Topic: Arduino Uno Rev3 pinouts photo (Read 216353 times) previous topic - next topic
WizenedEE
I find that the pins on the ICSP header (on the right) are useful for grabbing an extra +5/Gnd combination if I need to power other devices (or for hooking up a multimeter or logic analyzer).
I generally use the giant USB socket for a gnd to connect my multimeter to.
opal_1970
#16
Feb 05, 2012, 10:11 pm Last Edit: Feb 06, 2012, 10:26 am by opal_1970 Reason: 1
Hey thanks alot for sharing, this is really useful.
(cool, and I am the 1970th person to view this)
pictux
Have you already share this in the playground?
It's very useful!
sellonoid
Please pardon the somewhat off topic post....
I just bought an R3 Uno and it has the DIP processor.
Are the surface mount versions out yet, and are there any advantages to the surface mount types?
CrossRoads
Surface mount was used on Unos when DIPs where in short supply for a while.
Same die within each package.
Surface mount does allow access to two analog-input only pins, but they are not connected to any header pins on the Uno.
So really just a disadvantage when you smoke the chip by accident and need to replace it.
nickgammon
I like the removable ones. After all, if you test new sketches every day (as I do) then you will wear it out eventually. Rather than buying a new board for $30 I can replace the processor for $5. Similarly if I do something silly and burn out an output pin.
When you are ready to go you can buy one of the surface-mounted "tiny" versions that will be physically smaller and do the same things.
More info:
tuxduino
Thanks Nick, that photo is useful. A very good page on your site, too.
Nishant_Sood
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
nickgammon
I wondered that when I was doing the picture. See this:
http://arduino.cc/forum/index.php?topic=83829.0
More info:
BillO
Thanks for the pictorial doc.
BTW, what is the scoop on why they the second access to A4 and A5 (SCL & SDA).  Why would they be needed twice?
nickgammon
On the Mega SDA and SCL are in different spots. I am guessing they wanted to make it so shields could be compatible with both the Mega and the Uno if they use I2C.
More info:
CrossRoads
#26
Mar 27, 2012, 03:18 am Last Edit: Mar 27, 2012, 03:20 am by CrossRoads Reason: 1
paraphrasing Blazing Saddles:
"You said I2C twice."
"I like I2C."
bperrybap
I actually prefer what Seeeduino and iTeeduino did for i2c on their boards by providing a separate 4 pin header.
That way everything you need is there with a simple 4 pin connector/cable and you can still
use it even when a shield is being used.
--- bill
nigeljohnson73
Below is a modified photo of the Uno Rev3 board, with annotations about the extra meanings of some pins (not printed on the board):
Earlier boards are similar except that they don't have the ICSP header for programming the USB interface chip, and the extra SDA/SCL sockets for use with I2C.
Are the I2C pins on the D8-D13 header the same as the ones on A4 and A5? If so, are these in the same place as on a Mega because the A4 and A5 pins moved to D20 and D21 on the Mega and that's a pain for building a shield.
Thanks
CrossRoads
"Are the I2C pins on the D8-D13 header the same as the ones on A4 and A5?"
On Uno, Yes.
"are these in the same place as on a Mega because the A4 and A5 pins moved to D20 and D21"
No.
Mega has seperate functions pins for I2C, are not on A4/A5.
