Topic: Strange characters on Arduino Ethernet? (Read 2098 times) previous topic - next topic
darthsimon123
Dec 25, 2011, 02:07 pm Last Edit: Dec 29, 2011, 05:48 pm by darthsimon123 Reason: 1
Hello,
I recently bought me the Arduino Ethernet board and I've just started trying the examples. But there's a problem:
No matter what (Ethernet)sketch I upload to the Arduino, it always returns some strange text when I try to telnet to the Arduino.
This text contains sometimes the message I'd like to send, but mostly characters which look that what you see when you have an invalid Baud-Rate on a serial port.
For example:
2??j`?u?t@???}A#?9aw??a?F??
        ?0????&Z?????<??Pp?[E?:?#?EDW??Y_???????=X??]Cr??????y?T1)P?? ??"??=??u?)(L\?QH?f?D`?Z?'"Z?9???$????Z????LQ???5??By ?w?0&???
e??0????????X?NB4??/?X(?87???6A1?l?4?-rT]v????????Y?#?Y??R?V???Z-?~?3oV9Uk ????D??- ????m???}???>2?(??`?Sx??w?n??8?:???lPQ?'??~?>J????96???l?kU]T9?`(
          ?Y[C??5???<??p=?#?
!??k???*??X?+?~<!?????m8j?
</tr>
</table>
<br>
<form method=get><input type=submit name=all value='Alles aus'></form>
</body></html>
2222'><form method=get><input type=submit name=4 value='ausschalten'></form></td>
<td align='center'><font color='#CFCFCF' size='5'>OFF
</tr>222'><form method=get><input type=submit name=4 value='einschalten'></form></td>?o?y???8???A???DH?y???J??j1???HP?*?1????g`O 1??'??a???<#f?X??Y???W??5 ?S?gQ? 9?TL,v?u5?K5?a`
                                                  {n??N
                                                       O?v
Z$?KC\I??q??$????S?F\??h?X,c?q?P?bX??y?U\? ?I
                                                     oG&?j??&?r%?(?`!rWl?VP
D?o?%?\?Vr<?x?R?]t?7}&t??WU???~*?i?3?~E!???#C-AP?D+???x???
        ?%,a???.(P????k6"?!???/x?J
            ??nLKt!kb???Q??W?3? ?-?)??s???@A]\Ij??=????s;??b??wR"Z?????0n`??~?4?'
?=Fdb$?A h???V?_????9?[?Ed?3??z???inL9??
In this case, you can see what I wanted to send, it was some HTML.
The problem occurs with every sketch I've tryed, even with the examples of the Ethernet library.
Any idea where my problem is?
PS: Excuse my bad english, I'm from Germany
SurferTim
That could be the microSD card reader SPI interfering with your ethernet SPI.
  pinMode(4,OUTPUT); // set SD SPI slave select pin to OUTPUT
  digitalWrite(4,HIGH); // disable SD SPI interface. HIGH is disabled.
  // now do your ethernet setup stuff.
darthsimon123
#2
Dec 25, 2011, 03:48 pm Last Edit: Dec 25, 2011, 04:04 pm by darthsimon123 Reason: 1
I tried your suggestion, it didn't work.
Here is the sketch I've tried:
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x90, 0xa2, 0xda, 0x00, 0x61, 0xf1 };
IPAddress ip(10,42,43, 2);
EthernetServer server(80);
 // start the Ethernet connection and the server:
 Ethernet.begin(mac, ip);
 server.begin();
 if (client) {
   client.println("Hello World!");
   client.stop();
Maybe it has to do something with my setup?
I've got a notebook with an UMTS internet stick. On this notebook, I share the UMTS connection to the Arduino, which is connected using a normal patch cable. This is supported by my network adapter (I've tried it with other computers).
The Arduino has the static IP-Address you can see in the sketch and it is powered through USB.
EDIT:
Maybe it's a problem with the memory? I've changed the string in client.println() and it outputs me the old string + the new string...
bubulindo
Maybe you have too many strings in memory? Have you tried sending the bare minimum and see if this happens again?
This... is a hobby.
darthsimon123
The same: The old string is displayed + the new string + the strange characters
Grag38
What kind of arduino is the main board ? Uno, Mega ?
darthsimon123
As I said:
It is this one here http://www.arduino.cc/en/Main/ArduinoBoardEthernet
Another thing: I think those characters are not as random as they look. They're almost the same every time they are transmitted.
zoomkat
You are trying to access the arduino http server using a telnet application?
darthsimon123
#8
Dec 25, 2011, 06:56 pm Last Edit: Dec 25, 2011, 07:01 pm by darthsimon123 Reason: 1
Yes.
It (should) work. Telnet only sends text over the network, if you run
telnet www.google.com 80
for example, you can "talk" HTTP to Google.
But even when I run the "ChatServer"-Example (which explicitly sais "To use telnet to  your device's IP address and type.") it doesn't work.
zoomkat
When I try the the telnet, I get the below, much of which appears to be the binary conents of the "image/png;base64,".
HTTP/1.0 400 Bad Request
Content-Type: text/html; charset=UTF-8
Content-Length: 11782
Date: Sun, 25 Dec 2011 20:14:59 GMT
Server: GFE/2.0
<!DOCTYPE html>
               <html lang=en>
                               <meta charset=utf-8>
                                                     <title>Error 400 (Bad Reque
st)!!1</title>
                <style>
                           *{margin:0;padding:0}html,code{font:15px/22px arial,s
ans-serif}html{background:#fff;color:#222;padding:15px}body{background:url(data:
image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAKsAAADVCAMAAAAfHvCaAAAAGFBMVEVYn%2BH%2
F%2F%2F%2Bex%2B3U5vd7s%2Bfq8%2Fs0itq72PMLUPvtAAASvklEQVR4AbXBC0JqCQxEwT5Jd7L%2FH
c8FdR4g%2BEGtEr8u%2FBHxu7otdzd%2FQPyqlmRp1Pw%2B8aukDfRa1fw28ZtWy4sa89vEb7LCi0zx2
8RvqgkvouW3id%2FU8pbtWmv5beJXRWNrRmp%2BnfhlHXZm%2BQPi95Vk%2FoD4fZbMHxC%2FryTzB8T
darthsimon123
Have you typed
GET / HTTP/1.1
Host: www.google.de
[empty line]
But I think this is not the problem! I've tried the SD library, and it doesn't work too. I have set the SS port for the Wiznet chip (10) to high, as you suggested for the SD card, but the lamps of the RJ45 connector were blinking. So I think there's a general problem with the SPI.
zoomkat
Sorry, but I do not understand what you are actually trying to do.
darthsimon123
#12
Dec 27, 2011, 11:36 am Last Edit: Dec 29, 2011, 05:48 pm by darthsimon123 Reason: 1
OK, ignore this post. It was my fault.
EDIT:
Probably got a solution! See here http://arduino.cc/forum/index.php?topic=81846.0.
It's a bug in gcc.
Another edit:
Got it working now, using the solution prowided here: http://code.google.com/p/arduino/issues/detail?id=605&start=200
No the Ethernet part works, but not the SD...
I think I've set all the CS lines to the SD card an the W5100 correct, but the initialisation always fails. I've also tried using the card.init() function with a CS port specified, didn't work even. Any suggestions what I'm doing wrong?
