Topic: l293d problem (Read 905 times) previous topic - next topic
kiriti
Dec 26, 2011, 03:54 am Last Edit: Dec 26, 2011, 04:35 am by kiriti Reason: 1
hey guys, im not able to drive a single motor with l293d
i am using 4 AA batteries connected in series to drive a motor. motor runs when it is directly connected to battery.
so from above figure i connected :-
pin 1 to arduino pin 11
pin 2 to arduino pin 7
pin 7 to arduino pin 2
shorted both grounds pins 4 and 5, connected AA battery -ve to ground, arduino ground also to ground of l39d
connected aa battery +ve to 8
connected motor to the 2 terminals  3 and 6
and im using this simple code just to check if its working
int a = 11;
int b = 7;
int c = 2;
 pinMode(a, OUTPUT);
 pinMode(b, OUTPUT);
 pinMode(c, OUTPUT);
 digitalWrite(a, HIGH);
 digitalWrite(b, LOW);
 digitalWrite(c, HIGH);
but it does not work, what mistake am i doing?
John_S
Try connecting +5V to pin 16.
Pin 16 is the chip logic power supply (+5V only).
Pin 8 is the power supply for the motors (+5 to +36V).
http://jsrintervalometers.blogspot.ca
kiriti
connected 5v to 16, still not workin
John_S
Maybe post a clear picture of your setup?
kiriti
guys sorry, my breadboard was the damn problem!!!!
its vertical rails are not connected there is a disconnection in between!!!
same thing with all the 4 vertical rails :|
kiriti
guys can i apply the PWM signal to enable 1 on the l293d to get desired speed????
JasonK
the official rev 3 board does that (different chip)
http://mcukits.com/2009/03/12/assembling-the-freeduino-arduino-motor-shield/ does also
I looked at the spec sheet and it looks like an acceptable thing to do
dc42
Yes.
