Topic: External crystal for Attiny85 (Read 14282 times) previous topic - next topic
ProfePaco
Dec 25, 2011, 04:36 pm Last Edit: Dec 25, 2011, 04:39 pm by ProfePaco Reason: 1
I would like to employ an external 20MHz crystal for Attiny85.
I see that the crystal must be attached to pins 2 and 3. And datasheet gives us recommended values for the capacitors. OK.
However, the question is, pins 2 and 3, cannot be used for inputs/outputs if an external crystal is present?
Thanks in advance
runaway_pancake
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
spycatcher2k
Hi - You can use the pins as I/O if you do not use a crystal, You can set the chip to use an internal 8Mhz (or 1Mhz with divide by 8 set). OR run the chip at upto 20Mhz with the crystal & caps.  Having built over 100 projects with 45/85 chips, I have not used a crystal setup yet (other than on my programming board,  just incase I set the fuses to use external clock).
Drew.
http://www.uk-pcb.co.uk - My UK Based PCB Fab & Assembly Company
Design & Assembly work undertaken - Arduino repairs & testing - PM for details. PM me for non repair or testing, 1 to 1 support and I will charge you - beware!
ProfePaco
Yes... however in my case I need a lot of power because I have to make 3 FFT from 3 microphones continuously... so 20MHz better than 8. But I do not have pins enough if I use a external crystal.
I need 3 analogs input for the mics and one pin for sending the information to another Arduino.
borref
The AtTiny85 has a PLL circuit that can be used as a system clock source for 16MHz (64MHz / 4) operation. All you need is to program the approriate clock select fuse.
guardian_of_light
Wow, thanks, that is mighty good to know.
putyn
http://www.obdev.at/products/vusb/easylogger.html here is an example of the attiny45 (but could be used on attiny85)  used with its internal oscillator at 16.5Mhz if you download the source code youll see how that its done
hope this helps
ProfePaco
falcon74
If I am not mistaken, FFT on a single channel it a quite a stretch on a ATmega328 (Arduino) at 20MHz, so 3 channel FFT with tiny45/85, is it realistic ?
naut
old topic, but related question:
If I want to use the SoftwareSerial library with an Attiny85 I would use an external 20Mhz crystal?
Erni
Or tune the internal osccilator
http://forum.arduino.cc/index.php?PHPSESSID=02dq48s3merutqi5fnfgdll743&topic=183180.msg1357164#msg1357164
john1993
20mhz (actually 30mhz) is no problem for t85 using pll and oscal reg. however w/o a hardware multiplier fft would be hard.
