the right) are useful for grabbing an extra +5/Gnd combination if I need to power other devices (or for hooking up a multimeter or logic analyzer).
ProfePaco
nickgammon
You are welcome.
I've put the same photo on my website, with various annotations about what the abreviations (eg. I2C, SPI) mean, and some useful stuff about maximum ratings:
http://www.gammon.com.au/uno
robtillaart
SCL = Simply Connect Last (at least on an Arduino 328)
SDA = Shouldbe Dhe Ather (The other)   ;)
Rob Tillaart
liuzengqiang
That mounting hole on the top left side was already hard to use and this time with the two additional pins it should be impossible to use now.
KirAsh4
Really?  I'm using that mounting hole just fine with an R2.  I suspect the R3 will be tight and might even require some shaving of the screw/bolt head, but it should still work just fine.
JChristensen
Nice job Nick. Working on breadboards a lot, I have a cheat sheet (attached) which shows the DIP pin numbers, the Arduino pin numbers, and the AVR pin names.
True that. I wonder why they felt compelled to add redundant I2C pins. I've found the existing ones to be quite adequate...
mariusl
Thanks for the cheat sheet Jack. I do a lot of stand alone development (not using the Arduino board) and I always have to look up the pins. This will help a lot.
Rather people think you to be a fool than you open your mouth and confirm it.
westfw
multiple cpu compatibility.   It won't always be the case that the I2C shares pins with the ADC, and it would be nice to have shields that continue to work.
It's the same issue as SPI on the existing Uno vs MEGA.  The original ethernet shield assumed that the SPI pins were D13..11, and it didn't work with the MEGA at all, without stringing jumpers all over...
JChristensen
skyjumper
Dumb question... Did they change the USB interface chip and, why does its firmware need to be upgraded?
nickgammon
The older Uno had an Atmega8U2-MU USB interface. The Rev 3 Uno has an Atmega16U2-MU chip.
I presume the ability to upgrade the firmware is to allow for if it turns out to have some sort of bug, or maybe just for future expansion.
cyclegadget
Here is a small part of the info from this link: http://www.ladyada.net/library/arduino/unofaq.html
  The USB controller chip has moved from an atmega8u2 (8K flash) to an atmega16u2 (16K flash). This does not mean that you have more flash or RAM for your sketches this upgrade is for the USB interface chip only. In theory this will mean that it will be easier to have low level USB interfaces such as MIDI/Joystick/Keyboard available. However these are only theoretical at this time, there is no example code or firmware which will actually do this.
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
CrossRoads
Nick,  you didn't mention the extra pins on the power header. I think one has no connection the other is +5v also, tho not labelled that on the card.
nickgammon
True, not on the photo. I mention the IOREF pin on the page I linked to.
