Topic: Serial Midi Converter (Read 8928 times) previous topic - next topic
AspireBear
Dec 22, 2011, 12:40 am Last Edit: Dec 22, 2011, 01:02 pm by AspireBear Reason: 1
:smiley-roll-sweat:
Hello,
I am making a midi drum and I have finished building it but my problem is that Serial MIDI Converter flashes me a red light on the Serial RX. From what I understand is that it should be showing a green light to show that it is receiving a midi signal. What does a midi line look like? I am running code that I found online:
// User settable variables
unsigned char PadNote[6] = {60,61,62,63,64,65};         // MIDI notes from 0 to 127 (Mid C = 60)
int PadCutOff[6] = {900,900,900,900,900,900};           // Minimum Analog value to cause a drum hit
int MaxPlayTime[6] = {90,90,90,90,90,90};               // Cycles before a 2nd hit is allowed
#define  midichannel 0;                              // MIDI channel from 0 to 15 (+1 in "real world")
boolean VelocityFlag  = true;                           // Velocity ON (true) or OFF (false)
// Internal Use Variables
boolean activePad[6] = {0,0,0,0,0,0};                   // Array of flags of pad currently playing
int PinPlayTime[6] = {0,0,0,0,0,0};                     // Counter since pad started to play
unsigned char status;
int pin = 0;
int hitavg = 0;
// Setup
 Serial.begin(57600);                                  // connect to the serial port 115200
// Main Program
 for(int pin=0; pin < 6; pin++)
   hitavg = analogRead(pin);                              // read the input pin
   if((hitavg > PadCutOff[pin]))
     if((activePad[pin] == false))
       if(VelocityFlag == true)
//          hitavg = 127 / ((1023 - PadCutOff[pin]) / (hitavg - PadCutOff[pin]));    // With full range (Too sensitive ?)
         hitavg = (hitavg / 8 ) -1 ;                                                 // Upper range
         hitavg = 127;
       MIDI_TX(144,PadNote[pin],hitavg);
       PinPlayTime[pin] = 0;
       activePad[pin] = true;
       PinPlayTime[pin] = PinPlayTime[pin] + 1;
   else if((activePad[pin] == true))
     if(PinPlayTime[pin] > MaxPlayTime[pin])
       activePad[pin] = false;
       MIDI_TX(128,PadNote[pin],127);
// Transmit MIDI Message
void MIDI_TX(unsigned char MESSAGE, unsigned char PITCH, unsigned char VELOCITY)
 status = MESSAGE + midichannel;
 Serial.print(status);
 Serial.print(PITCH);
 Serial.print(VELOCITY);
Any ideas on how to resolve my issue?
Grumpy_Mike
Please modify that post. Select the code  and hit the # icon and save.
Next how have you got this wired up ?
It is not outputting at MIDI speeds so it must be sending stuff straight into the serial port. What application have you got that translates this into MIDI?
AspireBear
#2
Dec 22, 2011, 01:17 pm Last Edit: Dec 22, 2011, 01:27 pm by AspireBear Reason: 1
I did the following:
With the grounds from the piezos connected to one ground.
And I am using Serial Midi Converter on my Macbook, configured like so:
http://spikenzielabs.com/SpikenzieLabs/Serial_MIDI.html
And that is where my data shows that it is not midi formated... Are there better Midi apps for mac?
I tried changing my baud rate to 31250 and had the same problem.
Edit: I tried again with a baud rate of 31250 and Serial Midi Converter freezes when i select my output...
Grumpy_Mike
What version of the arduino IDE are you running?
Recent changes might make it not work.
Try replacing that function at the end with this:-
  Serial.write(status);
  Serial.write(PITCH);
  Serial.write(VELOCITY);
AspireBear
Wow! Your the best! That made all the difference, I fiddled with my settings in Ableton Live and now it works with that new line of code!
What I changed in Ableton was the in the Preferences > MIDI Sync and turned on all IAC Input and Output (Track & Remote) and it works!
Now I can drum away  :)
Thanks Grumpy_Mike.
Thot
#5
Nov 11, 2012, 09:13 pm Last Edit: Nov 12, 2012, 04:56 am by Thot Reason: 1
Grumpy_Mike, you are a genius!   :)
P.S. After thinking about it, I understand why this works and the previous version doesn't.
But I am puzzled on why did the previous version worked with older board, if it did.
There are three kind of people in the world: Those who can count, and those who can't
