Loading...
Pages: 1 [2]   Go Down
Author Topic: Tell me why I shouldn't throw the Uno out the window  (Read 1205 times)
Offline Offline
Newbie
View Profile
avrdude: stk500_getsync(): not in sync: resp=0x00
I'm not sure why you would be getting the error since you only mention the single Uno board but I can easily bring up that error message by plugging the USB cable into a different (clone) Arduino Uno but still plugged into the same PC USB port.  I don't know if it happens with two "genuine" Arduino boards or if it's because one is a clone but Windows invariably changes the COM port number.
If I forget to change to port number in the IDE, I initially get an error dialogue box asking me to check the COM port.  However, if I then select the correct port and try to upload a sketch without restarting the IDE, I get that same error message:
I tend to think it's more a Windows issue than an Arduino.
John.
Logged
Montreal
Offline Offline
Full Member
Arduino rocks
View Profile
did you connect something on pin TXD or RXD
That would prevent a download to your UNO
Logged
Patgadget
Montreal
Global Moderator
Melbourne, Australia
Online Online
Shannon Member
Lua rocks!
View Profile
WWW
Quote
It looks as though if I were to use Arduino I have to get rid of the bootloader and step back into the world of printer ports and DOS command lines which I thought I'd left for good.
I'm not sure I understand this comment. What have printer ports got to do with it?
You said it was working, and now it isn't. Quite possibly you broke it. There are a few things to consider. There is a maximum current you can draw from one pin, and a maximum from a group of pins. Also a maximum for the chip in general. These are documented in the data sheet for the device. Also if you happened to be testing a motor without reverse protection diodes you may have blown something.
This site documents a number of ways (10) you can destroy your chip:
http://ruggedcircuits.com/html/ancp01.html
However to be fair, you can destroy any chip if you are not careful. Personally I haven't destroyed any, and this includes after I have been drinking. smiley-wink
You can throw your Uno out the window if you want to. And then in a couple of months you might be throwing out your Microchip evaluation board.
I have a number of them sitting around my house doing things like monitoring if the garage door is open. I have to say that they are completely reliable.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
