Topic: Grounding Multiple LEDs (Read 3042 times) previous topic - next topic
Ithilistar
Dec 26, 2011, 11:52 pm Last Edit: Dec 26, 2011, 11:55 pm by Sean Duffy Reason: 1
Hello,
I'm new to Arduino and new to Electronics and circuit building, and I'm planning as one of my first projects to connect a few, probably three, LEDs to my Arduino, and trigger them to blink at different times. I know how to handle the programming side of things, but I just need some help on how to connect the LEDs.
I'm going to connect each LED to its own output pin, perhaps 10, 11 and 12 for example, and place a 1k? resistor between each LEDs anode and its assigned output pin. However, I'm a little confused about where to ground each LED. Is it okay to connect all three of the LED's cathodes to a single wire, going into a single ground pin, or will I have to make use of three ground pins?
Thanks in advance,
Sean. :)
Onions
Yes, connect the three cathodes together and use one wire to ground. All the arduino's ground pins are connected to one Gnd connection of the power supply, so it makes no difference how many wires it goes through to get there.
Good to see you remembered the resistors! If the LEDs are too dim, try a 330 ohm resistor.
Onions.
My website: http://www.harryrabbit.co.uk/electronics/home.html Up and running now! (Feel free to look round!) :D
Ithilistar
Thanks for the reply, I'll bear that in mind!
