Topic: Do you make your own arduino's? (Read 8385 times) previous topic - next topic
Odisej
Nov 25, 2009, 10:48 pm Last Edit: Nov 25, 2009, 10:50 pm by Odisej Reason: 1
just been wondering, has anyone else been doing he's (or her's) arduino's? If I count all that I have done at home, it goes like this:
4x serial single sided
5x serial double sided
3x freeduino (with USB ftdi chip)
And here they are, some of them that stayed at home (and two still waiting to be assambled)
Regards,
Peter
Tchnclfl
You should probably have posted this in Development or Bar Sport for better results, but I suppose posting it here was accurate, as you are exhibiting your boards as well as asking others.
On topic though:  No, I have never made my own board :).  I'm still getting comfortable with Arduino, but maybe once I really get it entirely, I'll make my own clone.  I also don't have regular access to things like a Laser Printer or UV Exposure box, so that's contributed as well. :P
Ro-Bot-X
Since I build robots, I needed a board that is designed a bit different, or I needed to use shields. First option was cheaper and more appealing, so I have recently designed R-Dev-Ino, a Robotic Development Arduino (software) compatible board. It relates more to a Nano, as it doesn't have a FTDI on board. It has all digital and analog pins on one side, with power  and ground pins next to them and the I can chose which group of pins gets regulated or unregulated power. At the top of the board there are the ISP and FTDI connectors and at the bottom there are the power connectors. The fourth side features a double mirrored I2C connector so the boards can be stacked directly or sideways. Below the I2C connector there is a small prototyping area so I can customize it depending on my needs. I am using 4 R-Dev-Ino boards on my robot and I'm very pleased how well they work. I am uploading code using a Basic FTDI board from SparkFun.
Here are some pictures:
bill2009
I've made several boards, mostly using variations on the circuit of the RBBB from modern device company adding or subtracting bits as required for my project of the day.
The_Bongmaster
I have made a few custom boards based on minimalist designs and using perfboard.
but my fav board at the moment has to be the RBBB for its size and simplicity and lack of bugs XD
pics of couple of my customs:
had to try it at least XD works nicely..
one of my 1st custom boards that is now being turned into a robot board,
attached behind it is a 6 transistor (3904, 3906) H-bridge pair.
pluggy
#5
Nov 28, 2009, 11:28 am Last Edit: Nov 28, 2009, 11:31 am by stephen_t Reason: 1
Something I posted a while back :
The SCABRS :
No laser printer, exposure box or etching tank required ;)
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1253997649
http://pluggy.is-a-geek.com/index.html
The_Bongmaster
@pluggy
whats that thing on top of it? :)
Tchnclfl
Quote
It's an RF transmitter.  See his original thread:
jdoll
If I am thinking of making a circuit board for a shield, I find it quite easy to plop down a microprocessor footprint and associated circuitry right on the board.  With this approach, no Arduino board is necessary.
For programming, it is easy to tack solder the 5 connections for an external serial USB board, creating a temporary programming dongle.  Plug in a processor with a boot loader, tell Arduino's IDE you're connecting to a Duemilanove with 168 or 328, and it uploads your code and supports serial communications just as if you're using a real Arduino board.  This approach worked fine for an update of my Arduino Whole House Telephone Intercom.
See http://joes.com/intercom/update.html for a 3D CAD rendering of the board.  Since that page was posted, I have built a working copy and programmed it using this technique.
whosawhatsis
I've made a bunch of them. Here are some pics:
More in this thread.
ao
I prototype w/ a regular Arduino USB board, then make a custom perf. board for permanent projects.
Andrew
I love that last picture of the Thumbduino on top of its namesake. This thread (and others) really show how successful and adaptable the Arduino design/concept has been - the creators must be very pleased.
Andrew
jds
#12
Jan 27, 2010, 08:13 am Last Edit: Jan 27, 2010, 08:45 am by jds Reason: 1
@bong_master
Quote
That was the small Arduino I was looking for some time ago... I am about to do something similar soon, but using a footer.
Edit: hmm, image doesn't show up....
The_Bongmaster
#13
Jan 27, 2010, 10:54 am Last Edit: Jan 27, 2010, 10:55 am by The_Bongmaster Reason: 1
did u put the image url in img tags like this:
Code: [Select]
[img]http://i29.photobucket.com/albums/c267/the_bongmaster/PICT1598.jpg[/img]
jds
yes, I did... I copied the url from your image between the img-tags, but it didn't show the picture. Maybe because it is in a code-tag block?
lets try again, without code tag block:
