Topic: NewSoft Serial compiling Errors (Read 19024 times) previous topic - next topic
Billcost
I am trying to install an xbee module on a project I downloaded the NewSoftSerial from the arduino libary link and unzipped it to the libary folder everything i try even the examples give me this compiling error
"In file included from AtCommand.cpp:21:
C:\zippy1\ardu\arduino-1.0\libraries\NewSoftSerial/NewSoftSerial.h:71: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
C:\zippy1\ardu\arduino-1.0\hardware\arduino\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
Can anyone tell me what i am doing Wrong
stef
I am also having the same problem with GPS/ LCD sketch that I am trying to compile:
In file included from srjGPS_Play2.cpp:18:
C:\Program Files\arduino-1.0-windows\arduino-1.0\libraries\NewSoftSerial/NewSoftSerial.h:71: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
C:\Program Files\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
stef
#2
Dec 28, 2011, 07:54 am Last Edit: Dec 28, 2011, 10:27 am by stef Reason: 1
In researching this, I came across a note in the 1.0 ReleaseNotes stating:
"The SoftwareSerial class has been reimplemented, using the code originally written for the NewSoftSerial library by Mikal Hart. "
On a hunch, I replaced the "NewSoftSerial" references in my code with the updated "SoftwareSerial" references.
Example:   from   "#include <NewSoftSerial.h>"   to   "#include <SoftwareSerial.h>" (be sure to change all references in your code)
I am now able to get a successful compile.
I have yet to upload and try, but at least I have managed to compile without error.  -stef
update: Success on upload and execute.
dweston
I also noticed on the Arduino site that if you are using the V1.0 IDE and you have a reference to
#include <WProgram.h>
in any of your library .h or .cpp files, these references must be changed to
#include <Arduino.h>.
stef
You are correct, I failed to mention that. Thanks for adding.  -stef
MWHM
Um using Arduino IDE 1.0.1 and um also getting this error. I can not do anything to avoid it please help.
dxw00d
If you are using IDE 1.0, then you should be using SoftwareSerial, not NewSoftSerial.
gillianlcr
I am in the same situation.
IDE 1.0.2 ; Xbee modules ;
I have switched every NewSoftSerial in all librairies (SoftwareSerial.cpp +.h)
I do not have WProgram.h
and every time the same compiling error,  as Billcoste and Stef.
In fact, i think i'm lost. :~
what is wrong ?
Thank you in advance
DEEPZZ
hey.............m facing similar problem with Arduino UNO.....
Im getting the following error while compiling:
and
My commands are as follows:
#include <Wire.h>
NewSoftSerial cell(2,3);
#define BMP085_ADDRESS 0x77 // I2C address of BMP085
const unsigned char OSS = 0; //oversampling Setting
int ac1, ac2, ac3;
unsigned int ac4;
unsigned int ac5;
unsigned int ac6;
int b1, b2, mb, mc, md;
long b5;
int i,j,k;
int index=1;
int counter=1;
int SMS_counter= 0;
int pressure_counter= 1;
float critical_height=0.50;
char recharge_centre[4] = "132";
char user[8] = "9160884";
char mobilenumber[8];
char recharge[13];
char inchar;
char Numb2[13];
char Numb1[8];
char Numb3[12];
char number [12];
cell.begin(9600);
Wire.begin();
delay(45000);
cell.println("AT+CMGF=1");
delay(200);
cell.println("AT+CNMI=3,3,0,0");
delay(200);
for(i=0; i!=88; i++)
inchar=cell.read();
Serial.print(inchar);
void Extract()
delay(10000);
cell.print("AT+CPBR=");
cell.println(index);
delay(5000);
SMS_counter = 0;
void Clear ()
for(i=0; i!=50; i++)
inchar=cell.read();
delay(10);
void SMS()
delay(10000);
delay(200);
cell.print("AT+CMGS=");
cell.print(uint8_t(34));
cell.print(number);
cell.println(byte(34));
cell.print("ALERT!! THE WATERLEVEL HAS REACHED CRITICAL HEIGHT. PLEASE EVACUATE TO HIGHER GROUNDS!!");
cell.println(uint8_t(26));
delay(5000);
void Phonebook() // storing New Contact number
delay(10000);
cell.print("AT+CPBW=");
cell.print(counter);
cell.print(",");
cell.print(mobilenumber);
cell.print(",129,");
cell.print("aa");
cell.println(uint8_t(34));
counter ++;
void Recharge() // SMS recharge number to user
delay(10000);
delay(200);
cell.print(user);
cell.print(recharge);
delay(15000);
if(pressure_counter==1)
////////////////////////////////////////// checks for *123 or *124 or *125
Pliz help.............
nickgammon
What the heck are all those blank lines? Attention-seeking?
Read this before posting a programming question
How to use this forum
Code tags, thanks. And get rid of the blank lines.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
PaulS
The answer is the same for you as for the others in this thread. DO NOT USE NewSoftSerial with 1.0+. If you don't like that answer, get over it.
DazzadaBum
hiya i get the same error when verifying  HelloWorld.pde and i am using arduino 1.5.4.
In file included from HelloWorld.pde:3:
C:\Users\Me\Desktop\multiarduino\arduino-1.5.4\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:81: error: conflicting return type specified for 'virtual void LiquidCrystal_I2C::'
C:\Users\Me\Desktop\multiarduino\arduino-1.5.4\hardware\arduino\avr\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
I have checked C:\Users\Me\Desktop\multiarduino\arduino-1.5.4\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h: line 81 and there is no reference to  write(uint8_t)
any help much appreciated
Darryl
nickgammon
PaulS
Starting with 1.0, the default extension for Arduino files is .ino. That you are f**king around with a .pde file should be a clue by 4 that you are dealing with an old library.
Either figure out, based on the bazillions of posts in the past, how to find a newer version or upgrade an older version of the library, or quit using the library. Your choice.
