Pages: [1] 2   Go Down
Author Topic: Mil-sim Airsoft Bomb Prop  (Read 3808 times)
Maine
Caution: Explosives in use.
First of all, thanks to all the great people here that helped me through my first project!
This is a project I have been working on for a while. We usually just use egg timers to simulate explosives in these games, but I figured it was time for something a little more realistic looking.
Video:
How it Works:
The bomb must be attached to the tether (which is locked to a tree or other immobile object) before it can be armed, this ensures that the bomb can only be armed in the designated area. If the tether is removed at any time while the bomb is on, it will detonate. It can only be turned on and off with an electronic key switch, I have 2 keys, one for each team leader/ref. To arm the bomb a 7 digit code must be entered. This starts a countdown. The countdown can be interrupted at any point by pressing the disarm button, when the button is pressed the user is asked for the disarm code, this is a separate 7 digit code from the arm code. After the disarm button is pressed, the bomb will wait 15 seconds for a code to be entered, if the code is correct, the countdown will end and the LCD will display "Bomb Disarmed". If the code is incorrect no message will be displayed, press the reset key ( the "*" key) and try again. If no code is entered after 15 seconds, the counter will restart and 15 seconds will be subtracted from the time left. When the countdown reaches 0, a buzzer is sounded and the LCD will display "Have A Nice Day". It sounds more complicated than it is, just watch the video.
Variables: - can be changed at any time.
Countdown time 0hr:2min:30sec
Arm code: 7355608
Disarm code: 1234567
The Bomb can be powered by a normal 9v battery, or a 12v 1.6A/hr battery. Right now I have it attached to a small buzzer, but it has more than enough battery capacity to run a siren, strobe, radio, electric detonator, servo, or just about anything that would be useful to alert people when the bomb is detonated.
Code
http://pastebin.com/f57045830
This is my first project, so i'm assuming that there are quite a few errors and places where I made an error, then reversed to to make the code work. Feel free to suggest any alternate ways to achieve this (if the code is clean enough to even be readable by other people, that is).
« Last Edit: April 27, 2009, 10:07:29 am by wizdum » Logged
"Anyone who isn't confused really doesn't understand the situation."
Arduino-based airsoft props -> www.nightscapetech.com
Norway@Oslo
loveArduino(true);
Wery cool!
Love the idea, and the implementation.
Made me want to switch back to airsoft, from paintball...  smiley-grin
Simple Solution Technologies
a a co2 canister in line with a paint canister with a spray nozzle with a solenoid in between.
(C02)----(PAINT)-> NOZZLE
Bangkok
freeduino.de Admin
small detonator unter a plastic bag of paint.
Bonn, Germany
somewhat funny that thing smiley-mad)
Good Job
Believe me, Mike, I calculated the odds of this succeeding against the odds I was doing something incredibly stupid[ch8230] and I went ahead anyway.
Bangkok
freeduino.de Admin
just googled a bit. really wonder how companies like this ship their products smiley
http://www.airsoftbomb.com/
Would be funny to have a couple of colored wired that you had to cut in the right order.
« Last Edit: April 29, 2009, 07:33:22 am by bara.munchies » Logged
how did you layout the pinout??? so far i was able to plan out:
0keypad
1keypad
2lcd
3lcd
4lcd
5lcd
6keypad
7keypad
8keypad
9keypad
10keypad
11lcd
12lcd
13buzzer
keyswitch wired between battery and arduino to set ready mode
enter code followed by pound to arm
enter seperate code  followed by pound to disarm
any other presses decrease time by ten sec.
this is my first project as well. i have the code portion covered
but im lacking in the knowledge of what pin can do what.
is it possible to wire the keypad to the analog pins to free up some of the digitals??? id like to add a flashing rgb led so thats another pin there...
« Last Edit: July 17, 2009, 07:51:24 am by Forgottenalarm » Logged
London, England
Go! Go! Arduinoooo !!!
That would take some explaining if you got stopped by the rozzers with it in your boot.
(I hope the yanks can understand that smiley-wink )
« Last Edit: July 17, 2009, 10:26:55 am by zooto68 » Logged
Maine
forgotten, if you use a serial LCD like I did, then you only need to use 1 digital pin for it, that frees up some digital pins. If you already have an LCD, sparkfun sells a serial backpack for LCDs, i'm not sure which ones it will fit though. You can probably put the buzzer on an analog pin, I set mine to trip a relay, then connected the buzzer directly to my 12v power supply.
« Last Edit: July 17, 2009, 09:29:43 am by wizdum » Logged
lol, yeah i didnt get a serial.. ill have to toy with it and see what i can do.  thanks for the reply..
uauuuu
I'm actually working on this exact same project.
I came via a different route, I wanted to put mercury switches in the device but needed some form of latching relay to do it and it took off from there.
I would love to get some shots of the inside of your device if possible (I'm heading towards a lexan box myself with all the guts inside except the keypad since i'm in Seattle)
Thanks!
Maine
Sure, I can get some pictures up tomorrow. I'm still in the process of redesigning this so I can sell them, but I have a working design right now. To cut costs, I followed the tutorial to make a bare-bones arduino, and am now using that instead of the pre-built unit I started with. I'm trying to keep the project updated with pictures and video at http://www.nightscapeairsoft.com I have a really crude wiring diagram here:
http://nightscapeairsoft.com/components/com_joomgallery/img_originals/products_1/bomb_prop_2/schematic_20090805_1204496161.jpg
Maine
Heres a picture of the inside, i'll get better ones when the college work lets up.
http://nightscapeairsoft.com/components/com_joomgallery/img_originals/products_1/bomb_prop_2/inside_20100214_1835757304.jpg
The 8 pin connector is for the keypad (only 7 pins are used), the three pin one is for the LCD, and the various 2pin ones are for the 9v -12v power in, power switch, buzzer, and tether. I used a weather proof project box from NTE.
Wisdum-
I am currently building a project extremely similar to this, except in my version the 'bomb' is buried underground, IED style.  I have rigged a solenoid valve to a compressed air tank, and when activated it sprays washable paint upwards out of a shower head, marking anyone who would have been killed by a real bomb.  It would be a great help if I could get a schematic and parts list (preferably with a website or store name where the parts came from)
Thanks
/me
Pages: [1] 2   Go Up
